Page 68 of 136 FirstFirst ... 18585960616263646566676869707172737475767778118 ... LastLast
Results 671 to 680 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #671
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by topjohn View Post
    Hello,
    06/01/2010 16:33:18:Info : Trying to connect to phone.
    06/01/2010 16:33:18ebug : Updating phoneHandle to : 33125704
    06/01/2010 16:33:18ebug : Device handle found is: 33125704
    06/01/2010 16:33:18:Info : You have succeeded in getting a remote device's handle.
    06/01/2010 16:33:19ebug : Updating phoneHandle to : 33125704
    06/01/2010 16:33:19ebug : Device handle found is: 33125704
    06/01/2010 16:33:19:Info : You have succeeded in getting a remote device's handle.
    this shows you have connected to your phone
    06/01/2010 16:34:07ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:07ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:08ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:08ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:18ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:18ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:28ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:28ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:38ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:38ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:48ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:48ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    06/01/2010 16:34:58ebug : Command received :SETVAR;mobilephone_batterystrength;C:\_Car\RideRu nner\Skins\BMV2\\MOBILEPHONE_BATTERY_5.jpg from form: menu.skin
    06/01/2010 16:34:58ebug : Command received :SETVAR;mobilephone_signalstrength;C:\_Car\RideRun ner\Skins\BMV2\\MOBILEPHONE_SIGNAL_5.jpg from form: menu.skin
    This looks like the skin is only requesting the battery status. Have you added any other indicators or labels to your skin file?
    06/01/2010 16:35:01ebug : Command received :ONBTNPRESS from form: menu.skin
    06/01/2010 16:35:01ebug : Command received :LOAD;mobilephone.skin from form: menu.skin
    06/01/2010 16:35:01ebug : Network not available as not connected to phone
    06/01/2010 16:35:01ebug : Command received :ONSCREENCHANGE from form: mobilephone.skin
    06/01/2010 16:35:02ebug : Network not available as not connected to phone
    06/01/2010 16:35:03ebug : Network not available as not connected to phone
    06/01/2010 16:35:04ebug : Network not available as not connected to phone
    06/01/2010 16:35:05ebug : Network not available as not connected to phone
    06/01/2010 16:35:05ebug : Command received :ONBTNPRESS from form: mobilephone.skin
    06/01/2010 16:35:05ebug : Command received :EXIT from form: mobilephone.skin
    06/01/2010 16:35:05ebug : Command received :ONSCREENCHANGE from form: menu.skin
    06/01/2010 16:35:06ebug : Command received :ONBTNPRESS from form: menu.skin
    06/01/2010 16:35:06ebug : Command received :EXIT from form: menu.skin
    the rest shows that you've lost the connection to your phone and its not reconnected.
  2. #672
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Tical84 View Post
    When I use the manuf and model label it shows as Nokia for both (It's a Nokia 6275i) Does this mean my phone just isn't sending the right info? It also shows 5 bars for both battery and signal but I have read a few posts mentioning that already.
    I just report what bluesoliel finds. So I guess its the phone thats the problem.
  3. #673
    lambosprit's Avatar
    Sep 2006
    UK
    for all those with silabs problems please check that its not selected as the default microphone in the control panel>> sounds and audio >> audio tab.
    When you plug in silabs it seems to make itself the default mike.
  4. #674
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello,
    In fact this is not my skin that I use, I already wanted mobilphone test on a skin or it is already installed (BMV2).
    Indeed there are other indicators in this skin, but I do not see why it will disconnect the phone!
    Have you a simple skin that works for you to send me so I can test and see if the problem is not elsewhere?
    thank you
  5. #675
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Quote Originally Posted by JohnWPB View Post
    @ Lambrosprit:
    I posted this pic as an upcoming feature of the upcoming DFX release, but thought I would post it here, showing it in action. Thanks so much for this plugin! It's about time I can use my iPhone in the car with the CarPC!!!!!! Kudos!
    All that is left, is to have the callin screen go away, and stay away once in a call
    Wow JohnWB
    When will DigitalFX 5.0? be released? That looks so very nice.
  6. #676
    lambosprit's Avatar
    Sep 2006
    UK
    Hello,
    thank you
    try the ones supplied with the installer. The BMV2 and carwings are pretty rubish but the other three work great.
  7. #677
    Oct 2009
    France /Wissous
    Although already have the versions that came with the installer, but hey I'll try others to see.
    I updated with the RR version of January and I thought I read that there was a problem with your plugin and this version ...
  8. #678
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Hi, A super job you have done with this plugin. Worked as a charm without any problems on first try, when other mobilephone plugins/apps has not been willing to co-operate. Also headset function works. Is Sync of mobilephone numbers implemented yet, if not when are you planning to include it?
    Thanks for this super plugin!
  9. #679
    Jan 2009
    would gladly use it but bluesoleil don't want to connect to my bluetooth
  10. #680
    Jul 2009
    B.C., Canada
    Is it possible for the picture box size to change with the picture? It's difficult/impossible to find photos of people that are all the same shape and I'm too lazy to crop every single one.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
