Page 43 of 136 FirstFirst ... 33343536373839404142434445464748495051525393 ... LastLast
Results 421 to 430 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #421
    Nov 2006
    It is really strange how the plugin and PDANet interact thru BS.
    I've tried disconnecting the phone and disabling the plugin after doing some call in and call out testing, and something keeps reconnecting for a couple of times and then pops up a message form BS about disconnecting DUN which I had never done.
    After that I tried PDANet, and it flat wouldn't connect. I then tried enabling the plugin and connecting the phone which worked BUT the phone interaction just didn't work, errors like I described.
    I am sending you a PM, hope you don't mind.
    Regards,
    Jim
  2. #422
    Jan 2004
    Hey Lambo,
    Great work so far and love the skin so far but why don't you use the phonecontrol skins that's already done for the BMW36 skin since you're making something similar to that.
    Quote Originally Posted by rodweb View Post
    Yeh I know, I promised to do something about this for the BMV2 skin I use and I finally knocked this graphic up tonight:
    I am not much of an artist but it is roughly like BMV2. If anybody has any good PSD's of phone logos I could borrow to use in this it would be much appreciated. The green one is a bit rough as it is a modified copy of the red one I found on Google...
    So now I just need to write the skin file for this one night soon. Have something on tomorrow night though.... maybe somebodyu else can finish this off.
    Lambospirit said we needed these commands earlier:
    I was going to use the bottom square box for
    MOBILEPHONE_PHOTOPATH and
    Green Icon for MOBILEPHONE_PICKUP and
    Red icon for MOBILEPHONE_HANGUP
    And MOBILEPHONE_CALLERNAME and MOBILEPHONE_CALLERID in the long rectangle centred one below the other.
    and maybe MOBILEPHONE_CANCELAA over the Incoming call text.
    This is laid out Pretty much as per the sample graphic Lambo posted up earlier.
    Happy for Lambospirit to pick this up when completed and include in his distro.
    Any feedback on the design would be appreciated. Can't guarantee I can incorporate it though as I am a newby with Photoshop....
    Not sure if I want to tackle the main graphic or not. It would be great to redo it too. Have not pulled down a version for a while maybe somebody else has fixed it....
  3. #423
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by wariow View Post
    Hey Lambo,
    Copyright mainly. Not sure if we're allowed to just use them. Be glad to if we get permission but wouldn't know who to ask.
    @Nomader. Any news on the testing? Your message box is full so can't pm you.
  4. #424
    Oct 2007
    Assens, Denmark
    Quote Originally Posted by lambosprit View Post
    Try Robby BMW. Here is his BMW E36 thread.
    Henrik
  5. #425
    Jun 2007
    Minnesota
    Request:
    Would like to have a True/False indicator for when the mic is muted. I've been playing around with making a couple of phone screens and it doesn't really make sense to have two separate buttons to mute/unmute the mic.
    Dan from Minneapolis
    1999 Volvo V70R
    Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
  6. #426
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by darag2358 View Post
    Request:
    you can always create a custom indicator which you control. then check that indicators state before the command. Something like so..
    in exectbl.ini
    Code:
    "ONSKINSTART","SETIND;CUSTOMMICMUTE;OFF"
    your mute button command code
    Code:
    "BYIND;CUSTOMMICMUTE;!MICONCOMMAND!||SETIND;CUSTOMMICMUTE;ON<<!MICOFFCOMMAND!||SETIND;CUSTOMMICMUTE;OFF"
    replace the commands between the ! with the mobilephone commands for mic mute on/off. And there you have one button that performs both tasks AND turns on/off the indicator.
    Live mp3Car Facebook Chat
  7. #427
    Jun 2007
    Minnesota
    Clever, thank you. This is my first time messing around with skins, so I have a couple of followup questions.
    Does this assume that mic mute is off when loading the skin? Is that OK to assume? What if I have the mic muted then exit the screen and later return to it? Is there any possibility that the custom indicator and the actual mic state gets out of synch?
    1999 Volvo V70R
  8. #428
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Sonicxtacy02 View Post
    in exectbl.ini
    Code:
    I'd make one small change. Id send a mobilephone_unmutemic as well. That way you know the current state of the connection. Otherwise you could end up thinking its mute when its not.
    "ONSKINSTART","SETIND;CUSTOMMICMUTE;OFF||MOBILEPHO NE_UNMUTEMIC;" I think
  9. #429
    Jun 2007
    Minnesota
    Perfect, that should work great. Thanks.
    1999 Volvo V70R
  10. #430
    Jun 2007
    Minnesota
    OK, I have a small hangup again. I made a simple mobilecall.skn, kind of like the example above. But, if I place a call using my actual cell phone (which I may want to do if I want to just use the phone and not let my passenger hear the call over the car's speakers) it triggers mobilecall.skn. Is that intended? I'd rather it not do anything in that scenario, and only have the mobilecall.skn load if there is an actual incoming call.
    1999 Volvo V70R
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
