Page 67 of 136 FirstFirst ... 17575859606162636465666768697071727374757677117 ... LastLast
Results 661 to 670 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #661
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Silabs radio audio on the phone
    I'm experiencing a stupid problem with the plugin. In my computer at home it works correctly but in my car it doesn't.
    The only issue is that on my car the person I call on phone (or the person who call me) only hear my fm radio (silabs usb) instead of my voice from the mic even if I correctly hear the other's person voice...
    So I hear the voice but the other hear the fm radio.
    Maybe there's some way to specify which audio card input use for the phone?
  2. #662
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by kuo View Post
    hey lambosprit. first i just want to say great job so far on the plugin. i tried what you suggested and tested those commands but they do not seem to do anything. i loaded up the mobilephone.skin and made a call. i could hear the person on the other side and i sent the command mobilephone_mutespkr and i could still here them at the same low volume as before. then i sent the command mobilephone_unmutespkr and again no change. is there something in bluesoleil to boost the volume? i have a feeling not everyone is having this issue. it may be specific to iphones or maybe just iphone 3g's...i dunno. all i know is i can hardly hear the other end when using bluesoleil's audio gateway on xp.
    the sdk only supplies the ability to change a speaker setting. Rather than make it complicated I just either set it to 0 or full. It should work. Can anyone else confirm if it does and if they have it working with this phone.
    As far as I know there is no way in bluesoliel other than this to change the volume.
    You could try the ctool. If it works better there then its probably something I can fix.
  3. #663
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Tical84 View Post
    Are we still waiting on BS to put SMS in their SDK?
    they just released a new sdk so I'm looking into it but I dont hold out much hope.
  4. #664
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by topjohn View Post
    And me ?
    Knew I'd miss someone.
    Well the fact you dont have a green connect light makes me say check the debug logs. They should tell you what the problem is. If you dont undertsnad them just post them.
    and make sure your debug level is set to 5 to get the most info possible
  5. #665
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by l1nk View Post
    I've had another person report this and I found it my self recently so hopefully will have it fixed soon.
  6. #666
    Jun 2007
    Sardinia Island
    Thank you lambosprit!
    So it's a bug? I was on the idea of a wrong setting by my side!
  7. #667
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello,
    Here are my MobilePhoneDebug.log, I hope it brings you a solution for I understand nothing:
    06/01/2010 16:32:58:Info : Starting MobilePhone version: 1.14.3583.27140
    06/01/2010 16:32:58:Info : Current directory: C:\_Car\RideRunner\plugins\Mobilephone.NET
    06/01/2010 16:32:58:Debug : Path being set to D:\Program Files\PC Connectivity Solution\;D:\WINDOWS\system32;D:\WINDOWS;D:\WINDOW S\System32\Wbem;D:\Program Files\QuickTime\QTSystem\;"D:\Program Files\Symantec\Norton Ghost 2003\";D:\Program Files\IVT Corporation\BlueSoleil\Mobile;C:\_Car\RideRunner\p lugins\Mobilephone.NET
    06/01/2010 16:32:58:Info : Device address: 00:23:76:75:16:5E
    06/01/2010 16:32:58:Info : Pair code:
    06/01/2010 16:32:58:Info : International prefix = 0044
    06/01/2010 16:32:58:Info : International shortcut prefix = +44
    06/01/2010 16:32:58:Info : National prefix = 0
    06/01/2010 16:32:58:Info : Using BlueSoleil for phone connection
    06/01/2010 16:32:58:Info : MobileCall.skin: on
    06/01/2010 16:32:58:Info : Trying to connect to phone.
    06/01/2010 16:32:58:Debug : Updating phoneHandle to : 0
    06/01/2010 16:32:58:Debug : Device handle found is: 0
    06/01/2010 16:32:58:Fatal : Device handle not found for specified address
    06/01/2010 16:32:58:Fatal : BlueSoleil failed to find specified hardware!
    06/01/2010 16:32:58:Info : IVT BlueSoleil SDK is being quitted!
    06/01/2010 16:33:08:Info : Trying to connect to phone.
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINORIGWIDTH;800 from form: menu.skin
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINORIGHEIGHT;600 from form: menu.skin
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINSHOWWIDTH;800 from form: menu.skin
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINSHOWHEIGHT;600 from form: menu.skin
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINXPOSITION;0 from form: menu.skin
    06/01/2010 16:33:16:Debug : Command received :SETVAR;SKINYPOSITION;0 from form: menu.skin
    06/01/2010 16:33:17:Debug : Command received :MEDIALAUNCH from form: menu.skin
    06/01/2010 16:33:17:Debug : Command received :ONCOMMANDINVALID from form: menu.skin
    06/01/2010 16:33:17:Debug : Command received :ONSKINSTART from form: menu.skin
    06/01/2010 16:33:17:Debug : Command received :ONSOURCECHANGE from form: menu.skin
    06/01/2010 16:33:17:Debug : Command received :ONSONGSTART from form: menu.skin
    06/01/2010 16:33:18:Info : Trying to connect to phone.
    06/01/2010 16:33:18:Debug : Updating phoneHandle to : 33125704
    06/01/2010 16:33:18:Debug : Device handle found is: 33125704
    06/01/2010 16:33:18:Info : You have succeeded in getting a remote device's handle.
    06/01/2010 16:33:19:Debug : Updating phoneHandle to : 33125704
    06/01/2010 16:33:19:Debug : Device handle found is: 33125704
    06/01/2010 16:33:19:Info : You have succeeded in getting a remote device's handle.
    06/01/2010 16:34:07:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:07:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:08:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:08:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:18:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:18:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:28:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:28:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:38:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:38:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:48:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:48:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:58:Debug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:58:Debug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:35:01:Debug : Command received :ONBTNPRESS from form: menu.skin
    06/01/2010 16:35:01:Debug : Command received :LOAD;mobilephone.skin from form: menu.skin
    06/01/2010 16:35:01:Debug : Network not available as not connected to phone
    06/01/2010 16:35:01:Debug : Command received :ONSCREENCHANGE from form: mobilephone.skin
    06/01/2010 16:35:02:Debug : Network not available as not connected to phone
    06/01/2010 16:35:03:Debug : Network not available as not connected to phone
    06/01/2010 16:35:04:Debug : Network not available as not connected to phone
    06/01/2010 16:35:05:Debug : Network not available as not connected to phone
    06/01/2010 16:35:05:Debug : Command received :ONBTNPRESS from form: mobilephone.skin
    06/01/2010 16:35:05:Debug : Command received :EXIT from form: mobilephone.skin
    06/01/2010 16:35:05:Debug : Command received :ONSCREENCHANGE from form: menu.skin
    06/01/2010 16:35:06:Debug : Command received :ONBTNPRESS from form: menu.skin
    06/01/2010 16:35:06:Debug : Command received :EXIT from form: menu.skin
  8. #668
    Jul 2009
    B.C., Canada
    When I use the manuf and model label it shows as Nokia for both (It's a Nokia 6275i) Does this mean my phone just isn't sending the right info? It also shows 5 bars for both battery and signal but I have read a few posts mentioning that already.
  9. #669
    Jul 2009
    B.C., Canada
    Ah
    I connected my E71 to see if the plugin picked up the information my 6275i was missing and now I'm stuck on perma-mute. Everything is at full volume, I can even see the green bar going in Windows but there is no sound. I restarted the computer and reinstalled drivers also.
    EDIT:
    Turns out it was a Windows update that did it. It just so happens it was the exact same time I connected my E71 and called in. Hmh, weird. Had to do a restore to fix it. Way to ruin a good thing Windows.
  10. #670
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Still working on getting the Motorola Droid to work. BluSoleil does not officially support the droid, but it connects to my phone and with their ctool plugin trial I can see my phone book and make calls. In the skin I can dial and a call but the sound and voice transmission is still handled in the phone and not through the pc. How do I get it come through PC speakers and use my mic? Is their a setting in bluesoleil?
    I had a call come in today and forgot I still had my BT enabled. The music muted in RR and Mobilephone.net tried to switch to "Call Skin" but it failed. At least some of it is working. I am really looking for settings in Bluesoleil how to manage the speaker and microphone setup. I am using on board sound for MIC input and a PCI Soundcard for output. I see know where to set anything up.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
