Page 70 of 136 FirstFirst ... 20606162636465666768697071727374757677787980120 ... LastLast
Results 691 to 700 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #691
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by kuo View Post
    i installed a standard microphone into my carputer today and bluesoleil is not picking it up. i've tried setting the carputer's bluetooth profile to "headset", paired, unpaired, deleted, repaired but still no sound goes through the microphone. the microphone is working otherwise. i can use sound recorder and create recordings. it is set as the default recording device in windows xp's sound settings. i've updated to the latest audio drivers, i'm using realtek onboard sound. can anyone help?
    Im in the same spot you are, but after several inquiries I have received no replies to nay of my questions on this thread. There is another rmore related to your problem here.
  2. #692
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    one interesting thing i've found is that everything works fine on my laptop, which is where i do my testing. the caller's voice comes through the laptop speakers and they can hear me through my laptop's built in microphone. however, when i disable the built in mic and plug in an external mic it doesn't work. i set it as the default recording device and the mic works in windows (i can make sound recordings etc) but bluesoleil does not use it. i can hear the caller, but they can't hear me. this makes me think that bluesoleil chooses the devices it wants to use and there's no way for me to change it.
    my carputers are both running onboard sound. there are headers on the motherboards for front audio jacks and i'm wondering if maybe bluesoleil has decided it wants to use the front mic jack as the recording device. i'm going to hack myself together a front mic jack tomorrow and see if that doesn't fix this problem.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #693
    Nov 2007
    PA
    same exact problem here!
  4. #694
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by Dougw133 View Post
    does it work when you use the pci sound card mic jack? i know you said you have a conflict w your radio but did it work with bluesoleil?
  5. #695
    Nov 2007
    PA
    It doesnt work with anything. I am using an old SB Live PCI card with KX drivers so I can individually control 2 different subs located in 2 different areas of my vehicle. The HD Radio is using the line in of the card, but with the SB Live cards the Mic IN and the Line IN operate on the same chip. I can't individually adjust volume and input for each. So I decided i would enable the onbaord sound and use the mic in on that when I setup RR Voice, which it all works fine, until BlueSoleil came along.
    Like you, audio out works, and i can hear people, BS doesn't send any Audio in. There is no where to change the setting. These were the settings in place when I installed Bluesoleil, so I don't know what to do. Seems pretty ridiculous if this setting cannot be changed, especially for 30 bucks, it makes it useless. I am curiosu if anyone else has or had this issue, and how they corrected it. I will send an inquiry to Bluesoleil, but any support related responses i get from them seem to be vague and I always get "We are constantly updating and improving Bluesoleil, check back in the future for further support". The Cphone tool is able to get my contacts as well, but they do not show up in .net plugin. I am using the original greay looking skin, perhaps I should try using another skin. Also, when usiing Cphone tool my phone doesn't automatically send audio to the PC, I have to press the "Transfer" button on the Cphone tool.
    Good luck.
  6. #696
    Nov 2007
    PA
    I wanted to have a test PC for this, don't you have to have an activation for each computer? That was a turn off for me! Or are you using the demo?
  7. #697
    Jul 2009
    B.C., Canada
    Here's something new:
    I can hear my ringtone through the speakers. This just started last time I used it and am pretty sure I hadn't changed anything.
  8. #698
    May 2006
    Simi Valley, CA
    Good luck.
    From my experiences, bluesoliel uses the first alphabetical device for audio regardless of windows settings.
    I emailed support about this and after a month they told me that they are looking into adding the ability to select audio devices.
  9. #699
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by GiODi View Post
    is there a place where you can check what bluesoleil has selected as it's audio device? in the registry or something like that?
  10. #700
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    just using the eval version for testing on my laptop.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
