Page 45 of 136 FirstFirst ... 35363738394041424344454647484950515253545595 ... LastLast
Results 441 to 450 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #441
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    All right, I got my car back early. I installed the Visual Basic C++ like you said I should, and now things are worse off then they were before.
    Now, the comp doesn't even recognize when a call is incoming or outgoing and it doesn't call for mobilecall.skin or pause the music that is playing. And the buttons that were giving errors, still do. At least before it would pause the music when I made or got a call.
    I have included the latest log files.
    Please help me fix this!
    Thanks.
    Edit with new info: I found out that it doesn't call mobilecall.skin and pause the music if I bring up the mobilephone.net skin at all. If I do, it will not do anything on an incoming or outgoing call until I restart RR. Other than that it works exactly the same.
    Attached Files Attached Files
  2. #442
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by darag2358 View Post
    OK, I have a small hangup again. I made a simple mobilecall.skn, kind of like the example above. But, if I place a call using my actual cell phone (which I may want to do if I want to just use the phone and not let my passenger hear the call over the car's speakers) it triggers mobilecall.skn. Is that intended? I'd rather it not do anything in that scenario, and only have the mobilecall.skn load if there is an actual incoming call.
    I think this is a problem in the plugin. It opens the mobilecall skin if your making an outgoing call or recieving one. I will try to fix. However I can't promise that the audio will be through the phone and not through RR. To do that you currently have to disconnect the phone using mobilephone_disconnect and then reconnect when you've finished your call.
  3. #443
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Spikemonkey View Post
    Thanks.
    I'll have a look.
    Did you try reinstalling mobilephone after vc++?
    Also you are getting the dreaded invalidcommand. Have you tried making the skin commands all lowercase?
  4. #444
    Aug 2009
    Virginia
    Quote Originally Posted by lambosprit View Post
    I'll have a look.
    No, I have not reinstalled mobilephone after. I will try that and let you know.
    And, I have not tried that either, I knew there was something else I was supposed to try that you had mentioned earlier. Where do I make the commands lowercase? In the skin itself or in one of the .ini files? Or both? I will do that, also, and let you know.
    Thanks again.
  5. #445
    Jun 2007
    Minnesota
    If that's the case, then maybe it would be fine to just call the mobilephone skin rather than the mobilecall skin, so that you have an easy way to disconnect.
    Dan from Minneapolis
    1999 Volvo V70R
    Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
  6. #446
    Aug 2009
    Virginia
    Well, I've tried everything. No go on changing everything to lowercase and reinstalling.
    Everything is still functioning/not functioning exactly the same. Although I did notice that the "pickup" command is pausing winamp properly, but only after I "OK" the error message.
    My only thought is to send you a copy of my entire RR directory to try and help you find anything. If you want to try that, let me know.
  7. #447
    Aug 2009
    Nothing works - are the comments and guides right?
    [COMMENT]Trial skin
    There is a trial skin also for BMV courtesy of Lucifer.To install this:
    add skin folder from the attached zip to your skin directory
    add x,mobilephone to your menu.skin
    change the button 09 in the menu.skin to B09,10,416,150,110,"LOAD;MOBILEPHONE.SKIN;","" *** this only applies to the BMV2 skin
    [/COMMENT]
    I dont know, how to get the zip, because as the main download file was the "Mobilephone.Net_setup1.12" and this had only the install exe.
    Is not good, that the installs and other files are not concentraded under the nice little button above, that has name "downloads"!
    Under this downloads the plugin section is not present. Skins and other instalable thing are missing here too! How to find the right files together?
    How to make working this plugin with the standard instalation of RideRunner? This have the skin named "Carwings_Dynamic_Lite". Can i made the settings to this standard screen?
    Thank you,
    Feri
  8. #448
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    got an error...
    anyone had this one before?
    EDIT: basic its missing bssdk.dll ... i have the bluesoil software installed (came along with my bluetooth dongle)
  9. #449
    Oct 2008
    Odense, Denmark
    got the dll from another thread and put it next to the plugin dll and tried to register... but tit failed... then tried in system 32... no luck either
  10. #450
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    got an error...
    Do you have the right version of bluesoliel installed. Your bluesoliel software should have come with the bssdk.dll and installed it. You need to be on at least 6.4.x. Most dongles come with a lower version of bluesoliel.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
