maybe this is my problem. Im gonna do a bunch of testing today
Thanks for this nice plugin. I just tested the plugin with iPhone. Connects fine, incoming call indicator works fine and plugin sends pause. Other functions like dial a number, answer or hangup a call does not work with iPhone. I have Bluesoleil Dialer plugin installed and works fine with dial/answer/hangup functions. I suppose your plugin has different method (AT commands maybe?) about that functions. (iPhone does not support AT commands AFAIK).
As mentioned before, I have also noticed that if you set AutoAnswer=0 in the configuration the mobilecall.skin does not load and plugin does not pause RR.
One suggestion, could you make the in call events configurable, like parameters in the ini file i.e. ringing="PAUSE" or hangup="PLAY"
Thanks again..
Live mp3Car Facebook Chat
My Work Thread:
http://www.mp3car.com/vbulletin/show-off-your-project/72552-mp3-project-for-land-cruiser-done.html
Source switcher for Lill
http://www.mp3car.com/vbulletin/show...d=1#post841007
Just tested with AutoAnswer=5... the box pops up... but the buttons dont accept/end the call. also it appeared that the MENU; command happened 2 or 3 times during the call as the box faded and came right back. I'm gonna test in the car with AutoAnswer = 0 and post results in about an hour.
Note this is with the previous version not the version just posted.
Ok tested in the car with 3 calls. First call had Autoanswer=10. moblecall.skin appeared the music paused AND the accept/end buttons did there job. Second call Autoanswer=0 was set and the popup didnt occur. Last call was a dialed call and the music paused.. but came back on during the call.
I'd say the conclusion is that Autoanswer = 0 means no popup at this point. There may also be a problem with pausing during a dialed call.
thanks for the testing. Found the bug and fixed it. It was stopping the auto pause and play stuff as well if auto answer was set to 0 so that should all be working fine now. I've updated the first post but kept the same version 1009 as only two people had downloaded
good stuff a new version
it makes me all warm and fuzzy in my pants LOL
what is the best thing to do
1 install over the top of old one
2 delete old files and install new one's
edit
just tryed it out all is good here
i can make a call
take a call auto answer works
it wants to pop up the mobilecall.skin but i dont have in the folder. so rr tells me it cant find it
but i still cant get the phone book to display
the files location is C:\Program Files\RideRunner\Plugins\MobilePhone
and in the mobilephone settings i have
# Path to where the phonebook files should be stored. Leaving blank will save them to RoadRunner folder.
PhonebookPath=C:\Program Files\RideRunner\Plugins\MobilePhone\
all the skins are standed as the came with the plugin
where the am i going wrong with this part
can someone please give me a idiots guide to setting this up
