Page 7 of 126 FirstFirst 123456789101112131415161757107 ... LastLast
Results 61 to 70 of 1260
Thread: .net Bluetooth Mobilephone Plugin
  1. #61
    lambosprit's Avatar
    Sep 2006
    UK
    Debug is automaticaly turned on. It can be turned off by a setting in the ini file but I forgot to add it.
    The logs are stored in the .\logs directory so should be in the roadrunner folder \logs. Its called MobilePhoneDebug.log.
    The wrapper dll creates its log files in the current directory i.e. roadrunner directory as I haven't got round to setting it to the correct place yet. All on my to-do list.
    its called BSWrapper.log. You could attach both.
  2. #62
    Apr 2009
    i guess it was never created... i cant find it anywhere... anything else i can do?
  3. #63
    lambosprit's Avatar
    Sep 2006
    UK
    ok. In that case are you sure you are running the dll. Did you add the x,mobilephone line to your menu.skin file? Try switching roadrunners debug on and check its log file to see if its finding the dll correctly. To do this use rrconfig and page 4 of general to switch it on.
  4. #64
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Everything is working pretty good for me. I had some funky errors with the previous version about the debug log being already in use but i havent seen it with the latest. Absolutely excellent job. Is the command to run mobilecall.skin LOAD or menu? I would personally prefer MENU;mobilecall.skin so that i can size the skin like a popup window.
    Live mp3Car Facebook Chat
  5. #65
    Apr 2009
    ok. i've reinstalled everything! and still cannot locate that log folder \ files! did a full serach for them and still nothing... please help.
    Edit: i dont know if it helps but... i just realized that when i install the plugin on the skin it mix's my buttons all around! it messes them up! hope that helps
  6. #66
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by lkarmi View Post
    You're going to add alot more detail to troubleshoot that problem. When you say install the plugin on the skin do you mean add the X line? What version of RR and what skin?
  7. #67
    Apr 2009
    by installing i mean using the .exe file and choose the rr directory and skin directory. the skins i have tried it on them are: elite lite 1.1, iDrive F01 -Alpha-, SIMPLISTIQUE_v0.3 i have checked the menu skin and it has x,mobilephone and the button but again, is scramble all my skin when i install it.
  8. #68
    lambosprit's Avatar
    Sep 2006
    UK
    @Sonicxtacy02. I use LOAD but could easily change to MENU. Does it allow it to be a smaller skin over another? Thats the effect I was after but LOAD doesn't do that.
    @Ikarmi. Lets start at the beginning. Have you checked roadrunners debug file to see if it found the dll? It should be called debug.txt and be in the roadrunner directory.
  9. #69
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by lambosprit View Post
    Yes menu will allow custom sized message boxes. If the box is smaller than the skin resolution it will appear just like a pop up (centered, or user-defined x n y). If the box is the same resolution its just like using LOAD.
  10. #70
    lambosprit's Avatar
    Sep 2006
    UK
    ok. Will make the change to MENU. Its exactly what i was looking for. Thanks
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
