Page 80 of 136 FirstFirst ... 30707172737475767778798081828384858687888990130 ... LastLast
Results 791 to 800 of 1360
Like Tree1Likes
Thread: .net Bluetooth Mobilephone Plugin
  1. #791
    Jan 2006
    [QUOTE=mcfly;1378098]
    3. I'd like to set up a "reset BT" button that turns Bluesoleil off, then on (same as right click BS tray icon, turn bluetooth off/on). Randomly, the COM port gets stuck connected after leaving RR, and the only way the Plugin can reconnect to the phone upon next start, is by restarting BS. What would be the command? If I'm not mistaken, it is used when going into standby, as the tray icon turns gray.
    I have the same problem using a belkin dongle. Damn BS sometimes hangs, or refuses to wakeup.
    I solved with with devcon and a batch file to enable and disable it. Also used separate bats for hibernate and resume to make sure connection is always stable.
  2. #792
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by marteline View Post
    I think that I donīt make myself clear... (sorry about my poor english)
    I just want to select a single mp3 file in the computer to play when the mobilephone plugin detect a call, but just in the computer, I donīt care if the phone still playing his ringtone.
    What about that?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  3. #793
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    There is an indicator, mobilephone_incommingcall=true/false. Maybe that could be used to decide when to play the mp3. I'm new to RR skins so...
  4. #794
    Dec 2007
    Romania
    Quote Originally Posted by mcfly View Post
    4) more on this tomorrow, I'll try to make some screenshots of your test skin and the Reborn skin.
    I turned debug to level 5, log file is attached.
    The test skin shows the └ and │characters, which change according to the signal level displayed on the phone. Two states caught on camera:
    I think └ is 5 and │ is 3
    At least I see from the log, why no image is displayed for the level indicators...
    Attached Files Attached Files
  5. #795
    Jul 2009
    B.C., Canada
    Does anyone have problems with it not muting automatically while playing Sirius? It works fine withe MP3s but not with Sirius.
  6. #796
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    mine it looks like it's registered, it shows two green dots in Plugin Manager, but I'm getting multiple errors with some BSwrapper message and I don't know what to do. the mobilephone.net plugin window won't open. I can't even get the button to show on the main scren. when I hold the main menu empty button for a couple seconds I can select the button from the list(it is there), but it won't show up on the main menu. what I'm doing wrong? I'm a newbie. please help.
    I don't have the latest BS, it is a 6.0227 or something like that.
  7. #797
    Jul 2009
    B.C., Canada
    Read the first post.
    "Pre-requisites:
    1) You must have BlueSoleil version 6.4.236.0 or greater is required for this plugin to work. You can use the trial version to test.
    2) This is a .net application so the .net framework must be installed. I've tested it with .net 2.0.
    3) You must have the vc runtime installed. You'll find it in the installer rar."
  8. #798
    Dec 2007
    Romania
    What about that?
    I have a similar desire too, actually a way to play a sound when connecting/disconnecting the phone. Just drove an Audi with OEM bluetooth handsfree, and it's quite useful to have an audible confirmation that the phone is connected. Something like ONPHONECONNECT (ONINCOMINGCALL for marteline) command
  9. #799
    lambosprit's Avatar
    Sep 2006
    UK
    Ok. thats more doable. I could use the SAY or TALK command in RR for that.
    The problem with the incomming call thing is that the phone ring is pased through RR so you'd hear the phone ringing and the mp3 file.
  10. #800
    lambosprit's Avatar
    Sep 2006
    UK
    I'll have a look. It seems that the phone is responding but with rubbish info. The bet I can do i think is just to tap it and set it to the max value. May be able to add debug to help as well.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
