Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1131
    Dec 2010
    Hong Kong
    Could not download the Mobilephone plugin
    Quote Originally Posted by lambosprit View Post
    ---------- Post added at 10:48 PM ---------- Previous post was at 10:44 PM ----------
    [/COLOR]
    I dont want to do this if I can help it. I want to keep everthing in one place. I see you've downloaded it a few times. What is the problem? Does the download not start, is it corrupt etc.
    Not sure of the problem. The computer tried to load the index.php after clicking the DOWNLOAD button but finally fail and display an error message.
  2. #1132
    Jul 2010
    Hello Everyone,
    I would first like to apologize for my English, but I'm french, so please excuse me if I did misunderstand.
    I started over in the CarPC. (That's a lot of fault, I know).
    I would like to thank all those who develop these plugins because it takes a long time.
    I installed the latest version 1.17 of mobilephone.
    my phone connects fine, I can call and answer calls, but I did not signal strength or battery charge.
    my phone is a sony ericsson W715, it is fully supported by bluesoleil.
    I hope you can help me.
    Sincerely, Cyril.
  3. #1133
    Constant Bitrate Jon-G's Avatar
    Jun 2005
    Chesterfield, UK
    As for your silabs problem its because the BS takes the first audio device in the windows list. Use the wavein and waveout settings in the ini to set it to the sound card you want. Its name should be the same as you see in the sound control panel.[COLOR="Silver"]
    Sorted thanks for that mate! I have found another problem tho with the way that the plugin controls the muted sounds. If Im using the music player at the same time as Sygic is navigating a route, the music remains muted when in a call and the directions keep coming from Sygic through the speakers (which is what I wanted). However if Im doing the same thing but using the radio not the music player, the sound is muted as the call comes in, but then as soon as I pick up the phone the audio is unmuted in the car.
    Is it something I can change at my end again to get it to play nicely. Car-PC is so close to perfection now its untrue!!
  4. #1134
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by cyrille View Post
    Hello Everyone,
    Sincerely, Cyril.
    the signal and battery strength are implemented but very few phones seem to support it.
  5. #1135
    Jul 2010
    ok, thank you.
    is not very embarrassing.
    I noticed something when I receive a call, the window with the name and contact picture appears, but the window flashes.
    So be quick to pick up when the window opens.
    on my desktop it does not.
    Sincerely, Cyril.
  6. #1136
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Jon-G View Post
    I've had a look at the code and it should play nicely. It is using a clucky way of tracking the current radiomute status though and I have fixed that to use the radiomute indicator now. It was working before for me though so don't know if this change actually makes any difference.
    ---------- Post added at 11:08 AM ---------- Previous post was at 11:07 AM ----------
    I'm sorry but this is not something I can help you with. Just keep pestering the appmart crew
  7. #1137
    Jul 2010
    ok, thank you.
    Sincerely, Cyril.
    please,someone can help me?
    thank you miles
  8. #1138
    Jul 2009
    @Lambosprit
    Please can u tell me how i can view what value returns from BlueSoleil for "BatteryStrength"??
    And how u managed the "BatteryImageCount=" in the ini???
  9. #1139
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Which Bluetooth service does Mobilephone.NET use to connect with a cellphone? Reason for asking before I started using this plugin my car radio which connects handsfree and freefone were both able to connect at the same time. Incoming calls were picked up by the car radio, and freefone would display the photos. Outgoing calls I dialled out using freefone and the car radio would show the traffic and mute the radio.
    All that is to say that they were using different Bluetooth services. I could possibly make a configuration change in the phone or radio if I knew what service Mobilephone.NET was connecting through.
    Thanks for any info.
  10. #1140
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by LopoTRI View Post
    @Lambosprit
    Different phones return different values for the max strength so for one phone a value of 5 might be the max but for another it could be only halff (i.e. max is 10). As I have no way of telling what the max number is the ini file is used to set the max value possible to be returned by he phone. You have to work this out your self.
    There is a label called mobilephone_batterystrength which returns a percentage based on the max value set in the ini and the returned number from the phone.
    there's also the special label FILE;$mobilephone_batterystrength$ which returns a file name based on the battery strength number rturned by the phone.
    ---------- Post added at 11:06 PM ---------- Previous post was at 10:59 PM ----------
    Quote Originally Posted by mnwcsult View Post
    it uses the hands free (audio gateway) service if thats what you mean. It also sets the BS local servce to a desktop computer which might be whats causing your problems.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
