I'm using a Belkin dongle (F8T0012) with my k800 and everything works fine so far
What USB dongles are being used with this and the Bluesoleil support?
Regards,
Jim
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
The reason for my original question is that I have a Belkin F8T013 and it doesn't seem to be supported by Bluesoleil.
Note that on the back of the dongle it says F8T013 NOT F8T013-1 which is what the Belkin web site refers to.
I have it installed on Vista using the Belkin Vista driver. It pairs fine with my HTC Mogul.
However, when I run the Bluesoleil hardware check it says that the dongle is not supported.
I know the dongle is at least 4 years old so it may be that.
Regards,
Jim
I have the plugin installed and it seems to be working OK so far except that I can't determine how to send keys (DTMF tones) to an active phone call.
As a simple example my cell phone voice mail needs both a password and menu navigation inputs.
How does one do that?
I tried just clicking the digits on the mobilephone.skin but that seemed to only place the key stroke in the dialed number area. I also tried clearing the dialed number area, clicking the numbers, and then clicking the dial button.
None of these worked.
I have to believe it's there somewhere and that I just can't find it.
I've reviewed the doc and see no send command (as opposed to dial). I know the WM6 phone support differenitates between send and dial from when I wrote my own limited support.
I have a Sprint HTC Mogul, latest BlueSoleil 6, button dongle that is supported, and XP-SP3.
Regards,
Jim O'Brien
Anyone have a mobilecall.skin and associated images that they are willing to post as an attachment?
I'm just rying to save some testing time.
Regards,
Jim
Heres one for the gurus.
My bluetooth is supported by BS. I had an old version, 2.6 or something like that, and it found my bluetooth with no problems.
So, I installed 6.4.249.0 and no matter what I try, it will not find my bluetooth. Nothing works. I tried several times and it just wont find it, but it is supported.
Any ideas?
