Page 19 of 126 FirstFirst ... 9101112131415161718192021222324252627282969119 ... LastLast
Results 181 to 190 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #181
    lambosprit's Avatar
    Sep 2006
    UK
    This plugin doesn't support contacts or sms for any phone YET. I've implemented a temporary measure where you can store contacts in the mobilephone_pc file and it will display them but it doesn't sync with the phone YET. It is top of my list of things though.
  2. #182
    Feb 2006
    How is it determined if a plugin shows in the plugin manager or not? My skin DigitalFX has a plugin manager and there are many plugins that do not show there. MobilePhone is one of them. Any Ideas?
  3. #183
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Thank you lambo for excellent working again, when you fix mute in call it's more than I can hope for From now on everything you do is luxury, keep on
  4. #184
    Feb 2009
    Finland
    Quote Originally Posted by EricE View Post
    Did you try Carwings Dynamic if it shows there then something wrong in DigitalFX skin, if not you did not register mobilephone.dll correctly.
  5. #185
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    The Pluging manager in DFX is old. Call it an early beta, and the first step in managing plugins in a skin, and not having to use the x, lines in the menu.skin. It does not work directly with the plugins as the new version, that comes with the carwings skin. It is something I plan to add to a future version of the DFX skin, I am just not sure when, as I have had so much going on here lately, that development of the skin has been on the far back burner for now.
    My Fiero Build Thread
  6. #186
    Jul 2006
    Quote Originally Posted by JohnWPB View Post
    So do the users of DFX need to use the carwings to enable the plugin, and then it will work in any skin?
  7. #187
    Feb 2009
    Finland
    Quote Originally Posted by LYHTSPD View Post
    To enable plugin you need to add X,mobilephone to menu skin and it works any skin you want.
  8. #188
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    true but if your using ride runner you just put it in the plugins directory and register it there then it can be used for any skin even ones you add later.
    the x,mobilephone is how road runner did it, it still works but means you have to add it to every skin.
    no. Carwings will show you if its registered correctly. thats all.
  9. #189
    Mar 2009
    Chaps.....I've had a read throught this thread....and I'm sure what isn't happening is because of my noobishness.
    I'm moving over fron CF2 to RR and I'm setting up RR on a seperate computer, one of the things that was stopping me from using RR earlier was the lack of half decent phone support.....so......
    I have the latest version of RideRunner installed......all good
    I have Bluesoleil 6.4.249(full) installed.....all good
    I have so far just stuck with the carwings skin to get things working
    I ran the VCREDIST file first....all good
    I ran the installer and point firstly to the RR root folder, then to the carwings skin folder and OK'ed........all good so far
    BUT in the plugins manager mobilephone isn't in there and in the debug it has a line that says " plugin found but will be unable to create (most likely NOT registered)
    so I'm guessing that it is not registered??? but how do I get it registered?
    Also MobilePhone is showing in the plugins folder and the skin elements are in the carwings skin folder
    cheers for helping out somebody who was too used to the easyness of CF2....BUT I'm trying to learn !!
  10. #190
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by lewisdg View Post
    try post 77 of this thread. You need to register with /codebase
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
