Page 51 of 136 FirstFirst ... 414243444546474849505152535455565758596061101 ... LastLast
Results 501 to 510 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #501
    Jun 2006
    Lambo,
    Can you decipher my debug log for me
    9/15/2009 7:34:21 PM:Info : Starting MobilePhone version: 1.12.3434.20297
    9/15/2009 7:34:21 PM:Info : Current directory: C:\Program Files\Road Runner\plugins\Mobilephone.NET
    9/15/2009 7:34:21 PMebug : Path being set to C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32 \Wbem;C:\Program Files\IVT Corporation\BlueSoleil\Mobile;C:\WINDOWS\system32\ Wbem;C:\Program Files\Road Runner\plugins\Mobilephone.NET
    9/15/2009 7:34:21 PM:Info : Device address: 00:23:7A:F2:4D:A8
    9/15/2009 7:34:21 PM:Info : Pair code:
    9/15/2009 7:34:21 PM:Info : International prefix = 0044
    9/15/2009 7:34:21 PM:Info : International shortcut prefix = +44
    9/15/2009 7:34:21 PM:Info : National prefix = 0
    9/15/2009 7:34:21 PM:Info : Using ATSMS for phone connection
    9/15/2009 7:34:21 PM:Info : MobileCall.skin: on
    9/15/2009 7:34:21 PM:Info : Trying to connect to phone.
    9/15/2009 7:34:25 PM:Info : Com port set to COM7
    9/15/2009 7:34:25 PM:Info : BaudRate set to 115200
    9/15/2009 7:34:25 PM:Info : DataBits set to 8
    9/15/2009 7:34:25 PM:Info : StopBit set to 1
    9/15/2009 7:34:25 PM:Info : FlowControl set to None
    9/15/2009 7:34:46 PM:Info : Connected to phone
    9/15/2009 7:35:07 PM:Fatal : Failed to connect to phone.ATSMS.InvalidOpException: Cannot enable CLIP ---> System.NullReferenceException: Object reference not set to an instance of an object.
    at ATSMS.GSMModem.EnableCLIP()
    --- End of inner exception stack trace ---
    at ATSMS.GSMModem.set_IncomingCallIndication(Boolean Value)
    at MobilePhone.MobilePhone.internal_connect()
    Looks like its trying to connect "ATSMS" ? How can I change that ? or should I not ? I'm with Verizon so I know something is different ?
    Mini Sumo Was here
  2. #502
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Mini Sumo View Post
    Lambo,
    Mini Sumo Was here
    you need to uninstall mobilephone then reinstall BUT only select bluetooth and not atsm. This plugin works for both (or should) but not at the same time. If theres both selected thenATSM wins. This is a legacy of lucifers code which is what I started with. When I get time I will change the installer so bluetooth is default selected and it will be impossible to select both bluetooth and atsm.
  3. #503
    lambosprit's Avatar
    Sep 2006
    UK
    @Ferika - dont use spikemonkeys. He only posted that so I could try to debug his problem (which I haven't been able to do yet as traveling again. I will get round to it though I promise).
    Follow wolvers advice and do some reading of RR's FAQ's. That way you'll find out about all the functionality of riderunner which will make it far more fun to use.
  4. #504
    Jun 2006
    Lambo,
    Reinstalled using only bluetooth now I get a popup exception screen saying
    can't load bswrapper.dll due to a configuration problem or something of the sort ?
    I did a regsvr32 on the bswrapper.dll and still get the popup ?
    Mini Sumo Was Here
  5. #505
    lambosprit's Avatar
    Sep 2006
    UK
    Lambo,
    Mini Sumo Was Here
    you dont need to register the bswrapper.dll. It just has to be in the same directory as the mobilephone.dll.
    Have you go the vc++ redistribution installed? That may be the problem. It comes as part of the installer now otherwise theres a link to its location in the readme.
  6. #506
    Variable Bitrate Deric's Avatar
    Sep 2006
    Has anyone got the Samsung Omnia (i910) to work with this? I just got this phone and would like to go handsfree via the CarPC.
  7. #507
    Feb 2008
    I have managed to get the plugin installed and working correctly, thanks for all your hard work. Turns out the issue I was having must have been skin related. I installed the simplistique skin files that were posted instead of the default skin that is supplied with the installer and all of the error messages stopped. By the way what is everyone using for a mic for the hands free? I currently have a headset mic but would like something that could be installed in the headliner where the factory handsfree is supposed to be installed but the mic would be almost 2 feet away and the current microphone won't pick up at that distance.
  8. #508
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by TSX2005PC View Post
    That fixed it? Man I need to get off my lazy butt and try that new skin. Heck, I'm the one that requested it! I will let you know if it works when I get a chance to do it.
    Also, I had a stroke of luck on my mic. My father had a Sony reciever that came with a mic for the auto calibration feature. It's an omni-directional mic that looks like a small hockey puck. It has a cord that is at least 15 feet long, so it can be mounted anywhere, no matter where your pc is. I have mine velcroed to the overhead console. It works great, if you want pics or anything, let me know.
  9. #509
    Aug 2009
    Virginia
    Alrighty, the new skin fixed it! It works great, now. I wonder what it is with the supplied skin that is affecting some but not all of us? I am going to try and put together a skin that looks more appropriate for the eLite skin I'm using, although if I wait long enough the developer of the skin is looking to integrate mobilephone.net into it himself. If my skin doesn't look like junk, I might post it.
  10. #510
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Spikemonkey View Post
    Great. I'm wondering as well why the skins causing the problem. I'll have a look and see if I can find anything.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
