Lambospirit can you tell me how to get rid of the skin not found error?. I am using the BMV2 skin but it is in a different folder name. Would that make a difference?
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
I think its a problem with the lowercase again. To update the dial box i send an onclclick which is in capitals. This I guess is why anyway. I can send you a special debug version which would write out what its being sent and processing. PM me with an email address I can send it to. Knowing the answers to the other questions may help solve this one.
Your quick. I was just going through each message.
There is two ways. The mobilecall skin is just called using a MENU;MOBILECALL.SKIN; call to RideRunner. This means its looking for the skin file in your current skin. So you could add one of the mobilecall.skin files I added to the installer or if you dont want mobilecall.skin to be called at all you can set the mobilecall parameter in your ini file to off. BEWARE though that you will have to detect any incomming call yourself and load your own skin because this setting stops the plugin doing it for you.
Your other point about contacts is that currently the plugin doesn't load contacts from your phone. Its possible to read caller names from the mobilephone_pc.txt file but this must be manually edited by you first. version 2 will have contacts but you'll have to be patient![]()
I bought myself a handsfree microphone to try to sort it but my bluesoliel doesn't recognise it so kind of stopped there what with everything else going on. It is on my list still though so please be patient. Just a question though. are you wanting the microphone to connect to bluesoliel or just to the phone? I assume you just want the computer to control whether you answer/make calls etc and just want the audio to be direct phone to mic.
RodW
EDIT: Sorry about the duplicate. Bad gremlins at the keyboard!
RodW
Just had a check of the installer and it doesn't have a mobilecall.skin for the bmv2 and carwings opps....As a test you could copy the freedom ultimate one as long as you have flash installed. I'll have a look at making one for the next release. To make one yourself you could use this screen shot and the mobilecall.skin from ultimate
Well I am out of time now, but I might have a go at this later as I have got Photoshop and the BMV2 .PSD's here. It would help enormously if you could list the skin commands that would need to be supported for mobilecall.skin
I had thought of redoing your graphics to match BMV2 if I can get this working for me which I would be happy to contribute.
RodW
