Page 76 of 136 FirstFirst ... 26666768697071727374757677787980818283848586126 ... LastLast
Results 751 to 760 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #751
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by thehump View Post
    hey guys i got it working well thanks for all your comments/help. I think I can get it working without cphonetool, they key was to not open the bluesoiel main window at the same time ride runner was open. I guess both programs dont share the bluetooth resource nicely (seems quite simple in hindsight). Also the latest version of BS (.299) has additional support for blackberry and iphone so its better now.
    the only ride runner problem I have now is occasionally the when mobilecall.skin comes up when i receive a call, the answer or drop call buttons on mobilecall.skin wont work and the debug log shows this...
    PM:Info : Phonebook functionality not part of current SDK
    anyone experience this before?
    I still have the echo problem... will need to continue to hit mute constantly in the meantime. i am thinking about going with this solution:
    http://store.mp3car.com/External_USB..._p/aud-004.htm
    and then use VAC
    What I did was enable the Echo Cancellation in the Realtek Control Panel; worked like a charm.
  2. #752
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Spikemonkey View Post
    Just check my setting in realtek and its enabled so now I know why I wasn't having the problem. Thanks for that
  3. #753
    Aug 2009
    Virginia
    Quote Originally Posted by lambosprit View Post
    Heh. Glad I could help!
  4. #754
    Jan 2010
    Ohio
    When an incoming call comes in how do I get the name to show up instead of the number? I have all my contacts saved in the MobilePhone_PC file.
  5. #755
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by Slider1385 View Post
    Label command "mobilephone_callername"
    Contacts in MobilePhone_PC needs to be LST123456789||John Doe
  6. #756
    Variable Bitrate egeekial's Avatar
    May 2004
    How are people using a microphone hooked to the computer for phone calls? I can get sound from the call to come through my speakers, but I cannot get sound to go the other way (i.e., from my computer microphone to the call). I have dug through this forum, Google searches, and the BlueSoleil options to no avail. I have an iPhone 3GS, Windows XP, and the newest BlueSoleil.
  7. #757
    Aug 2009
    Virginia
    Bluesoleil will only use the first alphabetically listed device for input and output. And unfortunately in XP, you can't change what the devices are called. Supposedly they are going to put the ability to pick which one you use in the next release.
    You are never done installing a CarPC.
  8. #758
    Low Bitrate Challenged's Avatar
    Jan 2010
    Spikemonkey beat me to it I'm using Windows 7 and renamed my analog microphone input from "Microphone" to "Analog Microphone" so that it is the first listed and that does seem to work for me.
  9. #759
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Any chance that I can use my lifecam mic for audio input? cause I just see the audio board device on the advanced audio proprerties... any way to switch to my webcam (lifecam) mic?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  10. #760
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Another dumb question... the battery level and signal level only works after I restart the RR, before that, the values are messed, like in the log attached. I can use the software for calls, normally, just the battery and signal levels donīt work.
    as I say, after restart RR, all things back normal... How can I fix it without restart the RR? ( I already try mobilephone_disconnect/mobilephone_connect... donīt work...)
    please, help me...
    thanks...
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
