Page 23 of 134 FirstFirst ... 13141516171819202122232425262728293031323373123 ... LastLast
Results 221 to 230 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #221
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    Yes and lambo knows it, I hope he fix it soon.
    I knew you where having the problem but I can't track it down. It works fine for me .
    What skin are you both using. I'm wondering whether its being changed back to play outside of the plugin.
  2. #222
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by lambosprit View Post
    Hey Lambo,
    I am using this skin:
    http://www.mp3car.com/vbulletin/rr-s...-released.html
    Its not a big deal for me as i will pause the music before i make a call, but would be nice to get this working.
  3. #223
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I use Robby's BMW E36 skin. I have change button, indicator and list commands to phoco, calls and contacts skins to work with your plugin, phoco is now mobilephone skin of course. If I remember correct, pause on call works in earlyer releases but not in last two or three.
    Edit: I remember wrong pause doesn't work with any versions. I also tried BMV2 skin with your mobilephone skin and it doesn't work either.
  4. #224
    Feb 2009
    Finland
    Stop the press! I just discover something, in this part of mobilephone ini:
    [PHONESTATUS]
    # How often is battery and signal updated in milli seconds.
    #Also checks for connection or not and whether ringing to auto answer.
    Update=10000
    I change updating to 100000 and pause hold about 2min and then it start to play music again.
    Can you TeamRSX confirm this?
  5. #225
    lambosprit's Avatar
    Sep 2006
    UK
    thanks dartman. Got the problem sussed. All fixed. Won't release it until I have done more stuff though.
  6. #226
    Feb 2006
    One thing that would solve the echo is to not use your car speakers for the sound. I never wanted the integration with the car other than to pause/resume my music so I set it up so I can use my earpiece. My iPhone wont talk to both the computer (through BlueSoleil) and my earpiece at the same time so my mobilecall.skin has a button that disables the mobilephone plugin and another that resumes play, enables the plugin and closes the form. This way when a call comes in I have the option to disable the mobilephone plugin so I can use my earpiece or just take the call on my phone. I haven’t used it enough to confirm that this works really well yet. I need to test some more.
  7. #227
    Jul 2006
    Quote Originally Posted by EricE View Post
    This is almost exactly what I want to do with the plugin. Use my BT headset for communication, and this plugin mainly for caller-id functions. How long of a delay is there from when you disable the plugin to when your BT headset syncs back up to the phone?
    lambo: can there be an option in the plugin to only use it as a caller id, or is this just something that the end user will need to work around?
  8. #228
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    2nd'd.
    I'm using MyMobiler to display my high res phones output and then its embedded in RR and the audio is solved via my BT stack but i need a background app to look for AT commands for incoming calls and stuff and then execute RR commands.
    Its along similar lines as the above post,can it be done with this app?
    I've seen the BT Caller ID Thread,i'm looking into that as an option too if the Dev wants to play.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  9. #229
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    seems many share my request for disabling integrated audio and use of a BT piece
  10. #230
    Feb 2006
    Quote Originally Posted by LYHTSPD View Post
    I hadn't tested it before but I just did.
    The earpiece syncs almost immediatly. The problem is that the mobilephone plugin keeps reconnecting...and as I write this I now know why. There is a reconnect option in the INI. I'll have to change that. More testing needed.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
