Page 65 of 136 FirstFirst ... 15555657585960616263646566676869707172737475115 ... LastLast
Results 641 to 650 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #641
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Radu, who is your service with?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  2. #642
    Sep 2007
    Italy
    i did not installed cphone tools, only blue soleil drivers. cphone tools is not free, it costs 14,99€
    Quote Originally Posted by stonestatue View Post
    what do you mean?
  3. #643
    Feb 2006
    I mean your cell phone provider.
  4. #644
    Sep 2007
    Italy
    Italy - Wind
    sorry for my english
  5. #645
    Feb 2006
    Just wondering if the application supports all phone providers.
  6. #646
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i installed bluesoleil and the mobilephone plugin and i'm able to make and receive calls on my iphone 3g! no phonebook syncing at the moment but i exported my contact list to mobilephone_pc.txt which is sufficient. the final piece of the puzzle is echo cancellation which should be eliminated by the phoenix soho card which i ordered yesterday.
    i've done a lot of reading in the past few days and it looks like the soho is the only thing available right now that can reliably eliminate echo for a handsfree phone setup for carpc's. the soho is a passthrough card which plugs into a pci slot but only for power. as you can see here http://forums.fluxmedia.net/general-...enix-soho.html salmizar has figured out how to power the card externally so even if you don't have a free pci slot, using a laptop, or just don't have room in your case, this is a great option.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  7. #647
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    ok i've run into a problem with the bluetooth audio volume being too low. i can't hear the person on the other end of the call unless i turn the stereo way up. when do this and the call ends, i get blasted with the music starting back up. any fix for this lambosprit? is there a way to boost the bluetooth audio gateway volume with bluesoleil?
  8. #648
    lambosprit's Avatar
    Sep 2006
    UK
    Looks like this is going to be just another Freefone.
    Nope...just needed a break. Was actually working hard on getting FTP and DUN working for myself and another user. He promised to post full steps to how he got it working but nothing yet.
    Anyway back now so will try to catch up.
  9. #649
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by riko View Post
    Hello guys,
    I integrated this plugin in my skin, I wanted to know:
    1 - when I receive a call, the mobilecall.skin appears after 5 / 8
    seconds - why?
    2 - How do I ignore a call?
    3 - How do I view the missed calls?
    4 - with my phone call the phone associated with
    RideRunner, if I close the call remains open window
    mobilecall.skin, how do I close it as soon as you close a
    call?
    5 - at the opening of mobilephone.skin How do I upload at once
    Heading? (MobilePhone_DC.txt)
    6 - How does the edit of a number? I do not work or do not know
    how it works :-)
    how to use the integrated Bluetooth hardware in the notebook, I
    Following the installation Segond that indicated in the first post.
    tried as a phone with a Nokia N70 - Samsung i8510 - INQ3
    I attach my mobilephone.ini
    please help !!!
    Most of these are in the help file. Just a question (no citisism) Does anyone use it?
    anyway 1) Mobilecall.skin pops up because its coded to. That way you can answer a call from any skin page rather than having to navigate to 1. To disable it (at your own risk) ee the ini file.
    2)mobilephone_cancelaa command does this if you have auto answer set otherwise just use Mobilephone_hangup
    3)You can't. Its not part of the plugin.
    4)This has been discussed in the thread. Use a combination of Mobilephone_hangup||quit
    5) not sure what you mean. Its RR that loads a custom list. The custom list is populated by whats in mobilephone_pc.txt. If the skin shows the list straight away then it should show the numbers available.
    6) Editing a number is not supported yet.
  10. #650
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by LNICK View Post
    May I use this pluging with 2 devices at the same time?
    I have a work and a private cellphones that I use in my car.
    Today I have a small BT HF that support it (Ego Cup FM).
    Thanks in advanced,
    Luis
    You can't I'm afraid. You can only connect to one phone at a time. You can have both phones configuired to be connectable but only the first mac address found is linked too.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
