Page 63 of 134 FirstFirst ... 13535455565758596061626364656667686970717273113 ... LastLast
Results 621 to 630 of 1334
Thread: .net Bluetooth Mobilephone Plugin
  1. #621
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by Dougw133 View Post
    Blu Soliel's website was no help, anyone know if the Droid Works with this? Time for a new phone but not getting anything that isn't compatible.
    I'll answer my question. The Motorola Droid works with BlueSoleil.
  2. #622
    Nov 2007
    PA
    Did the PDANET issues ever get worked out? I am not using PDANET for BT DUN, but tethered via USB. Today was my first go at this plugin and it didn't go to well. My phone pairs with blusoleil. When I open the plugin in RR it shows my phone, my number etc.. It doesnt do anything however. There is no contacts, nothing. I made a call dialing out manually and all it did was dial the call, it worked, but I had to pick up the phone and use it like normal. The audio didnt work through the speakers. Is there a way to standalone test this outside of RR?
    P.S. Do I need Bluesoleil mobile? This plugin does not require the CPhone connect plugin correct?
  3. #623
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Well, I was gonna give this a go, but ran into a problem installing Blue Soleil on Win 7.
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  4. #624
    Nov 2007
    PA
    i installed on win 7 64 bit no problem. Whats happening.. This thread really died..would really like to get this working.
  5. #625
    Nov 2007
    PA
    It seems the plugin is working properly to me. Can anyone give any insight into exactly what needs to be done with blue soleil? It seems pretty straight forward but I must not have something configured correctly. I have the phone paired etc..
  6. #626
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Have you tried consulting Blue Soleil?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  7. #627
    Sep 2008
    Exclamation plugin help
    Hello all,
    after looking through the 40 some pages of this thread I am more confused now with all the changes. I am trying to get this plugin to work with Riderunner but have had no success.I downloaded the Mobilephone.net_setup.zip file on the first post and ran it and the vcredist_x86.exe file. I also have Bluesoleil version 6.249 (full version), i can get it to connect to my phone and when i call my cell phone i can answer the call (on the cell phone by clicking answer on the cell phone) and then i can have it transfer the sound to the "headset" which causes the sound to go to the pc speakers. But how can i get this integrated into Riderunner? I have seen different posts about using BMW skin or Carwings_dynaminc skins but cannot find where to get the BMW skin and i dont see where in the Carwings version that comes with RR to get to the phone menu. I tried adding a button manually that goes to the "mobilephone.skin" menu but it looks like a generic tester menu which i think was mentioned before in the thread. It gives me a green icon at the top but nothing else seems to work in it.
    Can lambo or someone give me some insite on what my first step would be to get this working and integrated into RR.
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I'd try using the 'ultimate' skin's mobilephone stuff that's included in the installer as a trial.
    you can just copy that stuff into your working skin folder and load the mobilephone.skin file with a button.
    So you're wanting to use a bluetooth headset rather than a microphone hooked to the PC? There was mention in here about it, I think there's a button or option you set so that when you accept the call it'll transfer the bluetooth connection from the pc to the headset - something to do with having multiple bluetooth connections at once?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  9. #629
    Sep 2008
    Quote Originally Posted by sargeants View Post
    ok thanks, i will try to work with that.
    No i am wanting to get the sound through the speakers of the car and i would have to talk through a mic through the pc but bluesoleil calls it "headset" set up.
    i was messing with the test skin that was included in the install package and it shows it connecting but not much else works, i have tried to call my cell phone from a land line and it seems to know a call is coming in because it tries to load another screen called mobilecall.skin and it says its not found. I saw someone post something about it on post #247 but
    does anyone have a complete skin that this has been incorporated into that i can see?
  10. #630
    Nov 2007
    PA
    Maybe one day we will remote start our cars with our phone
    Looking great, can't wait to get this running.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 08:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
