Page 59 of 136 FirstFirst ... 9495051525354555657585960616263646566676869109 ... LastLast
Results 581 to 590 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #581
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    so without reading almost 600 posts
    if i was starting from scratch with this plugin, 1.14 now.
    what do I need to have pre installed?
    and do you have to pay for the BlueSoleil to keep this pluging working?
    im guessing the first post is out of date now too?
  2. #582
    lambosprit's Avatar
    Sep 2006
    UK
    Release 1.14 moved to firt post. New Simplistique skin by Wolvers added to the installer.
  3. #583
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Woofnstuff View Post
    first post is upto date. i just wanted people to test the fix before officially releasing it.
    Following is copied from the installer readme
    Installation instructions
    Pre-requisites:
    1) IVT BlueSoleil 5.x or 6.x has to be installed.
    For BlueSoleil 5.x,version 5.4.236.0 or greater is required.
    For BlueSoleil 6.x, version 6.4.236.0 or greater is required.
    2) This is a .net application so the .net framework must be installed. 2.0 is required.
    3) The BSWrapper uses VC++ so needs to have the VC++ Redistributable installed. Its called vcredist_x86.exe and should be in the installer folders.
    Alternatively
    http://www.microsoft.com/downloads/d...displaylang=en
    Installing:
    Run the installer exe. If it fails check out the troubleshooting guide thats part of the zip file.
    You need to pair the phone before using this dll. Do this in bluesoleil itself. Once paired it will remain paired forever unless you unpair.
    Next, you need the bluetooth address for the phone. Hover over your phone in bluesoleil and you'll see it.
    This needs to be added to your mobilephone.ini file for the dll to allow you to connect only that phone. This is for security reasons.
    yes you do need to buy Bluesoliel but its a one off payment and you wont have to pay anything after that. It is locked to the machine though so careful if you install on a test machine before installing on your PC. The way to do it is to use the 30day trial to test then install on the correct machine so you dont need two licences.
  4. #584
    Mar 2009
    roadrunner
    lambosprit
    this plugin work with roadrunner
  5. #585
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by achillealb View Post
    lambosprit
    yup. Thats why its in the RR released plugins forums
    unless you're asking if it works with OLD roadrunner rather than Riderunner. The answer is yes BUT you have to use the old method of registering the plugin using x,mobilephone and watch which version of RoadRunner you use as some of them had problems with more than one plugin being loaded (it only loaded the first one)
  6. #586
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by lambosprit View Post
    This is a screenshot of what it looks like when working. Notice the green circle above the conn button. This indicates that RR has connected with your phone successfully.
    Is this a real screenshot? I have the same nokia model but can't see battery and signal slider...
  7. #587
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by l1nk View Post
    It is but this nokia model doesn't output the battery and signal codes so it defaults to 5 bars. You have to have images with the correct name in the folder you specified in your ini file. Or if your using the new slider code you have to have valid sliders in your skin but if you're using the same phone you'll just get the 5 bars I'm afraid.
  8. #588
    Jun 2007
    Sardinia Island
    Ok, so it's correct. I haven't graphic bars (don't know why, I'll check) but I have the numeric values on the skin and both shows "5", even if on the display phone they aren't to the max!
    Tried also with an n95 8gb but no success.
    Anyone knows some cheap phone with battery and signal support on bluetooth connection?
  9. #589
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    moto old razr did that on phonecontrol.net from Zorro, should work on this one also
  10. #590
    Nov 2009
    nokia 5800
    Hey, first of all, great plugin you made there 0o.
    I'm just starting out with my first few little testruns with riderunner on my normal desktop pc, just to see if it will suit my needs ^^. One of the things I really like, is having a handsfree set, so I'd like to try this plugin out a little.
    There's one problem though, my mobile phone (nokia 5800 expressmusic) isn't in de list of models supported by Bluesoleil. Using the n96, or 5700 models in bluesoleil, does install an api on the phone, but as to be expected, its not compatible and so it won't update my contacts in the normal browser. Let alone it functioning in the mobilephone plugin.
    I did send a support message to the guys at bluesoleil (I read they're pretty helpful), but I'd like to know if you guys know any way to make this work on my phone?
    If this isn't going to work, then I'm considering buying another phone to use with this app exclusively. Wich of the models work best with the api, as far as you guys know?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
