Page 27 of 136 FirstFirst ... 17181920212223242526272829303132333435363777127 ... LastLast
Results 261 to 270 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #261
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Im not getting anything either after upgrading to the new version. Older version worked pretty good as far as connecting went.
    New Age Garmin - Skin for RR
  2. #262
    Aug 2006
    West Allis, WI
    Older version meaning version 1.0.0.11
  3. #263
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    New 1.12 plugin works fine here, thank's lambo.
    Few tips:
    Make sure your settings are correct in ini file.
    If your phone skin is splitted two or three skin, every skin name should be named mobilephone_XXXXXXXXX.skin
  4. #264
    lambosprit's Avatar
    Sep 2006
    UK
    @Junhe and thunderstick. If the skin is blank like that then the dll is not registered. Check in carwings plugin manager. If not try manually registering as before i.e. post 77. The installer should have registered it automatically but maybe something went wrong
  5. #265
    Feb 2006
    thanks for the latest version. I haven't tried it yet but I assume all will go well.
    My only advice is to add to the "trouble shooting" section of your readme. What should go there is the steps to manually register the dll. Digging for post #77 is not all that fun time after time.
  6. #266
    Feb 2006
    From the readme:
    mobilephone_incall | Y | Y | TRUE/FALSE | Shows if currently making a call.
    I beleive you have made this so it is true if you are currently in a call (however you got there).
  7. #267
    lambosprit's Avatar
    Sep 2006
    UK
    true. I will change the readme....nice to see someones reading it
  8. #268
    Constant Bitrate almera's Avatar
    Aug 2004
    Quote Originally Posted by lambosprit View Post
    What skin are you using? Can you send me a copy of the skin file if its not one of mine. I've double checked here and it all works for me. Have you checked the debug log for any info?
    Your BMV2 skin does not work for me. Problem for me; your button commands, labels etc all uppercase. I had to change all of them to lowercase. And also I had to change the sc definition line to get the custom list work. (I'm using the latest version of RideRunner):
    sc01,102,155,399,226,0,0,0,1,25,25,0,0,0,255,128,0 ,true,14,"arial"
    here is the debug file;
    Starting MobilePhone version: 1.12.3434.20297
    Current directory: C:\Program Files\RideRunner\Plugins\MobilePhone.NET
    Path being set to C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32 \Wbem;C:\Program Files\IVT Corporation\BlueSoleil\Mobile;C:\WINDOWS\system32\ Wbem;C:\Program Files\RideRunner\Plugins\MobilePhone.NET
    Device address: H0:82:K1:2D:0Y:48
    Pair code:
    International prefix = 0044
    International shortcut prefix = +44
    National prefix = 0
    Using BlueSoleil for phone connection
    MobileCall.skin: on
    Trying to connect to phone.
    Updating phoneHandle to : 25972616
    Device handle found is: 25972616
    You have succeeded in getting a remote device's handle.
    Shutting down normally
    thanks
  9. #269
    Jul 2006
    Brisbane, Australia
    Quote Originally Posted by almera View Post
    Would you be able to zip up and attach the revised BMV2 skin files? I just started on this myself
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  10. #270
    Aug 2004
    Quote Originally Posted by rodweb View Post
    Sure, here you go;
    Attached Files Attached Files
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
