Page 77 of 136 FirstFirst ... 27676869707172737475767778798081828384858687127 ... LastLast
Results 761 to 770 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #761
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by marteline View Post
    Another dumb question... the battery level and signal level only works after I restart the RR, before that, the values are messed, like in the log attached. I can use the software for calls, normally, just the battery and signal levels donīt work.
    please, help me...
    thanks...
    Not sure what you're saying here. Do you see proper values for battery and signal at any time? My phone (and most others) dont seem to support this so if its not supported it defaults to a value of 5 for both.
    Before you restart RR has it resumed from hibernation or something? I dont understand what state rr is in before you have to restart it.
  2. #762
    Newbie dongzhi's Avatar
    Feb 2010
    CHINA
    Dear developers, lambosprit sir
    I like your program, I try to install it, I'm using WIN7, Bluesoleil_5.4.256.0, RR 2010, REBORN skin(http://www.mp3car.com/vbulletin/rr-r...89-reborn.html), but I was never able to make it work.my phone is samsung i900.
    My English is poor, I try to read your text, but still can not successfully install.
    Can you give me a detailed installation step? Many thanks for your hard work.
    In China, a traditional New Year period, you are far away in the UK, the best way Chinese New Year blessings.
  3. #763
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by dongzhi View Post
    your log files would help. Makes sure you have debug set to 5. I need the MobilePhoneDebug.log and the bswrapper.log. Also the debug.txt file from RR.
  4. #764
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by lambosprit View Post
    Nevermind, once you sayd that the battery values and signal are not supported yet, I just removed those indicators from my skin. ;-)
    Any chance that in the future we can set a "custom MP3 ring" in the .INI settings?
    thanks again,
    regards,
    Marteline
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  5. #765
    Feb 2010
    CHINA
    2010/2/19 8:46:20: Start -- Version: 2010/2/1
    2010/2/19 8:46:20: OS Type: Windows 7
    2010/2/19 8:46:20: FileManager: FileMode = Legacy
    2010/2/19 8:46:20: FileManager: mypath = C:\Program Files\RideRunner\
    2010/2/19 8:46:20: FileManager: ProfilePath = C:\Users\myuser\Documents\RideRunner\
    2010/2/19 8:46:21: VMC---> Set object successful
    2010/2/19 8:46:21: VMC---> SOURCE: Playback Input line #1: "扬声器"
    2010/2/19 8:50:13: PLAYER: Winamp Version:
    2010/2/19 8:50:13: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    2010/2/19 8:50:13: No Phidgets interface detected.
    2010/2/19 8:50:13: Plugin Manager: loading Global Plugins...
    2010/2/19 8:50:13: Plugin Manager: Plugin Found: Mappoint
    2010/2/19 8:50:13: Plugin Manager: Plugin loaded (Global): Mappoint
    2010/2/19 8:50:38: Plugin Manager: Plugin Found: MobilePhone(.NET)
    2010/2/19 8:50:38: Plugin Manager: Warning Plugin MobilePhone does not support Initialize Method
    2010/2/19 8:50:38: Plugin Manager: Plugin loaded (Global): MobilePhone
    2010/2/19 8:50:38: Plugin Manager: Plugin Found: SkinTool
    2010/2/19 8:50:38: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    2010/2/19 8:50:38: Plugin Manager: Plugin loaded (Global): SkinTool
    2010/2/19 8:50:38: Plugin Manager: Plugin Found: Weather
    2010/2/19 8:50:38: Plugin Manager: Plugin loaded (Global): Weather
    2010/2/19 8:50:38: Plugin Manager: loading Global Plugins Completed.
    2010/2/19 8:50:38: LoadSkin: C:\Program Files\RideRunner\Skins\Reborn\
    2010/2/19 8:50:38: Plugin Manager: loading SkinDir Plugins...
    2010/2/19 8:50:38: Plugin Manager: loading SkinDir Plugins Completed.
    2010/2/19 8:50:40: CheckResume: ResumeMusic=0 WasRadio=0
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=C:\Program Files\RideRunner\Plugins\Mobilephone.NET\
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=true
    standardphonebook=0
    phonebooksencoding=windows-1252
    info;
    you've not set your device address properly in the ini file.
    Dialog box is displayed, I did not set the ini, which a configuration file do? How do I set?
    Please understand my lack of knowledge, thank you for help
    All the distinguished predecessors:
    I am a beginner, English is poor, may be the future I can to create the skin, it is because of your help, thank you.
    My computer is viliv x70ex ,windows 7.
  6. #766
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    If you haven't edited the mobilephone.ini then the plugin cannot connect to your phone.
    In your plugin directory you'll have mobilephone.net, and in there is the mobilephone.ini, open it and find this section.
    [code][BLUETOOTH]
    #Not required for ATSM
    #Blue tooth address for allowed phone. Found from BlueSoleil by hovering mouse over correct phone.
    #Multiple addresses can be added seperated by a ; Phones connected in order of list. Only one is connected to.
    Address=[code]
    after the address you'll need to put the MAC address of your phone. Save the file and restart RideRunner.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  7. #767
    Feb 2010
    CHINA
    Very grateful to canada sargeants sir, I will INI in the Address = [xx: xx: xx: xx: xx: xx] replaced with paired Bluetooth MAC address, a success.
    The software can automatically search for the Bluetooth program, if the phone MAC address, fill in the INI file is even more perfect.
    RR a lot of the first attempt to install software, a friend, you can easily feel the success of the first happy, more willing to put the future of this hobby and enthusiasm.
    Thanks again to all friends.
  8. #768
    Feb 2010
    CHINA
    lambosprit sir: SMS is How do I enter it? Where the text entered into it? ? ? Possible, I will not do? ? Up to now, or do not understand,,,,
  9. #769
    Dec 2009
    I don't think SMS is supported.
  10. #770
    lambosprit's Avatar
    Sep 2006
    UK
    if you have multiple phones that might be used in the car just put all the mac addressess seperated by a ;. The first mac address found will be the one used. Only ONE phone can be connected too at a time.
    and SMS is not supported.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
