Page 2 of 126 FirstFirst 12345678910111252102 ... LastLast
Results 11 to 20 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #11
    Low Bitrate SoulR's Avatar
    Aug 2007
    Awesome work lambosprit, will have to try this once i get my act together.
  2. #12
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    This sounds great!
    Is there a way to run this standalone?
    Tried to run the setup but it requires a valid RR directory.
  3. #13
    lambosprit's Avatar
    Sep 2006
    UK
    It needs RR to run because all the control inputs are through RR. It might be possible to make it standalone but what would the inputs be?
  4. #14
    Sep 2005
    Stockholm, Sweden
    Well, FreePhone had an early version that worked stand alone. That is, it looked as being inside rr with skin and all, but run without having RR acctually installed.
    I don't know how much work it is, but since I am not running RR...
  5. #15
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I havent been able to get this to work.
    THis is the copy of the debug when loading from menu.skin
    2/22/2009 2:36:45 PM: Plugin Manager: Error loading (menu.skin): mobilephone(ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
    THis is the copy of the debug when loading from plugin manager
    2/22/2009 2:36:44 PM: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    Here is a copy of the registration from command prompt
    C:\Program Files\RideRunner\Plugins\MobilePhone>regasm.exe MobilePhone.dll /tlb:
    MobilePhone.tlb
    Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.42
    Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
    Types registered successfully
    Assembly exported to 'C:\Program Files\RideRunner\Plugins\MobilePhone\MobilePhon
    e.tlb', and the type library was registered successfully
    C:\Program Files\RideRunner\Plugins\MobilePhone>pause
    Press any key to continue . . .
    SO it is registered successfully, but still cant get RR to load it.
    Any thoughts..
    New Age Garmin - Skin for RR
  6. #16
    Aug 2006
    West Allis, WI
    Freefone sucked because it as an external standalone (sorry). I would recommend keeping this a plugin so we can create some suitable looking skins.
  7. #17
    Sep 2005
    Stockholm, Sweden
    Best thing is a skinnable application. If you want to play with words :-)
  8. #18
    lambosprit's Avatar
    Sep 2006
    UK
    Sorry no plans at the moment to make it stand alone. Lots still to do to make it a finished dll first.
    Thunderstick: Pm'd you with an idea how to fix your problem but would like it tried before posting
  9. #19
    Aug 2006
    West Allis, WI
    OK I get it to register not sure what happened differently but I just registered again as I have been and it works.
    some what anyway.
    Here is a screenshot of what I get when I open the skin.
    I get one green light, not sure what it means and a few labels that say false.
    Anyway, not able to use the phone through BT yet. Any more ideas?
  10. #20
    Aug 2006
    West Allis, WI
    Quote Originally Posted by bes51659 View Post
    sorry still believe a plugin is the way to go. I can display phone info on any screen then and create buttons on any screen to interact with the phone plugin.
    External app, no can do.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
