Page 53 of 136 FirstFirst ... 3434445464748495051525354555657585960616263103 ... LastLast
Results 521 to 530 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #521
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Spikemonkey View Post
    So, the name of the JPG shouls be the same as the incoming number? Like, if Bob's number is 5550121, Bob's picture should be named 5550121.jpg? Thanks again.
    yup. and it doesn't have to be a jpg. It could be a png or tiff I think (its a riderunner thing) BUT you can only define one extension so all files must be in that format.
  2. #522
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by lambosprit View Post
    Awesome. Thanks for all your help. A little off topic, but do you watch Top Gear? If so, are you as excited as I am that this season is going to finally be in HD?
  3. #523
    lambosprit's Avatar
    Sep 2006
    UK
    version 1.13 released
    DTMF is now enabled. Any key press made while in a call will automatically be treatd as a DTMF code. Only 0-9 and * and #
    are valid.
    Added new command mobilephone_transaudio which transfers audio to phone or headphones.
    Fixed so that mobilecall.skin only called when phone ringing and not just in a call or when making a call.
    Added ongoing calls to the incall indicator. Fixes unmute of music before call finished.
  4. #524
    Aug 2009
    Virginia
    are valid.
    Awesome, now I can check my voicemail without digging out the phone! Will this install on top of the previous version OK? Also, do you know how to, if it's even possible, increase the volume of the caller? I have to crank things pretty high just to hear whom I am speaking with. Thanks again!
  5. #525
    lambosprit's Avatar
    Sep 2006
    UK
    yes it'll install over the previous version. All your ini settings will be preserved.
    Theres a speaker unmute control, check out the readme, that should set your phones output to maximum. try that.
  6. #526
    Aug 2009
    UK
    are valid.
    Some brilliant additions there. Look forward to trying this out.
  7. #527
  8. #528
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Enforcer View Post
    Is it possible to get the battery and signal strengths as standard RR sliders as opposed to the current 6 stage indicators?
    sure. I'll add it to the list for next release. The number of steps (if any) depends on the phone though so you may still just get 6 but I understand it will be a slider rather than a image.
  9. #529
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I know there will not be the 20 odd steps (of a standard RR slider), it's just that I'm trying to reuse the old phoco images and layout that my skin has.
    Cheers
    Also while you're here, I notice that Pickup and dial are two separate commands/buttons, normally this button ie a green handset does both functions. Is it possible to have one command that can do both, again for compatibility for old images (and old brains that are used to the proper phones that work this way)?
  10. #530
    lambosprit's Avatar
    Sep 2006
    UK
    Cheers
    pickup does do both. Dial is just a legacy from lucifers code that I left in.
    Pickup first accepts a call if the phone is ringing, if not it dials a call if the dialbox has a number or if dialbox is empty it redials last number.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
