Thread: .net Bluetooth Mobilephone Plugin
  1. #1261
    Jan 2006
    MAN, I just tried to get this going on my home pc running XP SP3 and BlueSoleil 6.4.240.2 and still get the same error. I really wanted to get this working.
  2. #1262
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Okay... you're not using the same downloaded file are you??
    Do you have any of the redist's installed when you try to install this? Which version of .net?
    * I may not know the answer, but hopefully these questions will help someone else help you.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  3. #1263
    Jan 2006
    Quote Originally Posted by sargeants View Post
    I believe I tried with the same downloaded file and then tried downloading again just incase it was corrupted and still got the same results. I have also tried with
    .Net 2.0 service pack 2
    .net 3.0 service pack 2
    .net 3.5 service pack 1
    .net 4 extended
    I would love to get this working
  4. #1264
    Jan 2006
    just tried this on my wife's laptop running Win 7 and started fresh. Installed latest RR and still got the same error about Dll not registering
  5. #1265
    Jan 2012
    UK
    I justed need to install thist on a machine as I need to get a command for a question, this machine did not have ride runner installed but I figured I would give it a try again I got the same error message as yourself about dll not registering and the install failed, but I also got a prompt about vc++ not being installed and pressed OK to install it. I tried again but this time I clicked cancel to the vc++ install message and the installer went stright through no errors. Very strange..
  6. #1266
    Jan 2012
    UK
    Want to ask a question about loading the phone book when the mobilephone.net.skin is loaded. So I want to run the "mobilephone_pc" command so it loads my phone book when the skin starts, is there any way of doing this?
    EDIT...
    found it just add ||command
  7. #1267
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hi lambospirit,
    In my last plugin RRGoogleMapsTools, i want to sent a phone number to your plugin .
    Can you say me how i can do that ?
    I had tried that:
    "mobilephone_dial;my number"
    but without success !
    Thanks !
  8. #1268
    May 2008
    Bordeaux, France
    No body can help me on this question please ?
  9. #1269
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by pierrotm777 View Post
    Hi lambospirit,
    I had tried that:
    Thanks !
    You have to send the number commands then the dial. So mobilephone_1 etc then mobilephone_dial
  10. #1270
    May 2008
    Bordeaux, France
    Quote Originally Posted by lambosprit View Post
    If i understand well, if my number is '0102030405' and must to do:
    mobilephone_0||mobilephone_1||mobilephone_0||mobil ephone_2||mobilephone_0||mobilephone_3||mobilephon e_4||mobilephone_0||mobilephone_5
    and after:
    mobilephone_dial ?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
