@ Lambrosprit:
I posted this pic as an upcoming feature of the upcoming DFX release, but thought I would post it here, showing it in action. Thanks so much for this plugin! It's about time I can use my iPhone in the car with the CarPC!!!!!! Kudos!
All that is left, is to have the callin screen go away, and stay away once in a call
My Fiero Build Thread
new test dll to see if I managed to fix it this time. Needed a new bswrapper so giving whole installer. Report back on if its fixed please then will add to first post.
EDIT:Moved to first post
I cannot get the dialbox populated by the list select. What's the procedure to do this?
As long as the code is 'mobilephone_dialbox' and the MobilePhone_PC.txt file is listed correctly then it should work.
What skin is that MGD, looks really good?
Well, the Custom list reads the file "MobilePhone_PC.txt just fine, otherwise the list would not populate and the label is called mobilephone_dialbox but when I click on an Item in the list, it will not show in the label.
Skin is called CONTOUR what I am working on right now.
EDIT: Me being stupid seted the color of the MobilePhone_dialbox to black. Now white and working.
1.14 working well for me, thanks for the changes Lambo.
I've altered my skin to suit it, and other changes, with the following;
1. Switches to mobilephone.skin after answering an incoming call.
2. In call indicator added to mobilephone.skin.
3. Bluetooth phone connection indicator added to mobilephone.skin.
4. Reject call button removed from mobilecall.skin.
5. Caller photo added to mobilecall.skin.
6. mobilecall.skin made larger.
