Page 75 of 136 FirstFirst ... 25656667686970717273747576777879808182838485125 ... LastLast
Results 741 to 750 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #741
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by bratnetwork View Post
    I'm going to be honest, this is a really long thread and I haven't read through the whole thing. I DID do a search through it though and did not find an answer to my question.
    I have been looking a good BT phone control program. I have bluesoleil and played with it bit already. What I want to know is that with this plugin will it automatically connect to the phone if you are in range?
    With just the bluesoleil stack itself i have to connect it manually every time. After its connected it seems to work ok.
    Using a HTC Touch Pro2 CDMA version with Windows Mobile 6.1.
    If you have the plugin running i.e. road runner up and running and you have autoconnect set in the ini then yes it will automatically connect. I dont know if your phone is supported but the plugin is programed to allow this
  2. #742
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by lambosprit View Post
    well we are going to find out... I should be testing it within the next few days. I'll let you know how it works out.
  3. #743
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i bit the bullet and installed windows 7 alongside of xp on my carputer. by default the digital audio device was the first alphabetical device. i renamed my mic so that it was the first alphabetical recording device by renaming it from "microphone" to "analog microphone". i installed bluesoleil and what do you know...it works. so the problem is definitely that bluesoleil only uses the first alphabetical recording device and for now there seems to be no way to change it. in xp i have been unable to find a way to rename audio devices so for now the only solution for those of us who's mic's do not work with bluesoleil is to use windows 7 or vista instead of xp. on the plus side, windows 7 gives me hybrid sleep and individual volume control for each program. the only negative so far is that the start button does not get hidden by rr. more configuring and testing to come.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  4. #744
    Sep 2009
    It isn't possible to have two phone books at the moment. I had plans for different phonebooks
    depending on source i.e. pc or memory card but they're floundering at the moment.
    re:
    Sorry, I didn't mean the mobilephone plugin, I meant the BlueSoleil plugin called cPhoneTool. I had to install that to get it so I could hear the other person and that, as well as BlueSoleil has a seperate charge. Am I the only one that had to install cPhoneTool for it to work properly?
    Hi Lambospirt, again great job with the plugin, much appreciated. I dont think id go the carputer route without this option...
    Tical84, any luck getting it to work without cphonetool? I am experiencing the same with a Blackberry 8820
    Kuo,
    did you end up resolving the handsfree echo problem? I have the same problem and have the andreas stereo mike, I am hoping that has some noise cancellation feature i can use
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by thehump View Post
    i bought the soho pci card that does echo cancellation. i've not actually been able to try it since i was having trouble getting bluesoleil to work with my mic. others have reported that it eliminates echo completely though.
    the soho is a passthrough card that only uses the pci slot for power. over in the centrafuse forums, someone figured out how to use the card externally by soldering a 5v and ground wire to the card so that laptop users or those limited by space can use it.
  6. #746
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I sent Bluesoleil a detailed inquiry about not being able to select device inputs. After a week a I get this "So much sorry you have problem. Blue Soleil has just been updated, so upgrade please". Upgrade didn't do a thing to solve our problem. Maybe if enough people get on them.
  7. #747
    lambosprit's Avatar
    Sep 2006
    UK
    the sdk has got input and output wave devices. I'm testing a version now which will allow you to set both from the ini file.....I hope. It will mean an upgrade to the latest bluesoliel but that shouldn't be a problem as the upgrades are free if you purchased a legal copy.
  8. #748
    Jul 2009
    B.C., Canada
    To be honest, I haven't tried. I've just been using it with the CPhoneTool installed. My BS trial has expired and I'm not quite ready to put this thing in my truck (still need to purchase some hardware) so I'm not going to purchase BS just yet.
  9. #749
    Nov 2007
    PA
    Keeping my fingers crossed!
  10. #750
    Sep 2009
    hey guys i got it working well thanks for all your comments/help. I think I can get it working without cphonetool, they key was to not open the bluesoiel main window at the same time ride runner was open. I guess both programs dont share the bluetooth resource nicely (seems quite simple in hindsight). Also the latest version of BS (.299) has additional support for blackberry and iphone so its better now.
    the only ride runner problem I have now is occasionally the when mobilecall.skin comes up when i receive a call, the answer or drop call buttons on mobilecall.skin wont work and the debug log shows this...
    PM:Info : Phonebook functionality not part of current SDK
    anyone experience this before?
    I still have the echo problem... will need to continue to hit mute constantly in the meantime. i am thinking about going with this solution:
    http://store.mp3car.com/External_USB..._p/aud-004.htm
    and then use VAC
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
