Page 128 of 134 FirstFirst ... 2878118119120121122123124125126127128129130131132133134 LastLast
Results 1,271 to 1,280 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #1271
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have found another method .
    I use your list and all is ok :-)
    Code:
                Case "gmaps_sendtomobilephone"
                    Dim PhoneNumber = Replace(SDK.GetInfo("=$PHONECLIP$"), ".", "")
                    If SDK.GetInd("pluginmgr;status;mobilephone") = "True" And SDK.GetInfo("=$PHONECLIP$") <> "*" And SDK.GetInfo("=$PHONECLIP$") <> "***" Then
                        SDK.Execute("LOAD;mobilephone.skin;Mobilephone.net;Mobilephone.NET")
                        SDK.Execute("CLCLEAR;ALL||CLADD;" & Replace(SDK.GetInfo("=$PHONECLIP$"), ".", "") & "||SETVAR;RRGoogleMapsToolsInfo;Ready for call the phone number '" & SDK.GetInfo("=$PHONECLIP$") & "'||menu;RRGoogleMapsTools_info.skin")
                    Else
                        SDK.Execute("SETVAR;RRGoogleMapsToolsInfo;You can't use this function !!!||menu;RRGoogleMapsTools_info.skin")
                    End If
                    ProcessCommand = 2
  2. #1272
    Feb 2011
    I've tested the plugin and is well working i have just a little problem of audio with the the first call (i've fixed it making a fake call to phone number and after some sec it hangup , when phone connect) but i would ask some questions:
    - The plugin uses a txt file as phonebook, is possible sync the file with the phonebook on the mobile? So when the mobile connect the phonebook on the carpc is the same as the one on the mobile
    - The only file txt that update is the MobilePhone_DC , while MobilePhone_MC and MobilePhone_RC are empty (i'm the onlyone with this problem?)
    - The sms functions works? I mean is possible to read the sms (incoming,sent,recived,archive) and send a new one?
    - Is possible to show the SIM list?
    I ask because i'm a little confused, i've read about other software but are outdated / dead / no-more supported but i find in skin commands:
    "SHOWINTERNALLIST" - Sets the Internal Phonebook in current skin's list
    "SHOWPHONELIST" - Sets the Phone's Phonebook in current skin's list
    "SHOWSIMLIST" - Sets the SIM Card's Phonebook in current skin's list
    "SHOWALLCALLS" - Sets the All Calls List in current skin's list
    "SHOWRECEIVEDCALLS" - Sets the Received Call's List in current skin's list
    "SHOWDIALEDCALLS" - Sets the Dialed Call's List in current skin's list
    "SHOWMISSEDCALLS" - Sets the Missed Call's List in current skin's list
    "SHOWRECEIVEDSMS" - Sets the Received SMS List in current skin's list
    "SHOWOUTGOINGSMS" - Sets the Outgoing SMS List in current skin's list
    "SHOWSENTSMS" - Sets the Sended SMS List in current skin's list
    "SHOWARCHIVEDSMS" - Sets the Archived SMS List in current skin's list
    So that's why i ask, thanks for have read
  3. #1273
  4. #1274
    Feb 2011
    ah so is from phonecontrol that is non usable as i've read, so this plugin in totally another thing
    And about the other questions i suppose it have the sms/sim support because i see on post #2 a pic of the vb source with buttons:
    sms read - sms send
    sim - missed - recived
    or maybe are just grapich buttons and function are not yet implemented
    Is this one the only working mobile plugin at moment right?
  5. #1275
  6. #1276
    Mar 2007
    I have been getting this error too. To get around it, hit cancel when it asks to install the vc runtime (assuming you've already installed it). The installer will then complete. However, once I then started up RR, it threw an error complaining that the .ini file wasn't to be found in Documents\RideRunner\Plugins\MobilePhone.NET. So, I copied the .ini file from ProgramFiles/RideRunner/etc there are started up RR. RR will load but then it quickly forcequits itself. Looking at the event viewer, I am getting the following:
    Faulting application name: RideRunner.exe, version: 1.0.0.0, time stamp: 0x4f776d4d
    Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b60
    Exception code: 0xc0000374
    Fault offset: 0x000c380b
    Faulting process id: 0xc9c
    Faulting application start time: 0x01cd14d381ce489e
    Faulting application path: C:\Program Files\RideRunner\RideRunner.exe
    Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
    Report Id: c60a398c-80c6-11e1-ab10-001bdc0f79e7
    I have also looked at the MobilephoneDebug.log and there is nothing out of the ordinary - the last entry is: "You have succeeded in getting a remote device's handle."
    I am running Windows 7 Professional x86, BlueSoleil 8.0.390.0, .NET 4, and VC++ 2010, and the April RR.
    Any ideas?
  7. #1277
    Jan 2006
    Ok finally got this installed but I'm getting the following error message when I click the "Add" button. I'm using the DFX5 skin. Also, I'm not really sure of the format for adding numbers and contact names to the MobilePhone_PC.txt. Any assistance is greatly appreciated
  8. #1278
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Yoy can't edit the file MobilePhone_PC.txt from within the skin.
    You need to edit the file manually with notepad, (Enforcer likes that)
  9. #1279
    Jan 2006
    Quote Originally Posted by MGD View Post
    what format? how would I add the number and name?
  10. #1280
    Jan 2006
    ok got it, now just need to set up the photos
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
