Page 134 of 136 FirstFirst ... 3484124125126127128129130131132133134135136 LastLast
Results 1,331 to 1,340 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #1331
    Mar 2009
    dfx5
    .net Bluetooth Mobilephone Plugin error
    phonecontrol.net feature
    feature not installedd
    you are trying to use the phonecontrol.net feature which has not been installed
    please rerun the riderunner installer and select the phonecontrol.net option to use this feature
    with other skin is OK with DFX5 get errorName:  phone1.jpg
Size:  78.5 KBName:  phone.jpg
  2. #1332
    Dec 2006
    istanbul
    Quote Originally Posted by canstb View Post
    I tested my carpc setup at home, and I was using the internal microphone of the pc. I also have a usb soundcard but I didnt try with it, since when I was using the eeePC, my previous carpc netbook, I had the exact same problem. I thought this was not a problem related with usb dongle, sound card or the microphone itself. Saying this, I must also say I dont have any noice cancelling hw or sw wise. and my sound problem doesnt feel like its a feedback issue.
    I didnt tune the microphone in windows, just set it to max setting for testing.
    funny thing is, its not only the other side hearing me with sound problems(which my microphone setup might cause), its also me hearing the other side "blurry". so I thought this is not only a microphone related issue.
    What else can I check?
    solved!
    funnily, another very old bluetooth dongle worked like a charm... both sides voice is clear now.
  3. #1333
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    solved!
    Well there you go - glad it's working better for you.
    Quote Originally Posted by achillealb View Post
    dfx5
    Phonecontrol is really old... and don't think it will work at all.
    Mobilephone doesn't seem like it's properly installed. See previous posts about errors during the install. Did you move the ini into your profile directory rather than in the installed/plugin directory? Do you have your mac address properly setup in the ini?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  4. #1334
    Mar 2009
    solved thanks
    Quote Originally Posted by sargeants View Post
  5. #1335
    Jul 2013
    Österreich
    Hi!
    I have 2 questions/problem The plug in can't read my phone book and show the battery/network indicator. I have a Asus R2H UMPC whit Tohsiba BT and a Nokia N 97 mini mobile. The calls worked.
    Thanks the answers.
  6. #1336
    Jul 2013
    Österreich
    Hi!
    My question: how can i setup, that i see the incoming calls, the battery/network indicators and the plug-in read my phonebook? Now i can only numbers take in and call them. I hear the phone calls in the pc speaker. I have a N97 mini cell phone and my car pc is a Asus R2H whit Toshiba BT.
    Thanks the answers.
  7. #1337
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    Hello I have an issue that I am not sure of whether or not it is related to this plugin, when I am making a phonecall the volume of the person coming through my speakers is quite low, even if RR volume is set at levels unsafe for your ears.
    Now I tried the volume mixer in windows, to adapt the volume of the plugin (wich is visible, but if I raise the volume for the bluetooth application (how the phonecall is shown in win7) the master volume will raise as well, I have no idea how to make all that go separately or if the is a way to put higher volume levels in an ini somewhere.
    any thoughts are appreciated
    View my worklog here
  8. #1338
    Jun 2014
    Having trouble getting this to work the dll file wont register I tried with the car wings skin and I also tried with post 77 method(with post 77 method I get error "RA0000 the given paths format is not supported") any ideas?
  9. #1339
    aro
    aro is offline
    Feb 2011
    hi
    can you please tell me where can I download mobilephone plugin please help thank you
  10. #1340
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by aro View Post
    See the first post
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
