paired,mac address correct, connected(the bluesoliel icon is become green)
this is my log
5/29/2009 8:41:43 PM:Info : Starting MobilePhone version: 0.1.0.10
5/29/2009 8:41:43 PM:Info : Current directory: c:\program files\riderunner\plugins\mobilephone
5/29/2009 8:41:43 PMebug : Path being set to C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\IVT Corporation\BlueSoleil\Mobile;C:\WINDOWS\system32\Wbem;C:\Program Files\StormII\Codec;C:\Program Files\StormII;c:\program files\riderunner\plugins\mobilephone
5/29/2009 8:41:43 PM:Info : Device address: 00:237:06
A:61;
5/29/2009 8:41:43 PM:Info : Pair code: 1234
5/29/2009 8:41:43 PM:Info : International prefix = 0044
5/29/2009 8:41:43 PM:Info : International shortcut prefix = +44
5/29/2009 8:41:43 PM:Info : National prefix = 0
5/29/2009 8:41:43 PM:Info : Using BlueSoleil for phone connection
5/29/2009 8:41:43 PM:Info : MobileCall.skin: on
5/29/2009 8:41:43 PM:Info : Trying to connect to phone.
5/29/2009 8:41:46 PMebug : Updating phoneHandle to : 29591712
5/29/2009 8:41:46 PMebug : Device handle found is: 29591712
5/29/2009 8:41:46 PM:Info : You have succeeded in getting a remote device's handle.
5/29/2009 8:41:54 PM:Info : Phonebook functionality not part of current SDK
I'll check that later..
Also, I'll check that later and let you know.
No problem in getting the custom list box to populate. I can see the list and browse the list succesfully. Problem is the custom list doesn't populate the mobilephone_dialbox. Otherwise if I dial a number using the dial pad, plugin works fine.
Hi Guys, finally took the plunge with this. Tried my work Nokia 3120c but it was not on the supported phone list so BS had trouble with this so used a Sony Erricssen W610i. I am using the BMV2 skin.
It connects, I can dial and receive calls but I get an error screen "MobilePhone.Skin not found."
I could not see any ini file settings to tell it where to look for the skin. Does it pickup the skin folder from RR?
Once I get that sorted, I need to work out why contacts etc don't show up. BS can see them.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
New Age Garmin - Skin for RR
Above post edited for corrections
it works OK for me.
if you guys are having probems (the pluging no registering) try to completely uninstall the plugin -there is an undelete exe- and reinstall
lambo is there any news on having the Bluetooth connection not connecting the audio so we can use a handsfree BT?
