Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1161
    Newbie chazzie.t's Avatar
    Mar 2011
    Houston, TX
    subscribe.
  2. #1162
    Mar 2008
    Georgia
    .net Issue
    Hi. I am having an issue that is probably tied to .net rather than the plugin but am wondering if anyone else has experienced it. Whenever I open up the phone on DFX and hit any button, I get a 'system access violation exception. attempted to read or write to protected memory...'
    I have an HTC Nexus One running on BS 8.0.338.
    Any clues as to why this is happening? Thanks!
    Car
    2004 Mazda RX8
    PC
    D201GLY2A with 1.2 ghz 220 Celeron CPU
    1 Gig O'Ram (128 megs video memory)
    Bluetooth
    Wireless Ethernet
    XM-Direct
    Xenarc 705
    Car2PC adapter
    iGuidance v4
    Bluetooth OBD (CAN) Dongle
    ROAD RUNNER!!!
  3. #1163
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    After a little tinkering I got this installed and running. Since I'm running in profile mode, I had to change the skin directory, and I'm wondering if that is responsible for the mobilephone.ini error I got when I first started RR. The message was that the ini wasn't found in c:\users\car\documents\riderunner\plugins\mobileph one.net. I copied the ini from the main plugin directory (in program files\riderunner\plugins) and it worked.
  4. #1164
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I'm having trouble getting RR to make calls with my phone, even though it is showing as connected in the skin (after changing the Carwings indicator to "mobilephone_connected":
    When typing in a number and pressing dial, it simply doesn't do anything.
    I'm using BlueSoleil 6.4.249.0 with a Motorola Droid, and the log is as follows:
    Code:
    5/4/2011 5:31:39 AM:Info   : Starting MobilePhone version:1.17.4070.39887
    5/4/2011 5:31:39 AM:Info   : Current directory: C:\Program Files\RideRunner\plugins\Mobilephone.NET
    5/4/2011 5:31:39 AM:Info   : Current directory: C:\Program Files\RideRunner\Plugins\MobilePhone.Net\
    5/4/2011 5:31:39 AM:Info   : Using BlueSoleil for phone connection
    5/4/2011 5:31:39 AM:Info   : Device address: F4:FC:32:47:BB:EE
    5/4/2011 5:31:39 AM:Info   : Pair code:
    5/4/2011 5:31:39 AM:Info   : International prefix = 0044
    5/4/2011 5:31:39 AM:Info   : National prefix = 0
    5/4/2011 5:31:39 AM:Info   : International shortcut prefix = +44
    5/4/2011 5:31:39 AM:Info   : MobileCall.skin: on
    5/4/2011 5:31:39 AM:Info   : Trying to connect to phone.
    5/4/2011 5:31:41 AM:Fatal  : Device handle not found for specified address
    5/4/2011 5:31:41 AM:Fatal  : BlueSoleil failed to find specified hardware!
    5/4/2011 5:31:41 AM:Info   : IVT BlueSoleil SDK is being quitted!
    5/4/2011 5:31:49 AM:Info   : Trying to connect to phone.
    5/4/2011 5:31:57 AM:Info   : Wavein left as default
    5/4/2011 5:31:57 AM:Info   : WaveOut left as default
    5/4/2011 5:31:57 AM:Info   : You have succeeded in getting a remote device's handle.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  5. #1165
    Aug 2008
    Hi
    I am have installed IVT_BlueSoleil_8.0.356.0 and when i get connected to phone i get new box to playing music from phone look pic
    Is there possible to make command to work thease whit .net Bluetooth Mobilephone Plugin?
  6. #1166
    Apr 2011
    SW Colorado
    Total Newb
    Hi, I'm a total newb to RR. I'm trying to install my first carputer and want to get bluetooth phone calls working. I've got a trial of BlueSoleil 8 installed, the latest RR and the latest .net plugin. I got the phone connected and got the address into .net. I have Phoco disabled.
    My problem is that when I launch RR I get an error saying it cannot find mobilephone.ini and then it closes. I don't know what the .ini file is or how to fix this. Any help is appreciated.
    The system is an AMD Compaq R4000 on Win 7 32 bit with a 4 channel amp and an 8" touch screen.
  7. #1167
    Apr 2011
    SW Colorado
    Must have missed the posts on this page. I copied the entire mobilephone plugins contents over to the my documents version and it runs.
    Unfortunately it isn't working to make calls. I'm running the Reborn skin and it says a phone is "not available." The phone and computer say they are connected. I was very careful typing in the address. What should I do? The phone is a Samsung Eternity II. aka SGH-A597.
  8. #1168
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by lambosprit View Post
    try post 77 of this thread. You need to register with /codebase
    Man, 117 pages and I still can't find my answer. The installation keeps failing so, as you suggested, I went back to post #77 and did it manually. A warning message appeared in the dos window but it completed successfully. The problem now is that because the installation itself fails, it will not continue on pass the fail part and so the ini file (and whatever else) is not installed so when I start Ride Runner, the 'missing ini' file appears and causes RR to blow up.
    Can someone tell me how to have the installation continue after the register failure or post all the files I need after manually registering it? I've been at this for over 4 hours and read every post I could find and frankly, my brain is fried!
    Thanks in advance to all who reply.
    EDIT: I created an XP virtual machine on Win7 box and tried installing mobile phone on a bare bones RideRunner install (with .net framework of course) and the installation failed in the same freakin' place. I have to assume that because it failed on a stand alone XP box and a vmware vm, something in the installation is out of whack or there's something going on with .net framework. I went to my C:\WINDOWS\Microsoft.NET\Framework folder and I see I have the following folders, v1.0.3705, v1.1.4322, v2.0.50727 and v4.0.30319 and registered the phone dll as specified in post #77 using v2.0.50727.
    I've been at this all day and now the wife's pi$$ed at me because we were supposed to go out but I got obsessed with this....guess I'll be on the couch tonight...
    "Imagination is more important than knowledge." -AE
  9. #1169
    Dec 2004
    Upstate New York
    Quote Originally Posted by Jon-G View Post
    Iv finally got the BS 6.4 pairing issue resolved, for some reason the 'create new pair' form doesn't show up during a remote desktop session!!
    Anyway I now I have Mobilephone.net connecting to my phone, but Im getting the exception (object reference not set to an instance of an object) when I hit any of the keypad number buttons (on any of the supplied skins). If I hit the green dial button, my mobile dials out the last number dialled, so the dll must be registered correctly in order to get this far no?
    I have read through this thread trying to troubleshoot and this is what Ive tried so far, all to no avail:
    Uninstall and reinstall plugin
    Check bswrapper.dll and mobilephone.dll are in the rr\plugins\mobilephone.net folder
    Manually registered the mobilephone.dll file as detailed in solution 2 in this thread
    Disabled the alarm page in the ini file (not that I think this is relevant, but was worth doing while I saw the ini entry)
    Checked all other details in the Mobilephone.ini file which is detailed below.
    If anyone could help out with anything I might have overlooked Id really appreciate it:
    [General]
    #Set PhoneLink to Blue if using BlueSoleil otherwise leave blank
    PhoneLink=Blue
    #Do you want to connect to the phone automatically. If connection is lost it will reconnect.
    AutoConnect=True
    #Do you want to auto answer any incomming calls? Value is number of seconds to wait before answering.
    #Value of 0 switches off feature.
    AutoAnswer=0
    #Debug output: can be set to 6 different values.
    #0 = off, 1=Fatal, 2=Error, 3=Warning, 4=Info, 5=Debug
    DebugLevel=4
    #To restart the log file everytime set to tru. This keeps the log as small as possible.
    #Set to false if you want debug stored over several runs
    Debugrefresh=true
    #Sets the device to use for phone mic
    WaveIn=
    #Sets the device to use for phone speaker
    WaveOut=
    [BLUETOOTH]
    #Not required for ATSM
    #Blue tooth address for allowed phone. Found from BlueSoleil by hovering mouse over correct phone.
    #Multiple addresses can be added seperated by a ; Phones connected in order of list. Only one is connected to.
    Address=00:19:63:97:93:99
    #XX:XX:XX:XX:XX:XX
    #Path to the install directory of BlueSoliel. Only used to find the network operator name. Specifically its looking for the IVTProvider.ini file.
    BSPath=C:\Program Files\IVT Corporation\BlueSoleil
    [CONNECTION]
    #Not required for Bluetooth
    Port=COM7
    BaudRate=9600
    DataBit=8
    StopBit=1
    FlowControl=None
    [PHONESTATUS]
    # How often is battery and signal updated in milli seconds.
    #Also checks for connection or not and whether ringing to auto answer.
    Update=10000
    BatteryWarningLevel=10
    BatteryImageCount=5
    BatteryImageExt=jpg
    SignalImageCount=5
    SignalImageExt=jpg
    #Path to image files for battery and signal strengh
    ImagePath=C:\CARPC\RideRunner\Skins\Simplistque VW
    [PHONEBOOK]
    # When a phonecall is terminated the RC,MC and DC txt files are updated, this specifies the delay in milliseconds between the hangup and the sync call
    SyncDelay=1000
    # Path to where the phonebook files should be stored. Leaving blank will save them to RoadRunner folder.
    PhonebookPath=C:\CarPC\RideRunner\plugins\Mobileph one.NET
    InternationalPrefix=0044
    NationalPrefix=0
    ShortCode=+44
    # Path to where to find photos to display for given caller id.
    PhotoPath=C:\CARPC\RideRunner\Skins\PhoneCallerIdP ics
    PhotoExt=jpg
    [ADVANCED]
    #Mess here if you know what your doing.
    MobileCall=on
    [ALARM]
    AlarmEnabled=False
    AlarmCode=1234
    THANK YOU THANK YOU THANK YOU!!!! I was all set to go to bed...I mean, the couch, and decided to scan the posts one more time when I saw this. I coped your ini settings (I was missing the ini file), put in my mac address and it worked!!!! Woo Hoo! Only spent a full day on this! LOL! Now a little fine tuning with icons, etc. and I should be good to go! Thanks again.
    My contacts aren't being saved and the little battery pics etc. aren't anywhere to be found but I can call and accept calls so that's a great start. Guess I'll be up all night!
  10. #1170
    Jan 2011
    So I read this whole thread and Got my phone to connect make calls, end calls, swap from hands free to cell phone, but i get no audio through the speakers. Went to the .ini file and tried 30 different combinations of realtek hd audio output and what not. still no audio. Using win7, latest 1.17 .net bluetooth mobilephone plugin, latest rr, dfx 5.1, and my phone is a HTC G2. I set my debug to 5 and it doesn't give me any errors. Any help would be appreciated thanks.
    edit: realized I didnt' install the drivers from my mb disc and let windows 7 give me generic audio drivers ..... So the sound works but now the microphone doesn't... will try again tomorrow
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
