Page 47 of 136 FirstFirst ... 37383940414243444546474849505152535455565797 ... LastLast
Results 461 to 470 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #461
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by spidermunz View Post
    yes, is correct
    if the telepone ring the radio reduce the volume and we can hear the ringing
    if i decide to accept the call the radio goes in mute
    at the end of the call, i hang up the phone and the radio return to the original volume, or if i reject the call the radio return to the original volume
    we can tell guino if can introduce this function for mp3, video, ecc
    later i send you the code, but the best is that it can be managed inside rr, and for all application
    I agree.
  2. #462
    lambosprit's Avatar
    Sep 2006
    UK
    Just to show there is some development going on here. I have a version with audio transfer (i.e. make the audio go through the phone, not your speakers) and DTMF being tested at the moment.
  3. #463
    Constant Bitrate almera's Avatar
    Aug 2004
    Does anyone using this plugin have problems with EWF / HORM setup? Plugin resumes from hibernation without EWF / HORM enabled. But when enabled plugin does not load after resume, even BT dongle detected fine.
  4. #464
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    I can not believe it, I created easier as I remembered
    just call these commands:
    softmute_on to decrease the volume
    softmute_off to restore the original volume
    mutesilabs to enable / disable the volume (this command to the radio will change the name because we will use the Standard command of RR for the radio mute
    so the procedure is this:
    ringing the phone you call "softmute_on"
    If you reply you call "mutesilabs"
    when you close the communication you only call "mutesilabs" and then immediately "softmute_off"
  5. #465
    Dec 2006
    italy, sardinia
    for now you can use that commands
    but i have requed to guino this function to be implemented inside rr for all programs that could use it
  6. #466
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by lambosprit View Post
    Been on holiday again. I'm always up for fixing problems, and also want to get this fixed. If you zip up your rr directory including the plugins and skins I'll have a look.
    Cool! Sorry if I came off as a bit impatient. I'll get it rar'ed and to you ASAP.
  7. #467
    Nov 2006
    So nobody wants PBAP?
    BlueSoleil have always emailed me back pretty promptly when I contact them. OBviously they are a business and can't do everything for free though.
    PBAP (Phone Book Access) is the only major thing left that the SDK can't do.
  8. #468
    Aug 2009
    Virginia
    Here you go! Hopefully the other guy who had this same problem can do the same, to help you search for similarities. If you need any more info about my system setup, hardware/software, just let me know. I will be glad to help you get his perfected.
    Attached Files Attached Files
  9. #469
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    so do it work with all tuners or just the silabs ?
  10. #470
    Oct 2007
    Assens, Denmark
    Quote Originally Posted by boelle View Post
    Only with the SiLabs and only if you use the Spidermunz SiLabs-plugin.
    But if others adapt the functionality, it's highly welcomed.
    Henrik
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
