Page 38 of 126 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #371
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    Quote Originally Posted by lambosprit View Post
    At the moment there is no phonebook synching for any phone.
    What there is is the ability to type your own phonebook manually.
    There are 4 phone books but the correct one to use at the moment would be MOBILEPHONE_PC.txt. This is supposed to be for numbers stored on your pc.
    Now the format is important.
    there MUST be a blank line at the beginning. I have no idea why but it must.
    then it must look like
    LSTphonenumber||displayname
    I think you need a blank line betwen each number as well.
    Now if you get a phone call and the caller id matches a number in this file (but only this file) then the caller id is changed from the number to the Name given.
    Also you can display the photo for the person by adding a picture file (type can be defined in the ini along with location) with the name of the file being the phonenumber.
    I start my MOBILPHONE_PC.TXT and add many address like:
    LST5511111||Luis Sanjuan Nextel
    LST55777777||xpluis phone
    LST55888888||Lambo Tell
    But its don't display in the skin, what's wrong?
    (Skin Code Area SC01)
  2. #372
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by blazini View Post
    And where might that be? It's not in the log file.
    You'll need to do a search on your harddrive I'm afraid. For some reason it sometimes get put elsewhere. I keep meaning to fix that but forget. Its coded in C++ which is not my favorite language to say the least.
  3. #373
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by xpluis View Post
    ok. couple of questions.
    Which skin? One of mine or your own. If your's can you post the .skin file.
    When you say it doesn't display is that anything at all, or is it displaying just the number?
  4. #374
    Sep 2006
    Mexico City
    In both skins i have the same fail, in my skin and also in your original skin i have the same problem.
    This is location: C:\Program Files\Road Runner\Plugins\Mobilephone.NET\MOBILEPHONE_PC.txt
    This is the file
    -------start of file--------------
    -------end of file--------------
    but dont display nothing, dont display number, and not display numbers... nothing... any ideas?
  5. #375
    Newbie roobin's Avatar
    Jul 2007
    Adelaide
    Quote Originally Posted by Dartman_71 View Post
    To enable plugin you need to add X,mobilephone to menu skin and it works any skin you want.
    what is it i have to add ??
    Roobin
    ICC Carputer
    Ford BA XR6 4.0L Auto
  6. #376
    lambosprit's Avatar
    Sep 2006
    UK
    This is the file
    if you see nothing its either because your file definition is wrong (but it looks ok from what you've posted) or its not finding the file. So have you set the correct location for the phonebook in your ini file?
    Last thing would be to check the debug of RR. This is just basic ride runner custom list stuff so nothing to do with Bluesoliel.
  7. #377
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by roobin View Post
    If you used the installer then nothing. It installs it as a global plugin. As far as I know global plugins only work for RideRunner so if your using the old code of RoadRunner you may need to add the x,mobilephone to the menu.skin.
  8. #378
    Sep 2006
    Mexico City
    I have this in my phonebook.ini:
    [PHONEBOOK]
    # When a phonecall is terminated the RC,MC and DC txt files are updated, this specifies the delay in milliseconds between the hangup and the sync call
    SyncDelay=1000
    # Path to where the phonebook files should be stored. Leaving blank will save them to RoadRunner folder.
    PhonebookPath=C:\Program Files\Road Runner\plugins\Mobilephone.NET
    And my address book is called MOBILEPHONE_PC.txt and is in these directory but not show nothing in mobilphone skin.
    I have 1 windows vista and nothing, in my office computer that have windows xp nothing, and nothing in my car. what could be the problem?
  9. #379
    Aug 2004
    I did hd searches up and down, bswrapper.log just doesn't exist. I do have the debug level in bswrapper.ini set to 5.
  10. #380
    May 2007
    Great plugin! I've tested it on my desktop PC and it works with my iPhone. Now to install it on my carPC and wire up a mic. Thank you so much for this hard work.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
