Yes it should popup once but it doesn't, something trigger it to popup again and again...
mobilecall should only popup when you have an incomming call. It should only popup once unless you cancel it without accepting or rejecting the call (even then I think it will only come up once). It shoud not popup if you make a call.
I finally got around to getting this to work with my iPhone. It is working well for making and answering calls. I exported my Contacts, and edited them to match the MobilePhone_PC.txt format, and can browse through them, select one and place a call. The battery and signal do not work, but this seems to be a Bluesolei limitation with the iPhone.
I do however, have the same problem as everyone above. When a call comes in, I click "answer" and the mobile skin pop-up remains on the screen. If I press "ESC" on the keyboard, it goes away briefly, and then pops right back up, preventing me from using anything else in the skin while I am in a call.
You have done some amazing work on this plugin, and thus many many thanks are in order! Now to get Bluesolei to fully support the iPhone and I will be set![]()
My Fiero Build Thread
I've been thinking about this today and I can see that there are some functions, particularly on the mobilephone.skin, that it would be useful to access while in a call.
You could always save a copy of the mobilephone.skin as mobilecall.skin if you want to have access to other phone functions while in a call. Just until Lambo has a chance to look into it.
dont worry all. I was sure it was fixed and its annoying that it isn't so I'll be looking into it asap. The reason I dont spot it is I stay in the mobilecall skin until the end of the call but thats just my choice.
Here's an updated version of my Simplistique skins for Mobilephone.net.
Changes are;
Added digital clock
Added 'Transfer Audio' button
Added 'Up' and 'Down' buttons for selecting names from the PB lists
Added previous and next page buttons (do these commands work Lambo?)
Menu button now goes to main menu
Added 'RADIOMUTE' command to dial/pickup and hangup buttons
Of course, please say if there are any issues.
I've been looking into the mobilecall issue. It only brings up the skin if the indicator mobilephone_incommingcall is true. What this means is that the ringing indicator must be true when you're in a call. Can somebody who's having the problem confirm this. i.e. answer a call and then check the value of the mobilephone_incommingcall while you are still in that call.
Don't mind at all.
I'm glad those buttons work. I can't test it as I haven't created a PB that's big enough yet and it said in the readme that they weren't implemented yet so I wasn't sure.
Are you using the latest RR build? I'm not getting the arial narrow font that's used in the PB and dial box now for some reason.
