Page 72 of 136 FirstFirst ... 22626364656667686970717273747576777879808182122 ... LastLast
Results 711 to 720 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #711
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Dougw133 View Post
    Where in the ini am I adding that, and what will that essentially do? I found a funny posrt in another forum on another website, someone using Centrafuse with their droid. They had the same problem and someone told them to enable or disable "Vise Versa Autotransfer".
    Is that basically what this will do? Reverse thinking for the plugin?
    I am running XP Pro as well. Like I said I have to have both Soundcards atm, so guess im outta luck unless I can find a hack to rename devices.
    There is maybe some hope for the audio problem. The latest sdk from BS has a wavein an waveout device setting. I'm going to have a play but be patient please. I've had to rebuild my pc and I've lost my bs licence and until I find it I can't do any testing
  2. #712
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by lambosprit View Post
    that's great news lambo. if you need a tester, i'm ready to go. i gotta say though, your plugin is awesome. bluesoleil...not so much.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #713
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by kuo View Post
    Agree!
    I dont think that the swap onresume will work for me. It has be done once the call is active. I don't know why. BS does not officially support my phone so I am happy I am this far, dont understand why they dont, nearly 99% of the functions work.
  4. #714
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Agree!
    in that case you could try changing the code for the answer button for mobilecall.skin and mobilephone.skin from "mobilephone_pickup||radiomute" to "mobilephone_pickup||radiomute||mobilephone_transa udio".
  5. #715
    Nov 2007
    PA
    Sounds what I am looking for, I'll give it a shot!
  6. #716
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    This is the reason why you need to run Mobile AutoTest Tool and send result to BS, so they could add support for your phone! There is hundreds different phone models in world, BS will not going to buy all those just adding support for those. Be active, help BS to help you.
    Edit: I send two phone reports and BS add both.
  7. #717
    Nov 2007
    PA
    Quote Originally Posted by Dartman_71 View Post
    Well thanks for the insight. BS autotest tool doesnt currently support CDMA, so I didnt do it.
  8. #718
    Feb 2009
    Finland
    Okay then you need send mail to BS and pester them to do something about it.
  9. #719
    Nov 2007
    PA
    I have been pestering BS since owning an LG Voyager which was in no way supported. I figured when I got the droid with it's popularity they would eventually have to support it. I could be wrong but whatever. I have offered to test or send them what ever they need and I keep getting what look like auto responses. Thanks yeah yeah.
    On another note, no matter what skin I use to test I keep getting a "Mobilecall.skin" not found error from RR.
  10. #720
    Nov 2007
    PA
    I dont see that line in of code in either mobilephone.skin trst files I have, one for carwings either.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
