this is my bswrapper...
BSWrapper.txt
BSWrapper.txt
I've tested some other plugins / skins about lowercase situation but only having the problem with just mobilephone.NET
Also checked The BSWrapper file, works ok, write logs out to RR directory only.
PM sent. Thanks again.
Make sure that this is correct in the MobilePhone.ini file
PhoneLink=Blue
New Age Garmin - Skin for RR
OK, I now have Mobile Phone working great in my skin. The only thing I ask now is that there be a pause or a wait until BlueSoliel is finished loading.
When I first boot up my PC it RR freezes for a while then Mobile dumps out a long error message. This only happens on initial boot. If I close RR after everything is started up and running then restart RR, I get no error messages. I am relating this to the fact the BS takes a while to find and connect to the phone.
This is little old news but BlueSoleil 6.4.261.0 is released 2009-5-21.
There is also very good news, quote from CF forums:
Next Bluetooth Stack Update: Q3 IVT releases will include integrated contact/phonebook support and sms support. As well, integrated software Echo Cancellation / Noise reduction is also currently being worked on and will be available soon.
