will future versions have support for typing sms? maybe with an ini setting that blocks sms typing when the car is moving?
@TSX2005PC and spikemonkey. Wolvers has a good point. Which skin where you using. Was i the flash one?
I am using the standard carwings dynamic skin packaged wth RR and the latest version of BS.
The only mobilcall.skin that I got with the download is the one with the flash file in it and is in all the skin folders.
Could someone be so kind as to show me an example phonebook file that will show a name for a number I put in it? Also how to set it up to identify a picture with a number on an incoming call? I am currently using the eLite lite 1.6.5 skin that just updated to include mobilephone.net support. Now I really want to get the most out of this awesome plug-in. Thanks again.
the format for the phonebook is the following
space Dont type space!
LST019xxxxxxxxx||Lambosprit
the first part after the LST is the number. The second part after the || is the name you want to display (Its just a custom list in RideRunner so see RideRunners help for more info).
You can add as many copies of the second line as you need.
to do the picture on the skin you use a special indicator e.g.
I00,518,14,240,170,"FILE;$mobilephone_photopath$"
mobilephone_photopath is created by the plugin when a call arrives. It uses the photo path set in the ini file plus the incomming phone number plus the PhotoExt from the ini file
so photopath = c:\riderunner\plugins\mobilephone.net\photos
photoext = jpg
means c:\riderunner\plugins\mobilephone.net\photos\00000 00000.jpg
if riderunner finds a file with this name in this directory it displays it otherwise its left blank
