Page 60 of 136 FirstFirst ... 10505152535455565758596061626364656667686970110 ... LastLast
Results 591 to 600 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #591
    Jun 2007
    Can I mute or stop dvd when incoming call?
    I test on VLC,MPC,WMP have same bug
    can speed up volume when use handfree? and slow down volume when hangup or finish to talk.
  2. #592
    Jun 2007
    Excuteme sorry its can not stop when play only title
  3. #593
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by anuchit View Post
    If you have an incomming call rr is sent a pause command. This should pause video or music.
    as for all the volume change requests , I'm waiting for Spidermunz whose arranging some fancy new stuff in RR that'll I'll make use of. Not sure where he's got to with it though as its been a while. Might be time to pester him
  4. #594
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by MGD View Post
    moto old razr did that on phonecontrol.net from Zorro, should work on this one also
    Ok, just buyed one used pink razrv3 on ebay. I'll test it next weekend then I'll post results here. Thank you
  5. #595
    Jun 2006
    ok I'm having trouble getting the dll's to register ? where do I need this file ?
    The BSWrapper uses VC++ so needs to have the VC++ Redistributable installed. Its called vcredist_x86.exe and should be in the install folders.
    not sure I understand which folder it needs to be in ? I also did the post 77 recommended fix and that didn't help either. For some reason they are not getting registered ?
    Thanks,
    Mini Sumo Was here
  6. #596
    Jun 2007
    Hi guy
    I test your plugin and I found alittle delay and echo.. but It work for me look great..
    I install asio4all and setting ( pic)
    and install andrea audiocommaner and set microphone wizard
    It seem better than before I not use..
    I use normal microphone .
  7. #597
    Jun 2007
    Can you make asio4all vertual device plugin for ivt bluesoeil seem foobar
    I think myselft.
    it work about latency compensation of sound because it prefer direct soundcard to speaker.
  8. #598
    Aug 2009
    UK
    Quote Originally Posted by lambosprit View Post
    Can you speak to him about radio on and off as well as I don't think the radio mute commands in the buttons on my skin are working as I'd like? I think it's unmuting the radio when I press the call/dial button when the radio is not being used and subsequently the caller hears radio as well as me.
    Any word from BS about echo cancellation?
    I still haven't figured out why your plugin makes my radio audio skip.
  9. #599
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I installed this and got it working so far. I do notice a delay and on the other end they can hear themselves after a delay as well.
    Any tweaks or adjustments for the echo cancellation? I'm using an Andrea mic like from the store.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  10. #600
    Oct 2005
    Quote Originally Posted by sargeants View Post
    Did you just plug in the andrea mic and have it work? I am having issues getting it to work for me.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
