mobilephone_readme in the Mobilephone.NET folder
Printable View
thank you sir :-D
looking at the readme and comparing to skin file...
SC01,130,175,200,350,0,0,0,255,255,255,0,0,0,255,1 28,0,true,14,"Arial"
what do that window do? show phonebook?
must have slipped my eyes but did not find it in readme
EDIT: think i understand now.... MOBILECALL.skin are opened if incomming call or i start a call myself right?
new issue:
path for signal strenght is set to:
but this is what comes up in log:Code:#Path to image files for battery and signal strengh
ImagePath=C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone
note double slash.. if i add slash there will just be tripple slashCode:SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
Multiple slashes in paths should not be an issue (in most cases) unless a program/plugin is doing something with it.
ok, just about to test it... just noted that rr connet to phone but signal and battery strenght do not show up
so this is about last plugin i need before i'm done....
what i noted today that RR can connect to phone... when i enter a phone number on phone i hear sound in speakers so i assume link is ok....
but when i tap numbers on screen there are a error... i just hope it shows up in logs
and i tried to dial a number from phone but then bluetooth connection was lost at the 2nd ring...
So i just tried to dial the phone from another... everything works but as soon i hit pickup i get the same access error thing... it did not show up in mobilephonedebig but here it is anyway:
rr debug in case its needed (in fact error was written there but i will copy out that for another code box):Code:09-12-2011 00:01:11:Info : Starting MobilePhone version:1.17.4070.39887
09-12-2011 00:01:11:Info : Current directory: C:\Program Files (x86)\RideRunner\plugins\Mobilephone.NET
09-12-2011 00:01:11:Info : Current directory: C:\Program Files (x86)\RideRunner\Plugins\MobilePhone.Net\
09-12-2011 00:01:11:Info : Using BlueSoleil for phone connection
09-12-2011 00:01:11:Info : Device address: 00:24:7D:01:2e:e2
09-12-2011 00:01:11:Info : Pair code:
09-12-2011 00:01:11:Info : International prefix = 0045
09-12-2011 00:01:11:Info : National prefix =
09-12-2011 00:01:11:Info : International shortcut prefix = +45
09-12-2011 00:01:11:Info : MobileCall.skin: on
09-12-2011 00:01:11:Info : Trying to connect to phone.
09-12-2011 00:01:11:Info : Properties called
09-12-2011 00:01:17:Fatal : Device handle not found for specified address
09-12-2011 00:01:17:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:01:17:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:01:21:Info : Trying to connect to phone.
09-12-2011 00:01:23:Info : Wavein left as default
09-12-2011 00:01:23:Info : WaveOut left as default
09-12-2011 00:01:23:Info : You have succeeded in getting a remote device's handle.
09-12-2011 00:03:51:Info : Trying to connect to phone.
09-12-2011 00:03:51:Fatal : Device handle not found for specified address
09-12-2011 00:03:51:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:03:51:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:01:Info : Trying to connect to phone.
09-12-2011 00:04:04:Fatal : Device handle not found for specified address
09-12-2011 00:04:04:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:04:04:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:11:Info : Trying to connect to phone.
09-12-2011 00:04:11:Fatal : Device handle not found for specified address
09-12-2011 00:04:11:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:04:11:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:18:Info : Phonebook functionality not part of current SDK
09-12-2011 00:04:21:Info : Trying to connect to phone.
09-12-2011 00:04:23:Fatal : Device handle not found for specified address
09-12-2011 00:04:23:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:04:23:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:31:Info : Trying to connect to phone.
09-12-2011 00:04:31:Fatal : Device handle not found for specified address
09-12-2011 00:04:31:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:04:31:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:41:Info : Trying to connect to phone.
09-12-2011 00:04:41:Fatal : Device handle not found for specified address
09-12-2011 00:04:41:Fatal : BlueSoleil failed to find specified hardware!
09-12-2011 00:04:41:Info : IVT BlueSoleil SDK is being quitted!
09-12-2011 00:04:44:Info : Shutting down normally
error here:Code:09-12-2011 00:00:57: Start -- Version: 04-11-2011
09-12-2011 00:00:57: OS Type: Windows 7
09-12-2011 00:00:57: FileManager: FileMode = Legacy
09-12-2011 00:00:57: FileManager: mypath = C:\Program Files (x86)\RideRunner\
09-12-2011 00:00:57: FileManager: ProfilePath = C:\Users\-bil-\Documents\RideRunner\
09-12-2011 00:00:57: Start Sequence: Starting Player...
09-12-2011 00:00:57: PLAYER: Initialization creating object
09-12-2011 00:00:57: PLAYER: Started
09-12-2011 00:00:57: PLAYER: BASSRR Version: ( 2.4 )
09-12-2011 00:00:57: PLAYER: Restored rrpl.m3u8
09-12-2011 00:00:57: PLAYER: Initialization complete
09-12-2011 00:00:57: Start Sequence: Starting Radio Device...
09-12-2011 00:00:57: Venice5---> RadioPowerOn: Create Radio Object
09-12-2011 00:01:00: Venice5---> RadioStart: Com Port COM5 Opened, waiting for ATR
09-12-2011 00:01:00: Start Sequence: Starting Serial Devices...
09-12-2011 00:01:00: Start Sequence: Starting Mixer...
09-12-2011 00:01:00: VMC---> Set object successful
09-12-2011 00:01:00: VMC---> SOURCE: Mixer line #1: "Lydstyrke"
09-12-2011 00:01:00: VMC---> SOURCE: Mixer line #2: "Lydstyrke"
09-12-2011 00:01:00: Start Sequence: Starting Speech...
09-12-2011 00:01:01: Venice5---> RadioStart: Radio found on COM5
09-12-2011 00:01:01: Venice5---> RadioPowerOn: RadioOn()
09-12-2011 00:01:03: DirectDraw Count: 3 - [] [{67685559-3106-11D0-B971-00AA00342F9F}] [{6768555E-3106-11D0-B971-00AA00342F9F}]
09-12-2011 00:01:03: Plugin Manager: loading Global Plugins...
09-12-2011 00:01:08: Plugin Manager: Plugin Found: BASSRR
09-12-2011 00:01:08: Plugin Manager: Plugin loaded (Global): BASSRR
09-12-2011 00:01:10: Plugin Manager: Plugin Found: MobilePhone(.NET)
09-12-2011 00:01:10: Plugin Manager: Plugin loaded (Global): MobilePhone
09-12-2011 00:01:11: Plugin Manager: Plugin Found: RRCleanScreen(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
09-12-2011 00:01:11: Plugin Manager: Plugin Found: RRFuelPrices
09-12-2011 00:01:11: Plugin Manager: Plugin loaded (Global): RRFuelPrices
09-12-2011 00:01:16: Plugin Manager: Plugin Found: RRMJSGUSBIO(.NET)
09-12-2011 00:01:16: Plugin Manager: Plugin loaded (Global): RRMJSGUSBIO
09-12-2011 00:01:16: Plugin Manager: Plugin Found: RRPDC plugin found but will be unable to create (most likely NOT registered)[skipped].
09-12-2011 00:01:17: Plugin Manager: Plugin Found: RRTMS
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): RRTMS
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Enabled Method
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Initialize Method
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Properties Method
09-12-2011 00:01:17: Plugin Manager: Plugin Found: RRTrafficCam
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): RRTrafficCam
09-12-2011 00:01:17: Plugin Manager: Plugin Found: SkinTool
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): SkinTool
09-12-2011 00:01:17: Plugin Manager: loading Global Plugins Completed.
09-12-2011 00:01:17: LoadSkin: C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\
09-12-2011 00:01:18: Plugin Manager: loading SkinDir Plugins...
09-12-2011 00:01:18: Plugin Manager: loading SkinDir Plugins Completed.
09-12-2011 00:01:20: Enter Exec: False, menu.skin, "ONRESTORED", False
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONRESTORED", False
09-12-2011 00:01:20: Executing: ONRESTORED
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONMOBILEPHONEDISCONNECTED", False
09-12-2011 00:01:20: Executing: ONMOBILEPHONEDISCONNECTED
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONSTART", False
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONLINE", False
09-12-2011 00:01:20: Leave Exec: False, menu.skin, ONLINE, False
09-12-2011 00:01:20: Global Hotkey: Successfully registered keycode:2112
09-12-2011 00:01:20: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:01:20: AudPlayerStart: music player: PLPosition=0 TrackPosition=-12
09-12-2011 00:01:20: AudPlayerStart: player volume be 0: 0
09-12-2011 00:01:21: AudPlayerStart: player should be playing: PLAYING
09-12-2011 00:01:21: AudPlayerStart: Player.GetTrackLength: 262432
09-12-2011 00:01:21: AudPlayerStart: Player.SetTrackPosition: 12
09-12-2011 00:01:21: CheckResume: Resuming to music player: PAUSED
09-12-2011 00:01:21: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:21: Que Exec: True, menu.skin, "ONSKINSTART", False
09-12-2011 00:01:21: EXECTBL Translation: ONSKINSTART -> MJSGIO_SETRELAY;1;1;1
09-12-2011 00:01:21: EXECTBL Translation: ONSKINSTART -> SetApps||SetCommandLabels01||SetAppLabels||$default$||1strun
09-12-2011 00:01:21: EXECTBL Translation: SetApps -> SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:01:21: Executing: SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels01||SetAppLabels||$default$||1strun", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels01 -> SETVAR;MyApp01LB;Musik||SetCommandLabels02
09-12-2011 00:01:21: Executing: SETVAR;MyApp01LB;Musik
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels02", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels02 -> SETVAR;MyApp02LB;Radio||SetCommandLabels03
09-12-2011 00:01:21: Executing: SETVAR;MyApp02LB;Radio
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels03", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels03 -> SETVAR;MyApp03LB;Video||SetCommandLabels04
09-12-2011 00:01:21: Executing: SETVAR;MyApp03LB;Video
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels04", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels04 -> SETVAR;MyApp04LB;Benzin Priser||SetCommandLabels05
09-12-2011 00:01:21: Executing: SETVAR;MyApp04LB;Benzin Priser
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels05", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels05 -> SETVAR;MyApp05LB;Trafik Kamera||SetCommandLabels06
09-12-2011 00:01:21: Executing: SETVAR;MyApp05LB;Trafik Kamera
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels06", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels06 -> SETVAR;MyApp06LB;MobilTlf.||SetCommandLabels07
09-12-2011 00:01:21: Executing: SETVAR;MyApp06LB;MobilTlf.
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels07", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels07 -> SETVAR;MyApp07LB;GPS||SetCommandLabels08
09-12-2011 00:01:21: Executing: SETVAR;MyApp07LB;GPS
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels08", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels08 -> SETVAR;MyApp08LB;Dæktryk||SetCommandLabels09
09-12-2011 00:01:21: Executing: SETVAR;MyApp08LB;Dæktryk
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels09", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels09 -> SETVAR;MyApp09LB;Bak Kamera||SetCommandLabels10
09-12-2011 00:01:21: Executing: SETVAR;MyApp09LB;Bak Kamera
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels10", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels10 -> SETVAR;MyApp10LB;<Unused>||SetCommandLabels11
09-12-2011 00:01:21: Executing: SETVAR;MyApp10LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels11", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels11 -> SETVAR;MyApp11LB;<Unused>||SetCommandLabels12
09-12-2011 00:01:21: Executing: SETVAR;MyApp11LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels12", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels12 -> SETVAR;MyApp12LB;<Unused>||SetCommandLabels13
09-12-2011 00:01:21: Executing: SETVAR;MyApp12LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels13", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels13 -> SETVAR;MyApp13LB;<Unused>||SetCommandLabels14
09-12-2011 00:01:21: Executing: SETVAR;MyApp13LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels14", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels14 -> SETVAR;MyApp14LB;<Unused>||SetCommandLabels15
09-12-2011 00:01:21: Executing: SETVAR;MyApp14LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels15", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels15 -> SETVAR;MyApp15LB;<Unused>||SetCommandLabels16
09-12-2011 00:01:21: Executing: SETVAR;MyApp15LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels16", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels16 -> SETVAR;MyApp16LB;<Unused>||SetCommandLabels17
09-12-2011 00:01:21: Executing: SETVAR;MyApp16LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels17", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels17 -> SETVAR;MyApp17LB;<Unused>||SetCommandLabels18
09-12-2011 00:01:21: Executing: SETVAR;MyApp17LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels18", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels18 -> SETVAR;MyApp18LB;<Unused>||SetCommandLabels19
09-12-2011 00:01:21: Executing: SETVAR;MyApp18LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels19", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels19 -> SETVAR;MyApp19LB;<Unused>||SetCommandLabels20
09-12-2011 00:01:21: Executing: SETVAR;MyApp19LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels20", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels20 -> SETVAR;MyApp20LB;<Unused>||SetCommandLabels21
09-12-2011 00:01:21: Executing: SETVAR;MyApp20LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels21", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels21 -> SETVAR;MyApp21LB;<Unused>||SetCommandLabels22
09-12-2011 00:01:21: Executing: SETVAR;MyApp21LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels22", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels22 -> SETVAR;MyApp22LB;<Unused>||SetCommandLabels23
09-12-2011 00:01:21: Executing: SETVAR;MyApp22LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels23", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels23 -> SETVAR;MyApp23LB;<Unused>||SetCommandLabels24
09-12-2011 00:01:21: Executing: SETVAR;MyApp23LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels24", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels24 -> SETVAR;MyApp24LB;<Unused>||SetCommandLabels25
09-12-2011 00:01:21: Executing: SETVAR;MyApp24LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels25", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels25 -> SETVAR;MyApp25LB;<Unused>||SetCommandLabels26
09-12-2011 00:01:21: Executing: SETVAR;MyApp25LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels26", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels26 -> SETVAR;MyApp26LB;<Unused>||SetCommandLabels27
09-12-2011 00:01:21: Executing: SETVAR;MyApp26LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels27", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels27 -> SETVAR;MyApp27LB;<Unused>||SetCommandLabels28
09-12-2011 00:01:21: Executing: SETVAR;MyApp27LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels28", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels28 -> SETVAR;MyApp28LB;<Unused>||SetCommandLabels29
09-12-2011 00:01:21: Executing: SETVAR;MyApp28LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels29", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels29 -> SETVAR;MyApp29LB;USB I/O||SetCommandLabels30
09-12-2011 00:01:21: Executing: SETVAR;MyApp29LB;USB I/O
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels30", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels30 -> SETVAR;MyApp30LB;RRCleanScreen||SetCommandLabels31
09-12-2011 00:01:22: Executing: SETVAR;MyApp30LB;RRCleanScreen
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetCommandLabels31", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels31 -> SETVAR;MyApp31LB;Dimmer||SetCommandLabels32
09-12-2011 00:01:22: Executing: SETVAR;MyApp31LB;Dimmer
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetCommandLabels32", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels32 -> SETVAR;MyApp32LB;BackGround
09-12-2011 00:01:22: Executing: SETVAR;MyApp32LB;BackGround
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetAppLabels||$default$||1strun", False
09-12-2011 00:01:22: EXECTBL Translation: SetAppLabels -> SETVAR;ButtonLabel;=Musik<<=Radio<<=Video<<=Benzin Priser<<=Trafik Kamera<<=MobilTlf.<<=GPS<<=Dæktryk<<=Bak Kamera<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=USB I/O<<=RRCleanScreen<<=Dimmer<<=Background
09-12-2011 00:01:22: Executing: SETVAR;ButtonLabel;=Musik<<=Radio<<=Video<<=Benzin Priser<<=Trafik Kamera<<=MobilTlf.<<=GPS<<=Dæktryk<<=Bak Kamera<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=USB I/O<<=RRCleanScreen<<=Dimmer<<=Background
09-12-2011 00:01:22: Que Exec: True, menu.skin, "$default$||1strun", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "1strun", False
09-12-2011 00:01:22: EXECTBL Translation: 1strun -> BYVAR;1STRUN;NOTHING<<1strunon||SAVETOSKIN;1STRUN;0
09-12-2011 00:01:22: Executing: BYVAR;1STRUN;NOTHING<<1strunon
09-12-2011 00:01:22: Que Exec: True, menu.skin, "NOTHING", False
09-12-2011 00:01:22: Executing: NOTHING
09-12-2011 00:01:22: Command not executed: NOTHING
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
09-12-2011 00:01:22: Executing: ONCOMMANDINVALID
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SAVETOSKIN;1STRUN;0", False
09-12-2011 00:01:22: Executing: SAVETOSKIN;1STRUN;0
09-12-2011 00:01:22: SAVETOINI: C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\skin.ini
09-12-2011 00:01:22: Que Exec: True, menu.skin, "MJSGIO_SETRELAY;1;1;1", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONMJSGIO_START", False
09-12-2011 00:01:22: EXECTBL Translation: ONMJSGIO_START -> MJSGIO_EVENTS;1;true
09-12-2011 00:01:22: Leave Exec: False, menu.skin, events;1;true, False
09-12-2011 00:01:22: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONSONGSTART", False
09-12-2011 00:01:22: Leave Exec: False, menu.skin, ONSONGSTART, False
09-12-2011 00:01:23: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:23: Que Exec: True, menu.skin, "ONMOBILEPHONENETAVAIL", False
09-12-2011 00:01:23: Executing: ONMOBILEPHONENETAVAIL
09-12-2011 00:01:23: Leave Exec: False, menu.skin, ONMOBILEPHONENETAVAIL, False
09-12-2011 00:01:23: Que Exec: True, menu.skin, "ONMOBILEPHONECONNECTED", False
09-12-2011 00:01:23: Executing: ONMOBILEPHONECONNECTED
09-12-2011 00:01:23: Leave Exec: False, menu.skin, ONMOBILEPHONECONNECTED, False
09-12-2011 00:02:14: Enter Exec: False, menu.skin, , False
09-12-2011 00:02:14: Que Exec: True, menu.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:14: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:14: Que Exec: True, menu.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:14: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:14: Leave Exec: False, menu.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:14: Enter Exec: False, menu.skin, "VOL-", True
09-12-2011 00:02:14: Que Exec: True, menu.skin, "VOL-", True
09-12-2011 00:02:14: Executing: VOL-
09-12-2011 00:02:14: Leave Exec: False, menu.skin, VOL-, True
09-12-2011 00:02:15: Executing: VOL-
09-12-2011 00:02:15: Leave Exec: False, menu.skin, VOL-, True
09-12-2011 00:02:15: Enter Exec: False, menu.skin, "ONBTNPRESS||VOL-", False
09-12-2011 00:02:15: Que Exec: True, menu.skin, "ONBTNPRESS||VOL-", False
09-12-2011 00:02:15: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:15: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:15: Que Exec: True, menu.skin, "VOL-", False
09-12-2011 00:02:15: Leave Exec: False, menu.skin, VOL-, False
09-12-2011 00:02:16: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:16: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:16: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:16: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:16: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:02:16: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:16: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:16: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:02:16: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:16: Executing: Menu;mobilephone.skin
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:19: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:02:19: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:19: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:19: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:19: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "SkinButton6", False
09-12-2011 00:02:19: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:19: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "MyApp06", False
09-12-2011 00:02:19: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:19: Executing: Menu;mobilephone.skin
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "cancel||Menu;mobilephone.skin", False
09-12-2011 00:02:19: Executing: cancel
09-12-2011 00:02:19: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:02:19: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:19: Que Exec: True, menu.skin, "Menu;mobilephone.skin", False
09-12-2011 00:02:21: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:21: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:21: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:21: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:21: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:21: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:28: Enter Exec: False, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:02:28: Que Exec: True, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:02:28: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:28: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:28: Que Exec: True, mobilephone.skin, "EXIT", False
09-12-2011 00:02:28: Executing: EXIT
09-12-2011 00:02:28: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:02:28: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:28: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
09-12-2011 00:02:30: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:30: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:30: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:30: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:30: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:02:30: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:30: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:30: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:02:30: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:30: Executing: Menu;mobilephone.skin
09-12-2011 00:02:30: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:30: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:02:31: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:31: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:31: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:31: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:31: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:31: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:41: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:41: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:41: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:41: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:41: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:41: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:51: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:51: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:51: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:51: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:51: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:51: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:03:01: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:03:01: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:03:01: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:03:01: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:03:01: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:03:01: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:03:06: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "ONMOBILEPHONERING", False
09-12-2011 00:03:06: Executing: ONMOBILEPHONERING
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "RADIOMUTE;ON", False
09-12-2011 00:03:06: Executing: RADIOMUTE;ON
09-12-2011 00:03:06: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:06: Executing: ONCOMMANDINVALID
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:06: Executing: MENU;MOBILECALL.SKIN;
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "cancel||MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:06: Executing: cancel
09-12-2011 00:03:06: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:03:07: Enter Exec: True, menu.skin, , False
09-12-2011 00:03:07: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:07: Que Exec: True, menu.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Executing: MENU;MOBILECALL.SKIN;
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "ONMOBILEPHONERING", False
09-12-2011 00:03:07: Executing: ONMOBILEPHONERING
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "cancel||MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Executing: cancel
09-12-2011 00:03:07: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:03:08: Que Exec: True, mobilecall.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:08: Leave Exec: False, mobilecall.skin, ONSCREENCHANGE, False
09-12-2011 00:03:12: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:12: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Executing: RADIOMUTE;ON
09-12-2011 00:03:12: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:12: Executing: ONCOMMANDINVALID
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Executing: WAIT;0.2
09-12-2011 00:03:12: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:13: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:13: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:13: Executing: ONCOMMANDINVALID
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
ved MobilePhone.APIs.ReturnCallBacks(UInt16 levent)
ved MobilePhone.MobilePhone.get_Ringing()
ved MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm);5", False
09-12-2011 00:03:13: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:13: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:18: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
ved MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm);5, False
09-12-2011 00:03:19: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:19: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: RADIOMUTE;ON
09-12-2011 00:03:19: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:19: Executing: ONCOMMANDINVALID
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: WAIT;0.2
09-12-2011 00:03:19: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:19: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:19: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:19: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:24: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:37: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:37: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:37: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:37: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: RADIOMUTE;ON
09-12-2011 00:03:38: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:38: Executing: ONCOMMANDINVALID
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: WAIT;0.2
09-12-2011 00:03:38: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:38: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:38: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:38: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:43: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:51: Enter Exec: False, mobilecall.skin, , False
09-12-2011 00:03:51: Que Exec: True, mobilecall.skin, "ONMOBILEPHONEDISCONNECTED", False
09-12-2011 00:03:51: Executing: ONMOBILEPHONEDISCONNECTED
09-12-2011 00:03:51: Leave Exec: False, mobilecall.skin, ONMOBILEPHONEDISCONNECTED, False
09-12-2011 00:04:08: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:08: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Executing: RADIOMUTE;ON
09-12-2011 00:04:08: Command not executed: RADIOMUTE;ON
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:08: Executing: ONCOMMANDINVALID
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Executing: WAIT;0.2
09-12-2011 00:04:08: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Leave Exec: False, mobilecall.skin, MOBILEPHONE_PICKUP, False
09-12-2011 00:04:11: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:11: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Executing: RADIOMUTE;ON
09-12-2011 00:04:11: Command not executed: RADIOMUTE;ON
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:11: Executing: ONCOMMANDINVALID
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Executing: WAIT;0.2
09-12-2011 00:04:11: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:04:12: Leave Exec: False, mobilecall.skin, MOBILEPHONE_PICKUP, False
09-12-2011 00:04:17: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "ONBTNPRESS||MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:17: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Executing: WAIT;0.2
09-12-2011 00:04:17: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Executing: RADIOMUTE;OFF
09-12-2011 00:04:17: Command not executed: RADIOMUTE;OFF
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:17: Executing: ONCOMMANDINVALID
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "EXIT", False
09-12-2011 00:04:17: Executing: EXIT
09-12-2011 00:04:17: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:18: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:18: Que Exec: True, menu.skin, "RADIOMUTE;OFF", False
09-12-2011 00:04:18: Executing: RADIOMUTE;OFF
09-12-2011 00:04:18: Command not executed: RADIOMUTE;OFF
09-12-2011 00:04:18: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:18: Executing: ONCOMMANDINVALID
09-12-2011 00:04:18: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
09-12-2011 00:04:29: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:04:29: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:04:29: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:29: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:29: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:04:29: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:04:29: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:04:29: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:04:29: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:04:29: Executing: Menu;mobilephone.skin
09-12-2011 00:04:29: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:29: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:04:37: Enter Exec: False, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:04:37: Que Exec: True, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:04:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:37: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:37: Que Exec: True, mobilephone.skin, "EXIT", False
09-12-2011 00:04:37: Executing: EXIT
09-12-2011 00:04:37: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:37: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:37: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
09-12-2011 00:04:38: Enter Exec: False, menu.skin, "ONBTNPRESS||load;exit_menu.skin", False
09-12-2011 00:04:38: Que Exec: True, menu.skin, "ONBTNPRESS||load;exit_menu.skin", False
09-12-2011 00:04:38: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:38: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:38: Que Exec: True, menu.skin, "load;exit_menu.skin", False
09-12-2011 00:04:38: Executing: load;exit_menu.skin
09-12-2011 00:04:40: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:40: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
09-12-2011 00:04:42: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "ONBTNPRESS||MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:42: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "QUIT", False
09-12-2011 00:04:42: Executing: QUIT
09-12-2011 00:04:42: Enter Exec: False, exit_menu.skin, "ONEXIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "ONEXIT", False
09-12-2011 00:04:42: Leave Exec: False, exit_menu.skin, ONEXIT, False
09-12-2011 00:04:42: Shutdown: (1)
09-12-2011 00:04:42: Shutdown: (2)
09-12-2011 00:04:42: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:42: Shutdown: (3)
09-12-2011 00:04:42: Venice5---> RadioStop: Close()
09-12-2011 00:04:42: Venice5---> RadioActive: Active = false
09-12-2011 00:04:42: Venice5---> RadioMuteSet=True
09-12-2011 00:04:42: Venice5---> RadioActive: Active = false, RadioMuteSet(true)
09-12-2011 00:04:42: Shutdown: (4)
09-12-2011 00:04:44: Plugin Manager: Warning Plugin rrtms does not support Terminate Method
09-12-2011 00:04:44: Plugin Manager: Warning Plugin skintool does not support Terminate Method
09-12-2011 00:04:44: Plugin Manager: ALL Plugins unloaded.
09-12-2011 00:04:44: Shutdown: (5)
09-12-2011 00:04:44: Player is running
09-12-2011 00:04:44: Shutdown: (6)
09-12-2011 00:04:44: Shutdown: (7)
09-12-2011 00:04:44: OSUnloadMode: 1
09-12-2011 00:04:44: Global Hotkey: All keys unregistered
the above error looks the same if i try dial from rr or a try to pick up an incomming callCode:09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
I have switched motherboards and now my phone audio comes out on my subwoofer/center speaker line(pink plug). Is there anything i can do to make the sound come from the front speaker output (green plug). I see a setting for waveOut but i dont know what kind of parameter its looking for.
the WaveOut and WaveIn options are looking for your sound card name.
http://www.mp3car.com/vbulletin/rr-r...ml#post1456059
here's what I've got in my mobilephone.ini
#Sets the device to use for phone mic
WaveIn=Andrea PureAudio USB-SA
#Sets the device to use for phone speaker
WaveOut=Andrea PureAudio USB-SA
The value comes from the device manager properties.
Not sure if you can choose which port handles what, that would be more of something for your audio config in Windows I would think.
