Yes, I saw the typo too
For me the plugin works ok. I have a few problems though.
(windows7, latest riderunner, bs 6.4.249.0, sony-ericsson k800i)
1. Phonebook doesn't work, the contacts don't get transferred from the phone to the plugin. However, rightclicking my phone in Bluesoleil, I have the Contacts option, and it transfers my contacts from the phone. Furthermore, I can right-click a contact and successfully send a SMS all this from within Bluesoleil.
So it seems logical that if BS can do it, the plugin should too. I'm only interested in the contacts part, not the SMS.
2. Redial. The plugin redials the last dialed number, from the phone's record! -regardless of the number on the plugin's record.
3. I'd like to set up a "reset BT" button that turns Bluesoleil off, then on (same as right click BS tray icon, turn
bluetooth off/on). Randomly, the COM port gets stuck connected after leaving RR, and the only way the Plugin can reconnect to the phone upon next start, is by restarting BS. What would be the command? If I'm not mistaken, it is used when going into standby, as the tray icon turns gray.
Smaller problems:
4. signal, battery aren't displayed (however centrafuse can display them, so the phone is ok) Sliders don't show at all, not even the default 5/5. (.INI slider folder set by default to ...\RideRunner\
Skins)
5. my voice gets played back in the PC speakers, and never gets through to the other phone, through BT. -though I admit this could very well be a windows setting... solved by renaming the microphone to A-Microphone so it's now listed first.
6. Phone manufacturer displayed correctly- Sony Ericsson, but model is "AAD-3022031-BV" which is the type code, instead of K800i. LG KE970 shows up correctly, and Bluesoleil shows S-E K800i correctly too.
7. While more than one MAC can be added in the INI, only one COM port, but in Bluesoleil each phone has a different COM port.
