Page 15 of 126 FirstFirst ... 567891011121314151617181920212223242565115 ... LastLast
Results 141 to 150 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #141
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    What happend with 1009? Dialed and received not work also MobilePhone_PC stops working
    Edit: My mistage, dialed and received working. Where it stored phone numbers now because those are not in MobilePhone_PC??? Now I can add numbers but can't add names because MobilePhone_PC doesn't work anymore.
    Edit2: Ok I found stored numbers but some how it save MobilePhone_PC, MobilePhone_DC and MobilePhone_RC to D:\ ??? In ini file I have:
    # Path to where the phonebook files should be stored. Leaving blank will save them to RoadRunner folder.Must add a \ at end.
    Path=D:\Programs\RoadRunner\Plugins\MobilePhone\
    Dialed and received show in RR only Unknown when MobilePhone_DC and MobilePhone_RC files shows LSTxxxxxxxxxx||Unknown
  2. #142
    lambosprit's Avatar
    Sep 2006
    UK
    Dartman_71. I changed the ini file so it looks for PhonebookPath rather than just Path.
    vtcom. Did you look to see if the phonebook has been created? It should be in the path that you set. It may be the skin not working.
    to all. So autoanswer=0 and pause / play is now working ok?
  3. #143
    Feb 2009
    Finland
    Quote Originally Posted by lambosprit View Post
    Thank's, PhonebookPath did the trick and now it works.
    If autoanswer is on or off pause / play working ok when answer call, BUT when you make call it doesn't work at all!
  4. #144
    lambosprit's Avatar
    Sep 2006
    UK
    are you making a call with mobilephone_dial or mobilephone_pickup?
  5. #145
    Feb 2008
    yep the file is there i can open it and and all is as it should be
    it just dont come up in the skin
    the skin is as it came im the zip file is there any thing that needs to be changed in there for it to work
  6. #146
    Feb 2009
    Finland
    With mobilephone_pickup and mobilephone_dial doesn't work either.
    Edit: It does try to pause but starts playing after 1 sec.
  7. #147
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by vtcom View Post
    ok. I think thats because the skin uses a custom list and not sure if I updated the plugin to load the custom list , I will check.
  8. #148
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    ok. Gives me some ideas. Will have a look later today.
  9. #149
    lambosprit's Avatar
    Sep 2006
    UK
    vtcom. Please try this.
    manually edit the mobilephone_DC.txt or RC.txt file to add two blank lines at the beginning of the file. For some reason it looks like a custom list has to have a couple of blank lines at the beginning to load it up.
  10. #150
    Feb 2009
    Finland
    This may be stupid question but did you click PC button?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
