Page 46 of 136 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #451
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    upps... 1.4.9.5
  2. #452
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    upps... 1.4.9.5
    That's your problem.
  3. #453
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by Spikemonkey View Post
    Well, I've tried everything. No go on changing everything to lowercase and reinstalling.
    Everything is still functioning/not functioning exactly the same. Although I did notice that the "pickup" command is pausing winamp properly, but only after I "OK" the error message.
    My only thought is to send you a copy of my entire RR directory to try and help you find anything. If you want to try that, let me know.
    lambosprit, are you interested or not? I, and others, would like to help you get this fixed.
  4. #454
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    i have a request:
    in my silabs plugin i can reduce or mute the radio sound by external call
    example: the phone ringing and the radio reduce automatically the volume, if i take the call the radio automatically mute the sound, i hang up and the radio return to original volume
    in this case the phone software must send 3 possible code
    1: reduce volume
    2: put radio in mute
    3: restore original volume
    the reduced volume value can be set in my config.ini of the silabs
    now is set to 25% of the max radio volume, user can be change this value into riderunner setup windowa of my plugin
    Code:
    [State Of Setup]
    news_switch=True
    ta_switch=True
    last frequence=100,50
    MinStrengthRadio=25
    frontsx=100
    frontdx=100
    rear_sx=75
    rear_dx=75
    drivemon=25
    muteafpopup=True
    afpopup=True
    presetpopup=True
    newsvol=50
    tavol=50
    tiseconds=90
    radioon=True
    silabsvolume=100
    tiswitch=True
    radioresume=False
    it's just do it, now only remain that your software call mine
    (next week i start to write the new extension plugin using the new riderunner plugin add some line to make it compatible with your plugin is very simple)
    i use this feature with sygic gps, when the gps "speak" the radio reduce the volume
    (this old video was made to test the function, the music is ugly and the speed of the track demo was set to high)
    [media]http://www.youtube.com/watch?v=jSAjX33gceI[/media]
    like the gps we can make it for the phone software
    you must only add 4-5 lines of code (if you want i can send you)
    if are you intrested for, i'm here
    (in the same way it's possible to do this for winamp, the source code to be write is simple)
  5. #455
    Jun 2007
    Minnesota
    Listen to this guy ^^
    He knows what he's doing.
    Dan from Minneapolis
    1999 Volvo V70R
    Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
  6. #456
    Nov 2006
    Hi Guys,
    I have been in contact with Blue Soleil about getting PBAP in their SDK.
    They said that they have no plans on integrating it into the SDK, but if I pay them I can get it put in.
    They quoted me like $20k US.. bit out of my price range.
    But then they sent me this email:
    Dear Adam,
    We still have no plan to deploy manpower to do the PBAP APIs.
    If you need it , we could apply resource to do, but its not free.
    Weve discussed with our leader, if you could pay$ 5,000 USD, we can help you to achieve all the PBAP interfaces and have Six months technical support.
    If you could pay the cost, we can accept to provide the PBAP API and description document for you in one month.
    Your comment please.
    Best regards,
    Eric
    So if I can come up with $5k we can get phonebook access in the SDK.
    Still a bit much for me, but 50 people @ $100 each doesn't seem too bad.
  7. #457
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by deepgrey
    I send 3 e-mails on 12 months period to BlueSoleil support about why BS doesn't support usb microphones and they not even bother to answer, so I'm not interest spending any $ to BS products.
  8. #458
    lambosprit's Avatar
    Sep 2006
    UK
    Been on holiday again. I'm always up for fixing problems, and also want to get this fixed. If you zip up your rr directory including the plugins and skins I'll have a look.
  9. #459
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by spidermunz View Post
    i have a request:
    1: reduce volume
    I think your saying you reduce the volume of just certain things so that the ringing could be heard. Is this correct?
    I'm interested. Send me the code and I'll look into implementing it for you.
  10. #460
    Dec 2006
    italy, sardinia
    yes, is correct
    if the telepone ring the radio reduce the volume and we can hear the ringing
    if i decide to accept the call the radio goes in mute
    at the end of the call, i hang up the phone and the radio return to the original volume, or if i reject the call the radio return to the original volume
    we can tell guino if can introduce this function for mp3, video, ecc
    later i send you the code, but the best is that it can be managed inside rr, and for all application
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
