Hi all i have a little question, is possible to reload the plugin?
I ask because i've made a little way for pair the phone by manually type the bluetooth address inside roadrunner and save it in mobilephone.ini
and it works prefectly on the next start, so the plugin needs to re-read the config file and for do this the only way i see is use RELOADRR?
I would evitate to use RELOADRR since it crashes my rr with some random error (sometimes problems loading the silabs and sometime problem loading all the plugins)
Thanks![]()
Hi Lambo,
I wrote a BT mobilephone plugin for myself, but I have released the source code. It contains code that allows the phonebook to be downloaded from the phone. It also uses the BlueSoleil SDK.
Thread: http://www.mp3car.com/rr-plugins/154...ne-plugin.html
Cheers,
Asela
Fox Mulder
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
Hi Asela
Jut seen it and had a look. See your using the AT codes to down load the phonebook. I had a play with that but could never get it working. If I get the time I'll have another look using your ideas if you don't mind.
Well done on getting it to connect directly to the SDK. I tried for months and had to give up which is why the wrapper came into existance.
No worries, with the AT commands for the phonebook I decided to get each contact one by one and internally acknowledge that I got it. Otherwise if you try and grab say lots of 10 at a time I'm not sure why but the BlueSoleil buffer can't seem to handle it and you lose information. Doing it one at a time actually doesn't take that much longer and has a success rate of 100%.
Fox Mulder
2004 Toyota MR2
Hi,
Would it be possible at all If someone could tell me how to use this plugin. I mean I step by step guide.
Please.
hello folks. Im quite new to RR. couldnt get this plugin working, can you please help a bit?
my computer is win7 x64, installed the latest version of RR, installed BlueSoleil 8.0.395.0, could install another plugin (getting used to configuring RR), using the default skin.
when I run the installer for net bluetooth mobile, it warns me .net is not installed(actually it is installed), dll is not registered. I ignore and continiue the installation and then register the dll manually.
I had to copy few files from somewhere to another, renaming some jpg files to png files to get the plugin skin working. I succeded to some point but now Im stuck.
here is where I am now;
when I start RR, my computer connects to my phone automatically.
I can see that the phone is connected, on the skin "mobilephone_connected"
when I check the plugins interface on RR, plugin seem to be installed and enabled. (like post3 of this thread)
when I click the button I modified (menu3, button2), I see the mobilephone skin.
but none of the buttons on this window seems to function.
when I receive a call, mobile call skin pops up, but no caller id nor number, and I cannot answer or reject the call (again, buttons not functioning)
I dont see any battery or signal strength indicators.
I thought maybe its my lumia causing the mess, tried it with a 3110, result is very same.
I tried a fresh install and also another installation on virtual XP machine, but no luck...
Can someone tell me what am I missing to do?
edit: logs added
this is my last bswrapper log;
12/27/12 14:40:42 Info: Version 3.0.0
12/27/12 14:40:42 Info: Debug Level= 5
12/27/12 14:40:42 Info: Application initialised
12/27/12 14:40:42 Debug: Checking if currently connected to BlueSoleil Server.
12/27/12 14:40:42 Info: Not connected so initialising.
12/27/12 14:40:42 Info: Connected to BlueSoleil Server.
12/27/12 14:40:42 Debug: Looking for bluetooth adapter.
12/27/12 14:40:42 Debug: Bluetooth adapter found.
12/27/12 14:40:42 Info: Bluetooth hardware is ready.
12/27/12 14:40:42 Debug: You have succeeded in getting the phone's handle.
12/27/12 14:40:43 Debug: Event: 2359 not handled
12/27/12 14:40:43 Debug: ATcommand command: 20496.
12/27/12 14:40:43 Debug: ATcommand result: 255.
12/27/12 14:40:43 Debug: ATcommand command: 16401.
12/27/12 14:40:43 Debug: HF-->Cellular Network is available!
12/27/12 14:40:43 Info: Service found but needed connecting.
12/27/12 14:40:43 Info: Service connected
12/27/12 14:40:43 Debug: Requesting Network operator name
12/27/12 14:40:43 Debug: Signal strength.
12/27/12 14:40:43 Debug: Event: 2322 not handled
12/27/12 14:40:43 Debug: Battery charge.
12/27/12 14:40:43 Debug: ATcommand command: 30.
12/27/12 14:40:43 Debug: ATcommand result: 0.
12/27/12 14:40:43 Debug: ATcommand command: 36896.
12/27/12 14:40:43 Debug: HF connection is created
12/27/12 14:40:43 Debug: ACL link has been established, but SCO link has not been yet.
12/27/12 14:40:43 Debug: ATcommand command: 16403.
12/27/12 14:40:43 Debug: ATcommand command: 32769.
12/27/12 14:40:43 Debug: Network operator.
12/27/12 14:40:43 Debug: ATcommand command: 16385.
12/27/12 14:40:43 Debug: ATcommand command: 16387.
12/27/12 14:40:43 Debug: ATcommand result: 201.
12/27/12 14:40:43 Debug: Extend command is received
12/27/12 14:40:43 Debug: 12/27/12 14:40:43 Debug: ATcommand command: 16393.
12/27/12 14:40:43 Debug: 12/27/12 14:40:43 Debug: ATcommand command: 16394.
12/27/12 14:40:43 Debug: ATcommand command: 36868.
12/27/12 14:40:43 Debug: ATcommand command: 32770.
And mobilephonedebug;
27.12.2012 14:40:42:Info : Starting MobilePhone version:1.17.4070.39887
27.12.2012 14:40:42:Info : Current directory: C:\Program Files (x86)\RideRunner\Plugins\Mobilephone.NET
27.12.2012 14:40:42:Info : Current directory: D:\_Data LinkedToOS\Users\cK\Documents\RideRunner\Plugins\M obilePhone.Net\
27.12.2012 14:40:42:Info : Using BlueSoleil for phone connection
27.12.2012 14:40:42:Info : Device address: F4:8E:09:1C:45:7B
27.12.2012 14:40:42:Info : Pair code:
27.12.2012 14:40:42:Info : International prefix = 0090
27.12.2012 14:40:42:Info : National prefix = 0
27.12.2012 14:40:42:Info : International shortcut prefix = +90
27.12.2012 14:40:42:Info : MobileCall.skin: on
27.12.2012 14:40:42:Info : Trying to connect to phone.
27.12.2012 14:40:42:Info : Properties called
27.12.2012 14:40:43:Info : Wavein left as default
27.12.2012 14:40:43:Info : WaveOut left as default
27.12.2012 14:40:43:Info : You have succeeded in getting a remote device's handle.
27.12.2012 14:41:00:Info : Shutting down normally
never mind guys, with another computer xp sp3 installed, it works fine. thanks for this plugin lambosprit.
As a BS 6 or 8 owner you are eligible for a free upgrade to BS 10 , also the CPhone tool is free for BS 10 owners , so thats a double bonus, I installed both , and works niceley.
I havent had my phone connect in RR yet , but maybe on my next boot it will , if not I wil see if I can find out why.
View my worklog here
