Page 133 of 136 FirstFirst ... 3383123124125126127128129130131132133134135136 LastLast
Results 1,321 to 1,330 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1321
    Jun 2012
    Hi Guys
    I am trying to load the mobile phone app to no avail. I have included two screen shots of the install errors. I have also installed VC++Redist and Microsoft Net and the install will still not find VC++. I have also manually registered mobile phone.dll and it is comming up under plugins in Carwings. I think I have exhausted everthing That I can do so if one of you gurus could assist it would be gratly apprecieated.
    I am self taught with this stuff so I am not quite sure what you will need regarding system info
    Cheers
    Bernie
  2. #1322
    Jun 2012
    Sorry I forgot to ad the screen shots
    Name:  Carwings Plugin.JPG
Size:  106.3 KBName:  Carwings Plugin.JPG
  3. #1323
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I believe I mentioned this back a few pages/posts.
    Did you click OK or Cancel when it gives you the VCC installer error?
    If you clicked OK, that might be where your problem is. Try clicking cancel when it says it can't find it.
    Then see how it goes.
    Edit - for quotes of things to check
    Quote Originally Posted by sargeants View Post
    Choose not to install the vccredist - the install will likely finish and still work (provided you still have it installed through Windows update or manually)
    Currently this isn't installed as Profile Mode. See the second note in the first post.
    Move the mobilephone.ini from the install directory into the profile config directory and that should work... but if you're able to dial from RR then it's reading from the ini.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  4. #1324
    Jun 2012
    Thanks Mate
    This has been a very big learning curve for me I have read the preceeding posts but stuggled to get it right. It seems now that my phone is connected and I just thought i would try and ring another phone and bingo it did however no battery, signal or contacts are coming up now is there any easy to understand notes for dummies on this?
    Cheers
    Bernie
  5. #1325
    Oct 2008
    Ontario, Canada
    No Probs
    Battery and Signal are spotty at best. It really depends on the phone, and how BlueSoleil connects with it. I think I only had 1 phone show the signal properly once, and the other phones and times were either 5 or nothing - and the 5 would've been when I was actually about 2.
    Contacts are stored on the computer itself, and not pulled into RR. There is a contactlist that you can edit on the computer and then also create jpgs of the people and save those as the phone number.
    Then when they call, it will use the number as the index and show the name and picture.
    Not really the best - but it is what it is. I haven't used this in almost a year, so not remembering things or have it installed on my home/work machine anymore... not even sure it's in the car now.
    What phone do you have? There is a newer Android phone plugin out there that sounds good.
  6. #1326
    Jun 2012
    Thanks mate my phone is a I phone 3s can you tell me where the new android plugin is
    Cheers
    Bernie
  7. #1327
    Dec 2006
    istanbul
    while somebody is reading this thread recently, I have a problem.
    I installed this plug-in and after loads of suffering finally got it working on an aspireOne 1.6Ghz processor, 1Gb ram, 8Gb SSD, XP machine, BS8.0.395, and bmw e36 skin.
    My problem is related with the sound quality while talking on the phone thru my carpc. my voice goes blurry and I hear the other side blurry. I dont know how to describe the sound exactly, sorry about my lack of language skills. but I can say that I can hardly hear and same story on the other side of the phone.
    I tried 3 different bt adapters but no help.
    Can anybody help me get this handsfree function work as it should?
    PS. I can listen to mp3 files through BT clearly, this sound problem occurs only while making a phone call.
    PS2. My phone is a lumia800, and I tried with another mobile as well, same result.
  8. #1328
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by Bernie1 View Post
    The Android plugin is here - RRDroid [phone control for Android phones]
    But since you have an iphone, you might want to see what this one is all about - http://www.mp3car.com/rr-plugins/154...ne-plugin.html
    Quote Originally Posted by canstb View Post
    It seems like your issue isn't related to the BT since you can listen to MP3's by it. What microphone are you using in the car? Is it going through the computer's sound card, or do you have a USB soundcard and microphone like the Andrea SUMA? Do you have any noise cancelling? Have you trained Windows for the volume of the microphone? Is Windows set to listen to the microphone (if so turn it off - would likely cause feedback)?
    I found that when I was talking to someone with a Blackberry, the volume was rather low, but with someone else using an Android phone, the volume was much better.
  9. #1329
    Dec 2006
    istanbul
    I tested my carpc setup at home, and I was using the internal microphone of the pc. I also have a usb soundcard but I didnt try with it, since when I was using the eeePC, my previous carpc netbook, I had the exact same problem. I thought this was not a problem related with usb dongle, sound card or the microphone itself. Saying this, I must also say I dont have any noice cancelling hw or sw wise. and my sound problem doesnt feel like its a feedback issue.
    I didnt tune the microphone in windows, just set it to max setting for testing.
    funny thing is, its not only the other side hearing me with sound problems(which my microphone setup might cause), its also me hearing the other side "blurry". so I thought this is not only a microphone related issue.
    What else can I check?
  10. #1330
    Mar 2009
    put vcredist_x86.exe in sam directori of mobilpfone.net_setup
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
