Page 25 of 134 FirstFirst ... 15161718192021222324252627282930313233343575125 ... LastLast
Results 241 to 250 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #241
    lambosprit's Avatar
    Sep 2006
    UK
    that depends. I'm assuming you've got bluesoliel installed.
    Have you paired your phone? Have you changed the mac address in the ini file (you get this from the bluesoliel classic view if you hover over your phone.
    Do you have any valid text in the top left of the screenshot? Does it look like the screenshot in post 3?
  2. #242
    Feb 2009
    Quote Originally Posted by lambosprit View Post
    Hey lambosprit,
    Yes Bluesoleil is installed and up to date.. yes I have changed the mac address in the ini file, however when I load up the app i get the following:
  3. #243
    lambosprit's Avatar
    Sep 2006
    UK
    you didn't say whether you had paired your phone.
  4. #244
    Feb 2009
    sorry, yes the phone has been paired up in bluesoleil, and I am able to call from it etc.
    cheers
  5. #245
    Low Bitrate sviyer's Avatar
    Oct 2006
    @ lambo, thank you for the wonderfull plugin, it is working great.
    I have an issue , when there is incoming call, the incoming no. is shown correctly. But , after 2 rings, there is an error shown in riderunner which says, mobilecall.skin not available.
    I have searched the carwings folder ( that's the skin i am using), but i can't find the mobilecall.skin !
    pls help
    Thanks and regards
    Honda City
  6. #246
    Feb 2009
    right ok ive managed to get it to dial now, seems to have been an issue with my pairing, just restarted and all seems to be fine next up is getting it to fit into a skin then, what skins are people using with this?
    cheers
  7. #247
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by sviyer View Post
    pls help
    Thanks and regards
    When an incomming call is received in RR it looks for mobilecall.skin. I have this just as a popup with the incomming call indicator, caller id and if i want to take the call, hang up or ignore.
    For now you can use the same skin as the mobilephone.skin and just copy that and rename it mobilecall.skin for now to see if it works. Then you can skin it the way you like..
  8. #248
  9. #249
    May 2009
    i am using digitalfx 4.0
    how to make the mobile phone button appear on the screen.
  10. #250
    lambosprit's Avatar
    Sep 2006
    UK
    JohnWPB was looking into using this plugin but he was travelling. Hopefully he'll be implementing it in his skin soon. May be worth asking the question in the dfx thread.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
