Hi I was looking through the mobilephone_readme.txt file and read about the Special Indicators "mobilephone_batterystrength" and "mobilephone_signalstrength". My question is how do you make use of them in the DFX5 mobilephone.skin?
Here is an excerpt from the DFX5 mobilephone.skin
L,167,472,138,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFo nt#,"=Add","center"
L,17,472,138,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFon t#,"=Delete","center"
L,246,-1,81,17,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont#,"=Sig nal:","RIGHT"
L,9,-1,91,17,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont#,"=Bat tery:","RIGHT"
L,508,0,126,17,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"mobilephone_connected","LEFT"
L,15,36,138,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFont #,"=Contacts","center"
L,509,164,77,45,#DFX1R#,#DFX1G#,#DFX1B#,30,#DFXFon t#,"=1","center"
What do I actually change, assuming that I am replacing =Signal: and =Battery:
I also spent a lot of time trying figure out where the images being referred to actually reside and lo and behold found them in the folder "C:\Program Files\RideRunner\Skins\BMW E36" that are part of the mobilephone.NET install.
I copied them to ..\Skins\DFX5\Indicators folder.
Afterwords I went back to the "C:\Program Files\RideRunner\plugins\Mobilephone.NET" folder to modify the mobilephone.ini file section
[PHONESTATUS]
# How often is battery and signal updated in milli seconds.
#Also checks for connection or not and whether ringing to auto answer.
Update=10000
BatteryWarningLevel=10
BatteryImageCount=6 <-- originally 5
BatteryImageExt=gif <-- originally jpg
SignalImageCount=6 <-- originally 5
SignalImageExt=gif <-- originally jpg
#Path to image files for battery and signal strengh
ImagePath=C:\Program Files\RideRunner\Skins\DFX5\Indicators
Fascinating said the Vulcan, it is amazing the revelations that glean from the mere act of reading.
That all I got, if someone would chime in on the use of the special indicators I would greatly appreciate it.
LinkBack URL
About LinkBacks
