Page 50 of 134 FirstFirst ... 404142434445464748495051525354555657585960100 ... LastLast
Results 491 to 500 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #491
    Aug 2009
    Thx to all.
    Any idea with 2 call buttons for dualsim ?
    Feri
  2. #492
    Aug 2009
    UK
    Quote Originally Posted by lambosprit View Post
    yes. Just edit the mobilecall.skin and change the
    /SHOWWIDTH=500
    /SHOWHEIGHT=300
    /POSX=180
    /POSY=180
    values until your happy. The swf file will automatically be scaled to fit by RR.
    That's great, I was hoping it was that.
    It would mean a change to the swf file. I use a modified bottom swf with freedom ultimate that shows the caller id and allows me to finish the call so its not been a problem.
    Right I see. Unfortunately the skin that I am using doesn't have a section which is common to all pages so I think I'll add the command to load the mobilephone.skin to the answer button.
    I think you can do that by checking the value of the incomming call indicator and then sending a radio pause. I thinks its th byvar skin command. However spidermunz has suggested a better way which I'm just waiting for word on before making any changes.
    Sounds good. Nice to hear all you plugin dudes are working together.
    In the mean time, I think I'll try adding the radiomute command to the answer button too.
    Then it's on to making a new mobilephone.skin and working out the caller ID and phonebook stuff.............it's a good job I haven't finished the hardware installation yet!!
    Edit; I just realised that I can't add any commands to the answer button without editing the swf (obviously!). Is there an freeware that will let me do this? Or maybe could someone do it and send me the edited version? Thanks.
    Edit again!; created my own mobilecall.skin that does what I need and matches the simplistique skin. Not as fancy as flash files but nevermind.
  3. #493
    Low Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by Wolvers View Post
    I've asked this a dozen times of a buch of other people, but: Would you mind posting your mobilecall.skin file? I would like to have one but I am no good at making skins. Thanks.
  4. #494
    Aug 2009
    UK
    Quote Originally Posted by Spikemonkey View Post
    Don't mind at all. I've done a version to match the simplistique skin of mobilephone.skin too if you want that?
    Actually, PM me as I don't have anywhere to host it right now.
  5. #495
    Aug 2009
    Virginia
    Yeah, both will be fine. Just rar them up and attach them to a post. That seems the easiest way. And, thanks.
  6. #496
    Aug 2009
    UK
    OK, here you go then. I hope they'll do what you need.
    Please note that they are work in progress, Mk1 if you like. The mobilecall skin only currently shows the incoming number (or name if you want to change the command) but I intend to change it so that it has both, and possibly images of callers. I may also add some stuff to the mobilephone skin if/when I decide what they should be or if the creator adds more useful features.
    I am also open to suggestions/requests.
    Attached Files Attached Files
  7. #497
    lambosprit's Avatar
    Sep 2006
    UK
    If you dont mind I'd like to add them to the installer when they're finished.
  8. #498
    Aug 2009
    UK
    Not at all. It's nice to be able contribute something.
    Actually some credit goes to member qbunnie who made the simplistique skin for mymobiler that I have used as a template for these.
  9. #499
    Aug 2009
    I am too stupid to install this pretty skin with phone supp. - can u help?
    Can you give here a little guide - from A till Z - how to install RR on fresh system from begin and then this fine skin and the telephone support? I got running only the standard installation of RideRunner, but nothing others!
    First - must be installed previously the standard RideRunner installation? Or is enough to copy the files from Spikemonkeys link, from thread #468:
    http://www.mp3car.com/vbulletin/atta...riderunner.rar
    to the right directory?
    I have tested 2 ways - first fresh ofitial installation and then owerwrite this with Spikemonkeys files. Not running. The error message are listed down. Then i have the ofitial installation deleted and kopied only the Spikemonkys files to the right location (more about later). The same errors! In both tests i got this message:
    C:\Program Files?Ride Runner\ Skins\eLite Lite\ does not contain a valid skin!
    Check your settings and try again.
    Details in debug.txt
    Debug txt:
    16.09.2009 01:14:15: Start -- Version: 01.07.2009
    16.09.2009 01:14:15: OS Type: Windows XP
    16.09.2009 01:14:15: FileManager: FileMode = Legacy
    16.09.2009 01:14:15: FileManager: mypath = C:\Program Files\RideRunner\
    16.09.2009 01:14:15: FileManager: ProfilePath = d:\MyData\Files\RideRunner\
    16.09.2009 01:14:15: ERROR: GDI+ support is requested, but unable to create object, possible cause, 'GDIPlusWrapper.dll' is not registerd
    16.09.2009 01:14:15: Master Vol: Lautsprecher/4
    16.09.2009 01:14:15: GetLineControl Failed: 401
    16.09.2009 01:14:15: No Treble Support
    16.09.2009 01:14:15: No Bass Support
    16.09.2009 01:14:15: No Master Mute
    16.09.2009 01:14:15: Source: Wave=&H1008/1
    16.09.2009 01:14:15: Source: SW-Synthesizer=&H1004/2
    16.09.2009 01:14:15: Source: CD-Player=&H1005/3
    16.09.2009 01:14:15: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    16.09.2009 01:14:15: No Phidgets interface detected.
    16.09.2009 01:14:15: Plugin Manager: loading Global Plugins...
    16.09.2009 01:14:15: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    16.09.2009 01:14:15: Plugin Manager: Plugin Found: SkinTool plugin found but will be unable to create (most likely NOT registered)[skipped].
    16.09.2009 01:14:15: Plugin Manager: loading Global Plugins Completed.
    16.09.2009 01:14:15: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
    16.09.2009 01:14:15: Plugin Manager: loading SkinDir Plugins...
    16.09.2009 01:14:15: Plugin Manager: loading SkinDir Plugins Completed.
    16.09.2009 01:14:15: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (main.png)
    16.09.2009 01:14:15: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menus.png)
    16.09.2009 01:14:15: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (on.png)
    16.09.2009 01:14:15: ERROR: Loading image file(s) for: menu.skin (Invalid picture)
    BTW:
    First problem was, that the german WinXPpro have the program directory not "Program Files" but "Programme".
    Second - i have this directory inclusive Windows home directory on drive F:\ , not C:\ !!! In this case no problem. I have for test created the "Program Files" directory on drive C:\ (i hope, it is a space between this words?) and then copied the downloaded "RideRunner" directory into it. But the message what i got is always the same, as described above.
    So please - how and what i need to download, install and set, to get a running first system!?
    Should i first install the standart Ride runner, or simply copy the files from Spikemonkey into c:\Program Files\Ride Runner\ - what is the right way???
    Thanks,
    Feri
  10. #500
    Aug 2009
    UK
    I think you need to uninstall everything and start again mate. Then read through the Riderunner FAQs carefully and make sure you follow the installation instructions for each item in this order;
    1. Riderunner (and related software that is required as per the FAQ)
    2. Place the folder of whatever skin you want to use in the 'Skins' folder. Select it in the Riderunner setting application.
    3. Mobilephone.net (follow Lambos instruction to the letter from post #1)
    4. Copy my skin files to folder of the skin you are using.
    If you get stuck on steps 1 or 2 then you need to ask in the main Riderunner forum and not here. Good luck
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
