Page 57 of 136 FirstFirst ... 7474849505152535455565758596061626364656667107 ... LastLast
Results 561 to 570 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #561
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by lambosprit View Post
    I've been looking into the mobilecall issue. It only brings up the skin if the indicator mobilephone_incommingcall is true. What this means is that the ringing indicator must be true when you're in a call. Can somebody who's having the problem confirm this. i.e. answer a call and then check the value of the mobilephone_incommingcall while you are still in that call.
    I just try it and mobilephone_incommingcall is true when I'm in call.
    Did you get my pm?
  2. #562
    Aug 2009
    UK
    Oh great. I've had to switch back to the onboard realtek sound, as the USB one that I was using was causing problems with the Silabs FM device, and now the caller doesn't hear anything at all!!
    Anyone else here using realtek onboard sound OK with this plugin?
  3. #563
    Feb 2009
    Finland
    Quote Originally Posted by Wolvers View Post
    Cool... I'm not alone My problem is that caller hear radio program from Silabs It's totally random, sometimes it work or not. I don't have problems with BS Dialer.
    Feels like Dialer check and choose what audio device to use, but plugin doesn't. I could be wrong, what I know
  4. #564
    Aug 2009
    UK
    Quote Originally Posted by Dartman_71 View Post
    My problem is that caller hear radio program from Silabs I don't have problems with BS Dialer.
    That's exactly the same here! I haven't tried the dialer yet.
    Lambo, you're the bluesoleil legend do you have any ideas?
  5. #565
    Constant Bitrate almera's Avatar
    Aug 2004
    I've had that problem. My solution; before installing BS software, go to control panel > Sounds and audio devices > set "sound recording" and "voice recording" default device to your mic device. I hope this helps.
  6. #566
    Aug 2009
    UK
    Dartman, do you find that the audio from your silabs stutters sometimes? Mine does and it would seem that it's lambo's plugin that is causing it.
    I had the BT turned off on my phone this morning, because of the mic not working, and the audio from the silabs was stuttering so badly that it was completely unusable. I turned the BT on, on my phone, so that the plugin could connect the headset profile and voila it stopped stuttering really badly and back to just a slight stutter very randomly (hardly noticeable).
    Quote Originally Posted by almera View Post
    Thanks for the suggestion. I checked this morning and it's set to this anyway. From what Dartman is saying, there is an issue with the BT stack and the realtek onboard device when not using the cphone tool (used ot be called BS dialler).
    I wonder if Lambo can force the sound input device in his plugin to use the mic and not the FM device?
    Edit; found the problem. Dartman, here's how to sort this
    1. Open device manager, USB audio device and go to the properties tab.
    2. Under audio devices open the 'USB audio device' and tick the box for 'Do not map through this device'. Click apply and OK, when prompted, and reboot the machine.
    3. In control panel, open sounds and audio devices and click on Test Hardware. Follow it through making sure that you get a level for your voice.
    4. That's it. It should work now. If you go into the Realtek control panel and select echo cancellation you'll get (what sounds to me) a half duplex type system where it sounds like it's cutting the mic when the caller speaks..........hence no echo for them.
    I haven't had a chance to see if this will sort the stuttering issue yet though.
  7. #567
    lambosprit's Avatar
    Sep 2006
    UK
    Ok. One problem at a time.
    The attached dll fixes the mobilecall popup problem I hope. To fix it I changed mobilephone_incommingcall to only be true when the phone is ringing and not when you're in a call.
    I've also added new return slider controls. Called mobilephone_batslide and mobilephone_sigslide. They use the values you set for BatteryImageCount and SignalImageCount in the ini file to work out the slider points so they must be set properly to get the correct output. Only you can do this as all phones are different and most phones dont support this feature so don't be surprised if it doesn't work.
    any way report back if it cures the popup problem.
    EDIT: Fix didn't work so removed dll.
  8. #568
    Nov 2006
    lambosprit,
    Thanks for the fixes, I will test tonight.
    This is a great piece of work, all I have left are BS and phone issues relative to battery and signal levels. I don't believe these are your issues anymore than the iPhone issues in the same area are.
    Regards,
    Jim
  9. #569
    Feb 2009
    Finland
    To Wolvers:
    Tick the box for 'Do not map through this device' seem to work, but I think it's not right way to fix the problem. Plugin should choose what device to use nor disabling device mapping.
    I have two Silabs, one in car and one in home, both work smoothly and I haven't notice any stuttering.
    To Lambo:
    New dll doesn't fix pop up, it still popping and mobilephone_incommingcall is true when in call.
  10. #570
    Aug 2009
    UK
    But it works and I can now use this brilliant plugin!
    Shame that my Silabs audio stutters a little though.
    Lambo, do I just copy the dll to the plugin folder or do I have to register it or something? Sorry if that is a noobish question!
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
