Page 24 of 134 FirstFirst ... 14151617181920212223242526272829303132333474124 ... LastLast
Results 231 to 240 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #231
    Feb 2006
    Request: can you make AutoReconnect a command that I can turn on and off?
    I tried turning AutoReconnect off so I could disable the plugin during a call in order to get my earpiece working but once I do that the plugin doesn't start on resume or on RR start. Admitedly I could find the right places to add the moblilecall_connect command to fix both of those but the cleanest way to do it is to just be able to turn AutoReconnect on and off.
    Again, thanks for doing this. I am pretty happy with what we have so far.
  2. #232
    lambosprit's Avatar
    Sep 2006
    UK
    How about I change moblilecall_connect / disconnect so they switch on/off autoconnect if its set to true.
    so you use moblilecall_disconnect and it disables autoconnect if on and moblilecall_connect re-enables it if it was on.
  3. #233
    Feb 2006
    Quote Originally Posted by lambosprit View Post
    Yes, thats perfect.
  4. #234
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    lambo, are you sure that in sdk or api doesn't have possibility to change audio between phone and pc? In BlueSoleil Dialer have this option.
    Edit. Ok it doesn't solve proplem if you wanna use bt headset But this could be useful option anyway.
  5. #235
    Feb 2009
    Could anyone tell me how to add the icon from plugin manager to my skin? I may sound really stupid but I cant understand
  6. #236
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dartman_71 View Post
    I'm still working on it. Haven't found the answer yet but dont give up hope yet.
    @danchappers
    not sure what your asking. Whats a plugin manager icon? I saw your post about skinning in lsxvoid. I dont have a skin for that, maybe someelse has done one. There are two supplied with the install. One is the BMV2 one and the other is lucifers. You can use either I assume in lsxvoid they just wont look nice....but they'll work until you make your own or the skin developer releases one.
  7. #237
    Feb 2009
    ok I've gone back to Carwings_Dynamic theme and there is a plugin manager on there, however the phone icon doesnt show for me to be able to use, I'm assumin I need to edit something to get this to show?
    cheers
  8. #238
    lambosprit's Avatar
    Sep 2006
    UK
    ahh. I think I understand now. You mean the phone button on the menu options. I have also found this and have not managed to find out how it decides to display it. Sorry I cant be more help. Maybe post an issue in the skin forum.
  9. #239
    lambosprit's Avatar
    Sep 2006
    UK
    sussed it. I had another look and you need to do the following
    1) make sure you install the skin files to the carwings folder.
    2)edit the app_chooser.skin file and remove the ,Atrist.bmp,Music.bmp from the third line
    3)open the exectbl.ini file in the carwings folder (not the one in rr folder) and look for "MyApp07", line 84 in the file. Change it to show "MyApp07","LOAD;mobilephone.skin;"
    4) open carwings and select the button you want the phone to be on. Keep it pressed down until the app_chooser skin opens and select phone from the list.
    thats it. Hope it works.
  10. #240
    Feb 2009
    Great that shows the dialer etc now.. so close ok do I need to configure it for my phone somehow? I've had a quick read but no luck
    cheers
    (sorry for all the noob questions)
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
