Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1211
    Aug 2008
    Quote Originally Posted by Spawn12336 View Post
    I'm getting an error from the install that I am missing the VC++ redistributable on win7. I have downloaded the 2010 x86 redistributable and installed it, but it still gives me that error on the install. the mobilephone.dll will not register without it. I've tried running the installer as administrator, and get the same results.
    any help?
    Copy VC++ redistributable setup file and mobilephone.net setup file in the same folder.
    Run mobilephone.net Installer. During installation it will run VC++ redistributable setup file and then just chose to repair. now your mobilephone.dll should be registered.
  2. #1212
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    Thanks Mali,
    I've give that a go later tonight.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  3. #1213
    Dec 2006
    cant connect to phone
    Hi All
    Ive been trying for a few days to get my phone to connect and done everything i can find in the thread but with no joy.
    Debug file allways says the same thing
    28/10/2011 20:28:10:Info : Starting MobilePhone version:1.17.4070.39887
    28/10/2011 20:28:10:Info : Current directory: C:\Program Files\RideRunner\plugins\Mobilephone.NET
    28/10/2011 20:28:10:Info : Current directory: C:\Documents and Settings\lee\My Documents\RideRunner\Plugins\MobilePhone.Net\
    28/10/2011 20:28:10:Info : Using BlueSoleil for phone connection
    28/10/2011 20:28:10:Info : Device address: C0:E4:22:9D:6F:4C
    28/10/2011 20:28:10:Info : Pair code:
    28/10/2011 20:28:10:Info : International prefix = 0044
    28/10/2011 20:28:10:Info : National prefix = 0
    28/10/2011 20:28:10:Info : International shortcut prefix = +44
    28/10/2011 20:28:10:Info : MobileCall.skin: on
    28/10/2011 20:28:10:Info : Trying to connect to phone.
    28/10/2011 20:28:10:Info : Properties called
    28/10/2011 20:28:20:Info : Trying to connect to phone.
    28/10/2011 20:28:20:Fatal : Device handle not found for specified address
    28/10/2011 20:28:20:Fatal : BlueSoleil failed to find specified hardware!
    28/10/2011 20:28:20:Info : IVT BlueSoleil SDK is being quitted!
    In frustration i tried the partners samsung, i didnt get any battery levels or signal but it connected and i could make calls.......
    Changed the mac address back to my phoe and naff all lol
    copy and pasted the address just in case i was typing it all and still nothing
    so maybe its my phone Bluesoleil says paired and connected phone says connected to media audio im sure it used to say headset????
    Think thats enough infomation lol
    Thanks for any info
    Lee
    my phone is a rooted htc hero running android 2.1
    Ok just found an old nokia in a drawer and up and running inside 5 mins So i guesss its down to my not so smart smart phone lol has any body managed to get an android phone working in this
    Just thought i would try ATSM but still nothing lol bug report
    30/10/2011 07:26:04:Info : Starting MobilePhone version:1.17.4070.39887
    30/10/2011 07:26:04:Info : Current directory: C:\Program Files\RideRunner\plugins\Mobilephone.NET
    30/10/2011 07:26:04:Info : Current directory: C:\Documents and Settings\lee\My Documents\RideRunner\Plugins\MobilePhone.Net\
    30/10/2011 07:26:04:Info : Using ATSMS for phone connection.
    30/10/2011 07:26:04:Info : International prefix = 0044
    30/10/2011 07:26:04:Info : National prefix = 0
    30/10/2011 07:26:04:Info : International shortcut prefix = +44
    30/10/2011 07:26:04:Info : MobileCall.skin: on
    30/10/2011 07:26:05:Info : Trying to connect to phone.
    30/10/2011 07:26:05:Fatal : Exception caught while loading ini parameters: 21
    30/10/2011 07:26:05:Info : Properties called
    30/10/2011 07:26:05:Info : Com port set to COM5
    30/10/2011 07:26:05:Info : BaudRate set to 9600
    30/10/2011 07:26:05:Info : DataBits set to 8
    30/10/2011 07:26:05:Info : StopBit set to 1
    30/10/2011 07:26:05:Info : FlowControl set to None
    30/10/2011 07:26:28:Info : Connected to phone.
    30/10/2011 07:26:48:Fatal : Failed to connect to phone.ATSMS.InvalidOpException: Cannot enable CLIP ---> System.NullReferenceException: Object reference not set to an instance of an object.
    at ATSMS.GSMModem.EnableCLIP()
    --- End of inner exception stack trace ---
    at ATSMS.GSMModem.set_IncomingCallIndication(Boolean Value)
    at MobilePhone.MobilePhone.internal_connect()
  4. #1214
    Oct 2007
    error with registering DLL
    I have tried to install the plugin but it gets stuck at registering the dll, I have read your readme and tried to do it manualy with no joy. I have all related programs installed.
    system OS win7 x86
    here is the errors from manual attempt
    C:\Windows\Microsoft.NET\Framework>cd v2.0.50727
    C:\Windows\Microsoft.NET\Framework\v2.0.50727>rega sm "%pathofrideruner%\mobileph
    one.dll"/tlb:mobilephone.tlb /codebase
    Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.5420
    Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
    RegAsm : error RA0000 : The given path's format is not supported.
    C:\Windows\Microsoft.NET\Framework\v2.0.50727>rega sm MobilePhone.dll /tlb:mobile
    phone.tlb /codebase
    RegAsm : error RA0000 : Unable to locate input assembly 'MobilePhone.dll' or one
    of its dependencies.
    C:\Windows\Microsoft.NET\Framework\v2.0.50727>cd..
    C:\Windows\Microsoft.NET\Framework>cd\..
    C:\>cd programfiles
    The system cannot find the path specified.
    C:\>cd program files
    C:\Program Files>cd riderunner
    C:\Program Files\RideRunner>cd plugins
    C:\Program Files\RideRunner\Plugins>regasm MobilePhone.dll /tlb:mobilephone.tlb
    /codebase
    'regasm' is not recognized as an internal or external command,
    operable program or batch file.
    C:\Program Files\RideRunner\Plugins>cd\..
    C:\>cd windows\microsoft.net\framework\v2.0.50727
    C:\Windows\Microsoft.NET\Framework\v2.0.50727>rega sm c:\Program Files\RideRunner
    \Plugins\MobilePhone.dll /tlb:c:\Program Files\RideRunner\Plugins\mobilephone.tl
    b /codebase
    RegAsm : error RA0000 : Unable to locate input assembly 'c:\Program' or one of i
    ts dependencies.
  5. #1215
    Jan 2011
    The command you need is more or less the first, but you also should put the whole path manually since there is no variable really as %pathofriderunner%.
    What you need from the .NET folder that you are in is the following:
    C:\Windows\Microsoft.NET\Framework\v2.0.50727>rega sm "c:\Program Files\RideRunner\Plugins\MobilePhone.dll" /tlb /codebase
    Another easier way to do it is to copy regasm.exe to your plugin folder, go there and just type regasm MobilePhone.dll /tlb /codebase.
    Also, just in case, be sure you are running command line as administrator.
    On another note, I'm having a similar issue with what Paul Murray describes here(check the video), and I'm using the Reborn skin and not DFX.
  6. #1216
    Oct 2007
    Quote Originally Posted by BrocasHelm View Post
    Thanks, I will Try that....
    ok got the skins working now but still does not turn bluetooh on in rr any ideas, do I need a nother plugin to get it working?
  7. #1217
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Gettin " MObilephone.net ini not found. Looked in both :documents/riderunner/plugins/mobilephone.net and in programfiles/riderunner/plugins and there is no .ini in either. Fresh install windows 7 X86
  8. #1218
    lambosprit's Avatar
    Sep 2006
    UK
    I think win7 has problems with the installer. So many are now using win7 that i am trying to update the installer to cope with it.
  9. #1219
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to see the signal for the battery and the signal but into the skintool the path is bad !
    D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm_new\MobilePhone_P ictures\\MOBILEPHONE_BATTERY_ |.jpg
    into my .ini file:
    ImagePath=D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm_new\MobilePhone_P ictures
    Where is my error please ?
  10. #1220
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Yoo.. trying to throw this in to the mix
    are there a .txt with all commands and labels?
    want to enable a few of those commented out by default... just need a short list of the labels etc so i know what do what
    Blessed are the "cracked" for it is they who let in the light.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
