Page 36 of 126 FirstFirst ... 26272829303132333435363738394041424344454686 ... LastLast
Results 351 to 360 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #351
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    Hello! this program is Windows Vista 64 compatible?
    I have the problem that com port is always COM7, i dont use COM PORT, i have iphone over bluetooth.
    but i change and change again and again the COM7, i try put COM9, or COM1, or any!! and all time my log say that is try to conect for COM7.
    i edit the mobilphone.ini but again COM7 is all time there.
    This is the log:
    05/07/2009 06:00:15 a.m.:Info : Starting MobilePhone version: 1.12.3434.20297
    05/07/2009 06:00:15 a.m.:Info : Current directory: C:\RideRunner\plugins\Mobilephone.NET
    05/07/2009 06:00:15 a.m.:Info : Device address: 00:23:127:AA:BE
    05/07/2009 06:00:15 a.m.:Info : Pair code:
    05/07/2009 06:00:15 a.m.:Info : International prefix = 0044
    05/07/2009 06:00:15 a.m.:Info : International shortcut prefix = +44
    05/07/2009 06:00:15 a.m.:Info : National prefix = 0
    05/07/2009 06:00:15 a.m.:Info : Using ATSMS for phone connection
    05/07/2009 06:00:15 a.m.:Info : MobileCall.skin: on
    05/07/2009 06:00:15 a.m.:Info : Trying to connect to phone.
    05/07/2009 06:00:15 a.m.:Info : Com port set to COM7
    05/07/2009 06:00:15 a.m.:Info : BaudRate set to 115200
    05/07/2009 06:00:15 a.m.:Info : DataBits set to 8
    05/07/2009 06:00:15 a.m.:Info : StopBit set to 1
    05/07/2009 06:00:15 a.m.:Info : FlowControl set to None
    05/07/2009 06:00:15 a.m.:Fatal : Failed to connect to phone.ATSMS.ConnectionException: El nombre de puerto proporcionado no empieza por COM o com, o no se resuelve en un puerto serie válido.
    Nombre del parámetro: portName ---> System.ArgumentException: El nombre de puerto proporcionado no empieza por COM o com, o no se resuelve en un puerto serie válido.
    en System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
    en System.IO.Ports.SerialPort.Open()
    en ATSMS.Modem.Connect()
    --- Fin del seguimiento de la pila de la excepción interna ---
    en MobilePhone.MobilePhone.internal_connect()
    any ideas???
  2. #352
    Aug 2004
    It's funny cuz I'm trying to get this to work on my desktop before I send it out to the car and I'm having the exact same problem, cept I'm using xp. I change the com port to com8 in the mobilephone.ini but the skin still shows 3 red lights.
    I check the debug log and It always says "Com port set to COM7" the baud rate (whatever that is) also differs from the .ini.
    BTW, what com port should it be set to anyway? My Bluesoleil device properties shows my phone using these com ports as serial ports:
    Com3 incoming
    com4 incoming
    com8 outgoing LGshine
    Part of the debuglog:
    at ATSMS.Modem.Connect()
    at MobilePhone.MobilePhone.internal_connect()
    7/5/2009 7:07:36 AM:Info : Starting MobilePhone version: 1.12.3434.20297
    7/5/2009 7:07:36 AM:Info : Current directory: C:\Program Files (x86)\RideRunner\plugins\Mobilephone.NET
    7/5/2009 7:07:36 AM:Info : Device address: 00:21:fb:67:04:6c
    7/5/2009 7:07:36 AM:Info : Pair code:
    7/5/2009 7:07:36 AM:Info : International prefix = 0044
    7/5/2009 7:07:36 AM:Info : International shortcut prefix = +44
    7/5/2009 7:07:36 AM:Info : National prefix = 0
    7/5/2009 7:07:36 AM:Info : Using ATSMS for phone connection
    7/5/2009 7:07:36 AM:Info : MobileCall.skin: on
    7/5/2009 7:07:36 AM:Info : Trying to connect to phone.
    7/5/2009 7:07:36 AM:Info : Com port set to COM7
    7/5/2009 7:07:36 AM:Info : BaudRate set to 115200
    7/5/2009 7:07:36 AM:Info : DataBits set to 8
    7/5/2009 7:07:36 AM:Info : StopBit set to 1
    7/5/2009 7:07:36 AM:Info : FlowControl set to None
    7/5/2009 7:07:36 AM:Fatal : Failed to connect to phone.ATSMS.ConnectionException: The port 'COM7' does not exist. ---> System.IO.IOException: The port 'COM7' does not exist.
    at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
    at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
    at System.IO.Ports.SerialPort.Open()
    --- End of inner exception stack trace ---
  3. #353
    Sep 2006
    Mexico City
    Quote Originally Posted by blazini View Post
    Com3 incoming
    com4 incoming
    FINALE AFTER ABOUT 8 HOURS OF HARD WORK I FIND THE PROBLEM!! and solution! (for bluetooth telephones)
    look when you install program you only need select BLUETOOTH and SKINS, not ATSM.
    Thats all, fix it. now its working THANKS!
    i think installer is very very bad, it put files in other places not in where you say, example when i install i say that install in c:\riderunner but it install skin files in program files\riderunner.
    I think actual install program very bad, and i think is better only put .rar and instruction.txt
  4. #354
    Aug 2004
    Yeah, I've tried that before too. All that seems to do is edit the first line of the .ini, which you can do without checking those boxes on the install.
    Anyway I uninstalled and did it fresh, now I'm getting popups.......
    system.indexoutofrangeexception: Index was outside the bounds of the array
    at Mobilephone.BsSDK.SelectRemoteDevice(UInt64 device_class)
    at Mobilephone.Mobilephone.Internal_connectBlue()
    at Mobilephone.Mobilephone.connectProcess()
    still won't connect, but the com7 thing is gone from the log.
    BTW, I setup DFX4 with mobilephone and I still get the same issue. My computer is an amd64 but the carputer is x86. Maybe it'll work in the car the way it is, but I don't even wanna bother with the hassle unless I know it's a x64 issue.
  5. #355
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by xpluis View Post
    I'm very sorry it took you all of 8 hours to find the problem. Try to remember I've put 100's of hours into this. Your correct in that you need to choose EITHER atsm or Bluetooth and not both.
    As far as the installer goes I'll look into the fact it doesn't install the skin in the correct place. The installer gets rid of lots of other problems so I'm going to stick with it.
  6. #356
    lambosprit's Avatar
    Sep 2006
    UK
    I have only tested it on an x86 so I can't say if its 64 compatible. However it looks like your macaddress hasn't been defined correctly.
    Make sure you only install Bluetooth if your using bluetooth. ATSM is completely diferent and is only there because Lucifers code worked for it (I may have broken it in my messing though). Then make sure you find the correct macaddress and pair your phone correcty.
  7. #357
    Aug 2004
    You were right it was set wrong, I set it up about 3 times trying to get it working and missed 2 digits the last time. The address is correct now in the MobilePhone INI but it's back to doing what it was doing before. Now the popups I get are:
    System.dllnotfoundexception: Unable to Load "BSWrapper.dll": This application has failed to start because the application is configured incorrect. Reinstalling the application may fix this problem (exception from HRESULT 0x800736B1)
    at Mobilephone.APIs.Initialize(IntPtr bd_addr)
    The only thing I noticed was in the log file it isn't showing a pair code. Where is the pair code taken from?
    7/5/2009 3:45:57 PM:Info : Starting MobilePhone version: 1.12.3434.20297
    7/5/2009 3:45:57 PM:Info : Current directory: C:\Program Files (x86)\RideRunner\plugins\Mobilephone.NET
    7/5/2009 3:45:57 PM:Info : Device address: 00:21:fb:67:04:6c
    7/5/2009 3:45:57 PM:Info : Pair code:
    7/5/2009 3:45:57 PM:Info : International prefix = 0044
    7/5/2009 3:45:57 PM:Info : International shortcut prefix = +44
    7/5/2009 3:45:57 PM:Info : National prefix = 0
    7/5/2009 3:45:57 PM:Info : Using BlueSoleil for phone connection
    7/5/2009 3:45:57 PM:Info : MobileCall.skin: on
    7/5/2009 3:45:57 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:08 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:18 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:28 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:38 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:48 PM:Info : Trying to connect to phone.
    7/5/2009 3:46:58 PM:Info : Trying to connect to phone.
    7/5/2009 3:47:08 PM:Info : Trying to connect to phone.
  8. #358
    Sep 2006
    Mexico City
    Quote Originally Posted by lambosprit View Post
    NO PROBLEM LAMBOSPIRIT! im very happy with this plugin, i have about 1 year try to conect my iphone with my carputer and now thanks to YOU finally i CAN!!
    I put my problems for all other people that use your program for first time, but really i very happy with this plugin.
  9. #359
    Sep 2006
    Mexico City
    Are some skin that have support for this plug in? that have his own mobilephone.skin, MobileCall.skin, etc... ?
  10. #360
    Sep 2006
    Mexico City
    I have vista 64 and its working, remember install fremework 2.0 (64 bit), and vc librarys for 64 system.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
