So i just tried to dial the phone from another... everything works but as soon i hit pickup i get the same access error thing... it did not show up in mobilephonedebig but here it is anyway:
rr debug in case its needed (in fact error was written there but i will copy out that for another code box):
Code:
09-12-2011 00:00:57: Start -- Version: 04-11-2011
09-12-2011 00:00:57: OS Type: Windows 7
09-12-2011 00:00:57: FileManager: FileMode = Legacy
09-12-2011 00:00:57: FileManager: mypath = C:\Program Files (x86)\RideRunner\
09-12-2011 00:00:57: FileManager: ProfilePath = C:\Users\-bil-\Documents\RideRunner\
09-12-2011 00:00:57: Start Sequence: Starting Player...
09-12-2011 00:00:57: PLAYER: Initialization creating object
09-12-2011 00:00:57: PLAYER: Started
09-12-2011 00:00:57: PLAYER: BASSRR Version: ( 2.4 )
09-12-2011 00:00:57: PLAYER: Restored rrpl.m3u8
09-12-2011 00:00:57: PLAYER: Initialization complete
09-12-2011 00:00:57: Start Sequence: Starting Radio Device...
09-12-2011 00:00:57: Venice5---> RadioPowerOn: Create Radio Object
09-12-2011 00:01:00: Venice5---> RadioStart: Com Port COM5 Opened, waiting for ATR
09-12-2011 00:01:00: Start Sequence: Starting Serial Devices...
09-12-2011 00:01:00: Start Sequence: Starting Mixer...
09-12-2011 00:01:00: VMC---> Set object successful
09-12-2011 00:01:00: VMC---> SOURCE: Mixer line #1: "Lydstyrke"
09-12-2011 00:01:00: VMC---> SOURCE: Mixer line #2: "Lydstyrke"
09-12-2011 00:01:00: Start Sequence: Starting Speech...
09-12-2011 00:01:01: Venice5---> RadioStart: Radio found on COM5
09-12-2011 00:01:01: Venice5---> RadioPowerOn: RadioOn()
09-12-2011 00:01:03: DirectDraw Count: 3 - [] [{67685559-3106-11D0-B971-00AA00342F9F}] [{6768555E-3106-11D0-B971-00AA00342F9F}]
09-12-2011 00:01:03: Plugin Manager: loading Global Plugins...
09-12-2011 00:01:08: Plugin Manager: Plugin Found: BASSRR
09-12-2011 00:01:08: Plugin Manager: Plugin loaded (Global): BASSRR
09-12-2011 00:01:10: Plugin Manager: Plugin Found: MobilePhone(.NET)
09-12-2011 00:01:10: Plugin Manager: Plugin loaded (Global): MobilePhone
09-12-2011 00:01:11: Plugin Manager: Plugin Found: RRCleanScreen(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
09-12-2011 00:01:11: Plugin Manager: Plugin Found: RRFuelPrices
09-12-2011 00:01:11: Plugin Manager: Plugin loaded (Global): RRFuelPrices
09-12-2011 00:01:16: Plugin Manager: Plugin Found: RRMJSGUSBIO(.NET)
09-12-2011 00:01:16: Plugin Manager: Plugin loaded (Global): RRMJSGUSBIO
09-12-2011 00:01:16: Plugin Manager: Plugin Found: RRPDC plugin found but will be unable to create (most likely NOT registered)[skipped].
09-12-2011 00:01:17: Plugin Manager: Plugin Found: RRTMS
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): RRTMS
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Enabled Method
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Initialize Method
09-12-2011 00:01:17: Plugin Manager: Warning Plugin RRTMS does not support Properties Method
09-12-2011 00:01:17: Plugin Manager: Plugin Found: RRTrafficCam
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): RRTrafficCam
09-12-2011 00:01:17: Plugin Manager: Plugin Found: SkinTool
09-12-2011 00:01:17: Plugin Manager: Plugin loaded (Global): SkinTool
09-12-2011 00:01:17: Plugin Manager: loading Global Plugins Completed.
09-12-2011 00:01:17: LoadSkin: C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\
09-12-2011 00:01:18: Plugin Manager: loading SkinDir Plugins...
09-12-2011 00:01:18: Plugin Manager: loading SkinDir Plugins Completed.
09-12-2011 00:01:20: Enter Exec: False, menu.skin, "ONRESTORED", False
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONRESTORED", False
09-12-2011 00:01:20: Executing: ONRESTORED
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONMOBILEPHONEDISCONNECTED", False
09-12-2011 00:01:20: Executing: ONMOBILEPHONEDISCONNECTED
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONSTART", False
09-12-2011 00:01:20: Que Exec: True, menu.skin, "ONLINE", False
09-12-2011 00:01:20: Leave Exec: False, menu.skin, ONLINE, False
09-12-2011 00:01:20: Global Hotkey: Successfully registered keycode:2112
09-12-2011 00:01:20: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:01:20: AudPlayerStart: music player: PLPosition=0 TrackPosition=-12
09-12-2011 00:01:20: AudPlayerStart: player volume be 0: 0
09-12-2011 00:01:21: AudPlayerStart: player should be playing: PLAYING
09-12-2011 00:01:21: AudPlayerStart: Player.GetTrackLength: 262432
09-12-2011 00:01:21: AudPlayerStart: Player.SetTrackPosition: 12
09-12-2011 00:01:21: CheckResume: Resuming to music player: PAUSED
09-12-2011 00:01:21: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:21: Que Exec: True, menu.skin, "ONSKINSTART", False
09-12-2011 00:01:21: EXECTBL Translation: ONSKINSTART -> MJSGIO_SETRELAY;1;1;1
09-12-2011 00:01:21: EXECTBL Translation: ONSKINSTART -> SetApps||SetCommandLabels01||SetAppLabels||$default$||1strun
09-12-2011 00:01:21: EXECTBL Translation: SetApps -> SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:01:21: Executing: SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels01||SetAppLabels||$default$||1strun", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels01 -> SETVAR;MyApp01LB;Musik||SetCommandLabels02
09-12-2011 00:01:21: Executing: SETVAR;MyApp01LB;Musik
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels02", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels02 -> SETVAR;MyApp02LB;Radio||SetCommandLabels03
09-12-2011 00:01:21: Executing: SETVAR;MyApp02LB;Radio
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels03", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels03 -> SETVAR;MyApp03LB;Video||SetCommandLabels04
09-12-2011 00:01:21: Executing: SETVAR;MyApp03LB;Video
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels04", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels04 -> SETVAR;MyApp04LB;Benzin Priser||SetCommandLabels05
09-12-2011 00:01:21: Executing: SETVAR;MyApp04LB;Benzin Priser
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels05", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels05 -> SETVAR;MyApp05LB;Trafik Kamera||SetCommandLabels06
09-12-2011 00:01:21: Executing: SETVAR;MyApp05LB;Trafik Kamera
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels06", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels06 -> SETVAR;MyApp06LB;MobilTlf.||SetCommandLabels07
09-12-2011 00:01:21: Executing: SETVAR;MyApp06LB;MobilTlf.
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels07", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels07 -> SETVAR;MyApp07LB;GPS||SetCommandLabels08
09-12-2011 00:01:21: Executing: SETVAR;MyApp07LB;GPS
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels08", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels08 -> SETVAR;MyApp08LB;Dæktryk||SetCommandLabels09
09-12-2011 00:01:21: Executing: SETVAR;MyApp08LB;Dæktryk
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels09", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels09 -> SETVAR;MyApp09LB;Bak Kamera||SetCommandLabels10
09-12-2011 00:01:21: Executing: SETVAR;MyApp09LB;Bak Kamera
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels10", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels10 -> SETVAR;MyApp10LB;<Unused>||SetCommandLabels11
09-12-2011 00:01:21: Executing: SETVAR;MyApp10LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels11", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels11 -> SETVAR;MyApp11LB;<Unused>||SetCommandLabels12
09-12-2011 00:01:21: Executing: SETVAR;MyApp11LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels12", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels12 -> SETVAR;MyApp12LB;<Unused>||SetCommandLabels13
09-12-2011 00:01:21: Executing: SETVAR;MyApp12LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels13", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels13 -> SETVAR;MyApp13LB;<Unused>||SetCommandLabels14
09-12-2011 00:01:21: Executing: SETVAR;MyApp13LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels14", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels14 -> SETVAR;MyApp14LB;<Unused>||SetCommandLabels15
09-12-2011 00:01:21: Executing: SETVAR;MyApp14LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels15", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels15 -> SETVAR;MyApp15LB;<Unused>||SetCommandLabels16
09-12-2011 00:01:21: Executing: SETVAR;MyApp15LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels16", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels16 -> SETVAR;MyApp16LB;<Unused>||SetCommandLabels17
09-12-2011 00:01:21: Executing: SETVAR;MyApp16LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels17", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels17 -> SETVAR;MyApp17LB;<Unused>||SetCommandLabels18
09-12-2011 00:01:21: Executing: SETVAR;MyApp17LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels18", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels18 -> SETVAR;MyApp18LB;<Unused>||SetCommandLabels19
09-12-2011 00:01:21: Executing: SETVAR;MyApp18LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels19", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels19 -> SETVAR;MyApp19LB;<Unused>||SetCommandLabels20
09-12-2011 00:01:21: Executing: SETVAR;MyApp19LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels20", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels20 -> SETVAR;MyApp20LB;<Unused>||SetCommandLabels21
09-12-2011 00:01:21: Executing: SETVAR;MyApp20LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels21", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels21 -> SETVAR;MyApp21LB;<Unused>||SetCommandLabels22
09-12-2011 00:01:21: Executing: SETVAR;MyApp21LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels22", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels22 -> SETVAR;MyApp22LB;<Unused>||SetCommandLabels23
09-12-2011 00:01:21: Executing: SETVAR;MyApp22LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels23", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels23 -> SETVAR;MyApp23LB;<Unused>||SetCommandLabels24
09-12-2011 00:01:21: Executing: SETVAR;MyApp23LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels24", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels24 -> SETVAR;MyApp24LB;<Unused>||SetCommandLabels25
09-12-2011 00:01:21: Executing: SETVAR;MyApp24LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels25", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels25 -> SETVAR;MyApp25LB;<Unused>||SetCommandLabels26
09-12-2011 00:01:21: Executing: SETVAR;MyApp25LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels26", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels26 -> SETVAR;MyApp26LB;<Unused>||SetCommandLabels27
09-12-2011 00:01:21: Executing: SETVAR;MyApp26LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels27", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels27 -> SETVAR;MyApp27LB;<Unused>||SetCommandLabels28
09-12-2011 00:01:21: Executing: SETVAR;MyApp27LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels28", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels28 -> SETVAR;MyApp28LB;<Unused>||SetCommandLabels29
09-12-2011 00:01:21: Executing: SETVAR;MyApp28LB;<Unused>
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels29", False
09-12-2011 00:01:21: EXECTBL Translation: SetCommandLabels29 -> SETVAR;MyApp29LB;USB I/O||SetCommandLabels30
09-12-2011 00:01:21: Executing: SETVAR;MyApp29LB;USB I/O
09-12-2011 00:01:21: Que Exec: True, menu.skin, "SetCommandLabels30", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels30 -> SETVAR;MyApp30LB;RRCleanScreen||SetCommandLabels31
09-12-2011 00:01:22: Executing: SETVAR;MyApp30LB;RRCleanScreen
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetCommandLabels31", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels31 -> SETVAR;MyApp31LB;Dimmer||SetCommandLabels32
09-12-2011 00:01:22: Executing: SETVAR;MyApp31LB;Dimmer
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetCommandLabels32", False
09-12-2011 00:01:22: EXECTBL Translation: SetCommandLabels32 -> SETVAR;MyApp32LB;BackGround
09-12-2011 00:01:22: Executing: SETVAR;MyApp32LB;BackGround
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SetAppLabels||$default$||1strun", False
09-12-2011 00:01:22: EXECTBL Translation: SetAppLabels -> SETVAR;ButtonLabel;=Musik<<=Radio<<=Video<<=Benzin Priser<<=Trafik Kamera<<=MobilTlf.<<=GPS<<=Dæktryk<<=Bak Kamera<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=USB I/O<<=RRCleanScreen<<=Dimmer<<=Background
09-12-2011 00:01:22: Executing: SETVAR;ButtonLabel;=Musik<<=Radio<<=Video<<=Benzin Priser<<=Trafik Kamera<<=MobilTlf.<<=GPS<<=Dæktryk<<=Bak Kamera<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=USB I/O<<=RRCleanScreen<<=Dimmer<<=Background
09-12-2011 00:01:22: Que Exec: True, menu.skin, "$default$||1strun", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "1strun", False
09-12-2011 00:01:22: EXECTBL Translation: 1strun -> BYVAR;1STRUN;NOTHING<<1strunon||SAVETOSKIN;1STRUN;0
09-12-2011 00:01:22: Executing: BYVAR;1STRUN;NOTHING<<1strunon
09-12-2011 00:01:22: Que Exec: True, menu.skin, "NOTHING", False
09-12-2011 00:01:22: Executing: NOTHING
09-12-2011 00:01:22: Command not executed: NOTHING
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
09-12-2011 00:01:22: Executing: ONCOMMANDINVALID
09-12-2011 00:01:22: Que Exec: True, menu.skin, "SAVETOSKIN;1STRUN;0", False
09-12-2011 00:01:22: Executing: SAVETOSKIN;1STRUN;0
09-12-2011 00:01:22: SAVETOINI: C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\skin.ini
09-12-2011 00:01:22: Que Exec: True, menu.skin, "MJSGIO_SETRELAY;1;1;1", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONMJSGIO_START", False
09-12-2011 00:01:22: EXECTBL Translation: ONMJSGIO_START -> MJSGIO_EVENTS;1;true
09-12-2011 00:01:22: Leave Exec: False, menu.skin, events;1;true, False
09-12-2011 00:01:22: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:22: Que Exec: True, menu.skin, "ONSONGSTART", False
09-12-2011 00:01:22: Leave Exec: False, menu.skin, ONSONGSTART, False
09-12-2011 00:01:23: Enter Exec: False, menu.skin, , False
09-12-2011 00:01:23: Que Exec: True, menu.skin, "ONMOBILEPHONENETAVAIL", False
09-12-2011 00:01:23: Executing: ONMOBILEPHONENETAVAIL
09-12-2011 00:01:23: Leave Exec: False, menu.skin, ONMOBILEPHONENETAVAIL, False
09-12-2011 00:01:23: Que Exec: True, menu.skin, "ONMOBILEPHONECONNECTED", False
09-12-2011 00:01:23: Executing: ONMOBILEPHONECONNECTED
09-12-2011 00:01:23: Leave Exec: False, menu.skin, ONMOBILEPHONECONNECTED, False
09-12-2011 00:02:14: Enter Exec: False, menu.skin, , False
09-12-2011 00:02:14: Que Exec: True, menu.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:14: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:14: Que Exec: True, menu.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:14: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:14: Leave Exec: False, menu.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:14: Enter Exec: False, menu.skin, "VOL-", True
09-12-2011 00:02:14: Que Exec: True, menu.skin, "VOL-", True
09-12-2011 00:02:14: Executing: VOL-
09-12-2011 00:02:14: Leave Exec: False, menu.skin, VOL-, True
09-12-2011 00:02:15: Executing: VOL-
09-12-2011 00:02:15: Leave Exec: False, menu.skin, VOL-, True
09-12-2011 00:02:15: Enter Exec: False, menu.skin, "ONBTNPRESS||VOL-", False
09-12-2011 00:02:15: Que Exec: True, menu.skin, "ONBTNPRESS||VOL-", False
09-12-2011 00:02:15: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:15: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:15: Que Exec: True, menu.skin, "VOL-", False
09-12-2011 00:02:15: Leave Exec: False, menu.skin, VOL-, False
09-12-2011 00:02:16: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:16: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:16: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:16: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:16: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:02:16: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:16: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:16: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:02:16: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:16: Executing: Menu;mobilephone.skin
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:19: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:02:19: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:19: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:19: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:19: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "SkinButton6", False
09-12-2011 00:02:19: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:19: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "MyApp06", False
09-12-2011 00:02:19: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:19: Executing: Menu;mobilephone.skin
09-12-2011 00:02:19: Que Exec: True, mobilephone.skin, "cancel||Menu;mobilephone.skin", False
09-12-2011 00:02:19: Executing: cancel
09-12-2011 00:02:19: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:02:19: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:19: Que Exec: True, menu.skin, "Menu;mobilephone.skin", False
09-12-2011 00:02:21: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:21: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:21: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:21: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:21: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:21: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:28: Enter Exec: False, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:02:28: Que Exec: True, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:02:28: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:28: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:28: Que Exec: True, mobilephone.skin, "EXIT", False
09-12-2011 00:02:28: Executing: EXIT
09-12-2011 00:02:28: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:02:28: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:28: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
09-12-2011 00:02:30: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:30: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:02:30: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:02:30: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:02:30: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:02:30: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:02:30: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:02:30: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:02:30: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:02:30: Executing: Menu;mobilephone.skin
09-12-2011 00:02:30: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:02:30: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:02:31: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:31: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:31: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:31: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:31: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:31: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:41: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:41: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:41: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:41: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:41: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:41: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:02:51: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:02:51: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:02:51: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:02:51: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:02:51: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:02:51: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:03:01: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:03:01: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png", False
09-12-2011 00:03:01: Executing: SETVAR;mobilephone_batterystrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_BATTERY_.png
09-12-2011 00:03:01: Que Exec: True, mobilephone.skin, "SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png", False
09-12-2011 00:03:01: Executing: SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png
09-12-2011 00:03:01: Leave Exec: False, mobilephone.skin, SETVAR;mobilephone_signalstrength;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Images\mobilephone\\MOBILEPHONE_SIGNAL_.png, False
09-12-2011 00:03:06: Enter Exec: False, mobilephone.skin, , False
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "ONMOBILEPHONERING", False
09-12-2011 00:03:06: Executing: ONMOBILEPHONERING
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "RADIOMUTE;ON", False
09-12-2011 00:03:06: Executing: RADIOMUTE;ON
09-12-2011 00:03:06: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:06: Executing: ONCOMMANDINVALID
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:06: Executing: MENU;MOBILECALL.SKIN;
09-12-2011 00:03:06: Que Exec: True, mobilephone.skin, "cancel||MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:06: Executing: cancel
09-12-2011 00:03:06: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:03:07: Enter Exec: True, menu.skin, , False
09-12-2011 00:03:07: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:07: Que Exec: True, menu.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Executing: MENU;MOBILECALL.SKIN;
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "ONMOBILEPHONERING", False
09-12-2011 00:03:07: Executing: ONMOBILEPHONERING
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Que Exec: True, mobilecall.skin, "cancel||MENU;MOBILECALL.SKIN;", False
09-12-2011 00:03:07: Executing: cancel
09-12-2011 00:03:07: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:03:08: Que Exec: True, mobilecall.skin, "ONSCREENCHANGE", False
09-12-2011 00:03:08: Leave Exec: False, mobilecall.skin, ONSCREENCHANGE, False
09-12-2011 00:03:12: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:12: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Executing: RADIOMUTE;ON
09-12-2011 00:03:12: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:12: Executing: ONCOMMANDINVALID
09-12-2011 00:03:12: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:12: Executing: WAIT;0.2
09-12-2011 00:03:12: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:13: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:13: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:13: Executing: ONCOMMANDINVALID
09-12-2011 00:03:13: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
ved MobilePhone.APIs.ReturnCallBacks(UInt16 levent)
ved MobilePhone.MobilePhone.get_Ringing()
ved MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm);5", False
09-12-2011 00:03:13: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:13: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:18: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
ved MobilePhone.RRExtension.ProcessCommand(String& CMD, Object& frm);5, False
09-12-2011 00:03:19: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:19: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: RADIOMUTE;ON
09-12-2011 00:03:19: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:19: Executing: ONCOMMANDINVALID
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: WAIT;0.2
09-12-2011 00:03:19: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:19: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:19: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:19: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:19: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:19: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:24: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:37: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:37: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:03:37: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:03:37: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: RADIOMUTE;ON
09-12-2011 00:03:38: Command not executed: RADIOMUTE;ON
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:03:38: Executing: ONCOMMANDINVALID
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: WAIT;0.2
09-12-2011 00:03:38: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:03:38: Executing: MOBILEPHONE_PICKUP
09-12-2011 00:03:38: Command not executed: MOBILEPHONE_PICKUP
09-12-2011 00:03:38: Que Exec: True, mobilecall.skin, "SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:38: Executing: SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:38: ErrorScr: Mobilephone.NET Exception System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:43: Leave Exec: False, mobilecall.skin, SetErrorScr;Mobilephone.NET;Exception;System.AccessViolationException: Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
09-12-2011 00:03:51: Enter Exec: False, mobilecall.skin, , False
09-12-2011 00:03:51: Que Exec: True, mobilecall.skin, "ONMOBILEPHONEDISCONNECTED", False
09-12-2011 00:03:51: Executing: ONMOBILEPHONEDISCONNECTED
09-12-2011 00:03:51: Leave Exec: False, mobilecall.skin, ONMOBILEPHONEDISCONNECTED, False
09-12-2011 00:04:08: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:08: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Executing: RADIOMUTE;ON
09-12-2011 00:04:08: Command not executed: RADIOMUTE;ON
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:08: Executing: ONCOMMANDINVALID
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Executing: WAIT;0.2
09-12-2011 00:04:08: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:08: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:04:08: Leave Exec: False, mobilecall.skin, MOBILEPHONE_PICKUP, False
09-12-2011 00:04:11: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "ONBTNPRESS||RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:11: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "RADIOMUTE;ON||WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Executing: RADIOMUTE;ON
09-12-2011 00:04:11: Command not executed: RADIOMUTE;ON
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:11: Executing: ONCOMMANDINVALID
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "WAIT;0.2||MOBILEPHONE_PICKUP", False
09-12-2011 00:04:11: Executing: WAIT;0.2
09-12-2011 00:04:11: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:11: Que Exec: True, mobilecall.skin, "MOBILEPHONE_PICKUP", False
09-12-2011 00:04:12: Leave Exec: False, mobilecall.skin, MOBILEPHONE_PICKUP, False
09-12-2011 00:04:17: Enter Exec: False, mobilecall.skin, "ONBTNPRESS||MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "ONBTNPRESS||MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:17: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "MOBILEPHONE_HANGUP||WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "WAIT;0.2||RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Executing: WAIT;0.2
09-12-2011 00:04:17: Enter Exec: True, mobilecall.skin, , False
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "RADIOMUTE;OFF||EXIT", False
09-12-2011 00:04:17: Executing: RADIOMUTE;OFF
09-12-2011 00:04:17: Command not executed: RADIOMUTE;OFF
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:17: Executing: ONCOMMANDINVALID
09-12-2011 00:04:17: Que Exec: True, mobilecall.skin, "EXIT", False
09-12-2011 00:04:17: Executing: EXIT
09-12-2011 00:04:17: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:18: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:18: Que Exec: True, menu.skin, "RADIOMUTE;OFF", False
09-12-2011 00:04:18: Executing: RADIOMUTE;OFF
09-12-2011 00:04:18: Command not executed: RADIOMUTE;OFF
09-12-2011 00:04:18: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
09-12-2011 00:04:18: Executing: ONCOMMANDINVALID
09-12-2011 00:04:18: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
09-12-2011 00:04:29: Enter Exec: False, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:04:29: Que Exec: True, menu.skin, "ONBTNPRESS||SkinButton6", False
09-12-2011 00:04:29: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:29: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:29: Que Exec: True, menu.skin, "SkinButton6", False
09-12-2011 00:04:29: EXECTBL Translation: SkinButton6 -> BYVAR;MAINBUTTON6;$AppToRun$
09-12-2011 00:04:29: Executing: BYVAR;MAINBUTTON6;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32
09-12-2011 00:04:29: Que Exec: True, menu.skin, "MyApp06", False
09-12-2011 00:04:29: EXECTBL Translation: MyApp06 -> Menu;mobilephone.skin
09-12-2011 00:04:29: Executing: Menu;mobilephone.skin
09-12-2011 00:04:29: Que Exec: True, mobilephone.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:29: Leave Exec: False, mobilephone.skin, ONSCREENCHANGE, False
09-12-2011 00:04:37: Enter Exec: False, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:04:37: Que Exec: True, mobilephone.skin, "ONBTNPRESS||EXIT", False
09-12-2011 00:04:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:37: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:37: Que Exec: True, mobilephone.skin, "EXIT", False
09-12-2011 00:04:37: Executing: EXIT
09-12-2011 00:04:37: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:37: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:37: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
09-12-2011 00:04:38: Enter Exec: False, menu.skin, "ONBTNPRESS||load;exit_menu.skin", False
09-12-2011 00:04:38: Que Exec: True, menu.skin, "ONBTNPRESS||load;exit_menu.skin", False
09-12-2011 00:04:38: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:38: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:38: Que Exec: True, menu.skin, "load;exit_menu.skin", False
09-12-2011 00:04:38: Executing: load;exit_menu.skin
09-12-2011 00:04:40: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
09-12-2011 00:04:40: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
09-12-2011 00:04:42: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "ONBTNPRESS||MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
09-12-2011 00:04:42: Executing: PlaySound;C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite_1\Sounds\button1.wav
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "MJSGIO_SETRELAY;1;1;0||QUIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "QUIT", False
09-12-2011 00:04:42: Executing: QUIT
09-12-2011 00:04:42: Enter Exec: False, exit_menu.skin, "ONEXIT", False
09-12-2011 00:04:42: Que Exec: True, exit_menu.skin, "ONEXIT", False
09-12-2011 00:04:42: Leave Exec: False, exit_menu.skin, ONEXIT, False
09-12-2011 00:04:42: Shutdown: (1)
09-12-2011 00:04:42: Shutdown: (2)
09-12-2011 00:04:42: CheckResume: ResumeMusic=2 WasRadio=0
09-12-2011 00:04:42: Shutdown: (3)
09-12-2011 00:04:42: Venice5---> RadioStop: Close()
09-12-2011 00:04:42: Venice5---> RadioActive: Active = false
09-12-2011 00:04:42: Venice5---> RadioMuteSet=True
09-12-2011 00:04:42: Venice5---> RadioActive: Active = false, RadioMuteSet(true)
09-12-2011 00:04:42: Shutdown: (4)
09-12-2011 00:04:44: Plugin Manager: Warning Plugin rrtms does not support Terminate Method
09-12-2011 00:04:44: Plugin Manager: Warning Plugin skintool does not support Terminate Method
09-12-2011 00:04:44: Plugin Manager: ALL Plugins unloaded.
09-12-2011 00:04:44: Shutdown: (5)
09-12-2011 00:04:44: Player is running
09-12-2011 00:04:44: Shutdown: (6)
09-12-2011 00:04:44: Shutdown: (7)
09-12-2011 00:04:44: OSUnloadMode: 1
09-12-2011 00:04:44: Global Hotkey: All keys unregistered
the above error looks the same if i try dial from rr or a try to pick up an incomming call
